1989 Olds. delta 88 fuse box
In a couple slots in my fuse box i am missing the internal metal clamps that make the connection with the fuses. Can i replace these? If so how? Also, some of them only have 1 clamp instead of 2 how will that effect my car?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 100 Answers
Most fuse box have some empty slots like you describe, For example if your card had electric door locks, heated seats, electric seat adjustment they likely would have had to add the extra fuse holders but for a less decked out car you may not find them all junctional.
Posted on Nov 18, 2013
Where is the turn signal flasher in my fuse block on my 1985 Olds Delta 88?
THE TURN SIGNAL FLASHER IS LOCATED AT LOWER RIGHT CORNER OF FUSE BLOCK (OLD STYLE)
THE HAZARD FLASHER IS LOCATED AT UPPER CORNER OF FUSE BLOCK
Oct 12, 2017 | 1985 Oldsmobile Delta 88
1989 olds delta 88 turn signal
Check your turn signal switch arm. Could have faulty wiring/component there.
Nov 18, 2013 | Cars & Trucks
What is a Dig cluster on a 1989 delta 88 olds
it is the instrument cluster(your gauges and indicators) fuse
Apr 28, 2013 | Cars & Trucks
Which fuse is for the fuel pump on a 89olds delta 88
The fuel pump fuse is under the glove box inside the car.
Why is it blowing is the $100 question!
Here's a good one from left field- Check the Oil Pressure sending unit before going for the in tank pump.
They share the same power (fuse)
Go figure!
Feb 05, 2013 | 1988 Oldsmobile Delta 88
Olds 88 alternator fuse
You may find a blown fusible link or burnt wire/bad connection at the starter large terminal.I would start the car and check voltage output at the alternator output terminal first in case it's just a bad alternator.If you have 14+ volts at the alternator output terminal,you could also just run a 10 gauge wire from that terminal to battery positive directly and disconnect the alt feed to the starter terminal.
Mar 29, 2017 | 1989 Oldsmobile Delta 88
Where can i find the fuse box on a 1989 oldsmobile 88? it isn't under the drivers side dash.
most fuse boxes are under the hood,check there.....hope this helps....cheers
Jul 24, 2010 | 1989 Oldsmobile Delta 88
Where is the fuse box on a 1995 olds delta 88 royale
under dash on drivers side is small fuses. on firewall in middle for large fuses.
Feb 11, 2010 | 1995 Oldsmobile 88
I can not find the manifold absolute sensor on
Likely mounted between the valve covers and the carb/throttle body on the passinger side of engine.One vacum hose and a three wire harness.Two mounting screws.Probibly mounted on a metal bracket with several other things packed on as well.
Jan 15, 2010 | 1989 Oldsmobile Delta 88
Need to know which fuse?
there is a box under the hood on the right side near the windshield when facing the car, there are two plastic screws to undo to open the cover, on the inside of the cover are the placement of the fuse schematics
Aug 21, 2009 | 1988 Oldsmobile Delta 88
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
