Question about Goodman Heating & Cooling
No spark to pilot for janitrol GUPI100-4. Installed new pilot assembley and a new ignition control board
  • tony
    tony Nov 18, 2013
    Thanks Paul, Robert and Mrfixit...Inducer motor runs when I call for heat. Sensor is brand new. Pilot knob is brand new, it's on the new ignition control bd.
  • 69 Answers
Did make sure you grounded new control board properly and gap for electrode set correctly??
Posted on Nov 19, 2013
  • tony
    tony Nov 19, 2013
    Thanks David...new ignition control bd is grounded. Don't know anything about gap for electrode. Where and what is that?
4 Suggested Answers
  • 24 Answers
SOURCE: janitrol gup power vent ignition sequence
inducer motor should run for several seconds before furnace lights, this proves the pressure switch and ensures proper ventilation
Posted on Sep 30, 2009
  • 1033 Answers
SOURCE: Janitrol GUPS075-3 Furnace burners will not stay lit
The first thing I would do is make sure the flame sensor is clean, this is a metal rod immersed in the burner flame on the opposite side of the igniter. If too much oxidation builds up on it, it will not allow the burner to stay lit. To clean, just turn off furnace and remove flame sensor and clean with steel wool and then reinstall. If this does not solve the problem there may be a problem with the gas valve.
Posted on Nov 08, 2012
  • 2550 Answers
SOURCE: majestic 33bdvtrn will not allow a spark when the pilot light knob is depressed.
Sounds like it is shorting out on the pilot knob
Posted on Dec 05, 2012
My Janitrol/goodman model gups100-4 will not light pilot strong new thermocouple
Hello Hal,
The picture show with your question seems to indicate a small furnace... The THERMOCOUPLE statement flies in the face of that...
There's no extra charge for a more detailed question... but the only reason to replace a thermocouple is if the pilot lights... but wont STAY LIT...
The "pilot" click... would be really nice to hear about.
Most of your modern "sparkers" or HOT-SURFACE igniters
will only try a few times to light the pilot... then they should lock up... to keep from accumulating a dangerous amount of gas... and to avoid a possible EXPLOSION.
SOMETHING YOU MUST keep in mind while you are working on your heater... GAS.
To reset your logic... you might be able to simply remove power.
(in my opinion) The most common failure is a fractured hot surface igniter... (but I've put a page full of ideas below)
If you are hearing an initial click... check for line voltage at the hot surface... if equipped for the pilot to light... (this is where I put my finger to see if it was warm... That was how I DISCOVERED it was FULL LINE VOLTAGE (not a recommended... test).
If you are not getting that INITIAL CLICK you have several areas to pursue... low voltage transformer is good (volt-meter)...
High temp sensors (etc.)...
Not expensive... but dangerous if not correctly serviced.
Might be time to hire a certified professional.
Hope I'm helping!
https://www.bing.com/search?q=janitrol%2Fgoodman+model+gups100-4&form=EDGEAR&qs=PF&cvid=1e58b531d95e4c9f9904821d15bba8c5&pq=janitrol%2Fgoodman+model+gups100-4&PC=DCTE
Go to Bing homepage
Nov 13, 2016 | Heating & Cooling
Automatic pilot light wont light on a honeywell furnace
Honeywell is a controls company and makes a variety of auto-pilots. If this is a no spark problem,does the lead from the igniter go to a big PC board or a module. If a module, check voltage to the spark module or thermostat voltage to the ignition module. If it comes from a large board, the board may be bad. I'll need more Info. if this does not cover it for you.
Nov 18, 2013 | Honeywell Power Humidifier: Furnace...
Onan 4000 generator has no spark
If there is no spark, the ignition module may be bad, or the wiring to it. Have the module ohmed out. Also the magnetic trigger assembley that is on the rotor that sweeps past the ignition module maybe broken. If they check ok, suspect the control board
Mar 23, 2013 | Onan Microquiet 3600 & 4000 Generator
Nov 08, 2012 | Heating & Cooling
Hello, I have the Goodman gas furnace that has an igniter. I will not light the flame. I was told that it was probably the board. So I went to a heat and air dealer and they sold me a new board, I...
Yes an igniter can go bad, unfortunately most furnace dealers will not return the board so you now have a spare. Pay attention to detail when changing the igniter out. Not knowing what style of igniter I can not give you tips on placement. The glowing type are very fragile they break when you look hard at them. The spark type it is important you have a clean direct spark at the pilot gas tube outlet and gapping the spark is critical. Ask your parts supplier for added tips they will know them all.
Dec 27, 2010 | Goodman GMS90703BXA Heater
We've checked voltage to all connections,but not getting gas to igniter
If this is electronic ignition then the ignition control board is probably bad. The ignition module sends voltage to the gas valve to open the pilot valve whil the board sparks to light the pilot.
Dec 30, 2009 | Heating & Cooling
Janitrol gup power vent ignition sequence
Sep 30, 2009 | Goodman Heating & Cooling
Pilot goes out afeter a few minutes
I bet you have a dirty pilot assmbley which caused the thermocouple to go bad. Remove the assembley clean it well (including the small oriface inside the assembley). then install a new thermocouple (probably 12-15 dollars) this should solve your problem.
Mar 25, 2009 | Dyna-Glo Double Tag-a-long Heater
Janitrol furnace wont ignite
it is probably a bad hot surface ignitor
Jan 29, 2009 | Kitchen Appliances - Others
Heating & Cooling Logo
51 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
