Question about Dryers
Ge ddg7580gdlwh Last time my wife used the dryer, she saw a flash and then the circuit blew. We reset the circuit but now dryer is not heating or drying.
I would check the connections at the terminal block (where the dryer cord is installed on the machine, there will be a small access panel). The dryer cord is installed by the delivery guys, and those connections are frequently left too loose. That loose connection will eventually fail.
Posted on Nov 19, 2013
4 Suggested Answers
carlsbiz
  • 1124 Answers
SOURCE: Dryer takes a very long time to dry a load.
Some dryers have more than one heating elliment..
A way to check is -- take the exaust hose off.. Put a mirror so you can see into the hole & hopefully see the heating elliment(s).. When running they should glow like a stove burner..
If it is not gloing its not working & needs to be replaced..
I suspect that one may have went out..
I hope this helps !!
Please rate me good ;o)
Posted on Jul 12, 2009
  • 864 Answers
SOURCE: Reset GE Profile Harmony Dryer
Try here: http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
Posted on Sep 15, 2009
  • 101 Answers
SOURCE: GE dryer will not dry towels
How warm is "warm"? If the clothes are warm to hot after 15 minutes of running but not gettign dry, you do not have a heating element problem. Sounds like you still have an air flow problem. Does the heating element cycle often? You may have lint clogged at he entrance to the blower. This would be out of sight from the exhaust. Try removing the exhuast hose and running it in air-only and feel the amount of air leaving. It should feel like a lot of air coming out. If not, you will need to check the condition of the blower. I had this same issue and ended up pulling the blower cover off and pulled out a very large amount of lint..it was almost completely clogged. Afterwards it drys really fast! Good-Luck.
PS If you do not feel comfortable accessing the blower, you should have a professional do it for you.
Posted on Jan 24, 2010
Ge ddg7580gdlwh filter
Check the heating element...
Nov 18, 2013 | Dryers
Clean Lint Filter Light Keeps Dryer from starting
Evidently the fuse blew for some reason.
Keep the dryer unplugged from power for one hour or so. If it still does start, you will have to take apart the dryer, check the fuse, check the thermal fuse, and test the wirings inside.
If you need to call arepairman use the number listed on the owner manual.
Oct 06, 2008 | Frigidaire FGQ1442ES Gas Dryer
I have a GE profile performance wisard dryer. When I press on the start/pause, the light just blinks and the dryer does not turn on. I have turned the dryer completely off, unplugged it, checked the...
Take the cover off where the power enters the dryer and confirm that you have 240 volts there and the connections are tight. If yes, check for a broken belt or a drum safety thermostat. The last time I saw this, I found incorrect voltage present at the dryer. Checked the breaker and found that there was a bad connection from the breaker to the main buss bar in the circuit breaker panel.
Feb 05, 2011 | GE Dryers
GE Dryer PBSR353ET5WW.. I believe this unit is manufactured in Canada.. unit works, but does not heat up..
Check and clear the lint filters, and reset the circuit breaker. If your dryer still does not heat up, it is likely that the SWITCH controlling the heating element, OR the HEATING ELEMENT ITSELF is faulty and needs to be replaced.
Jun 07, 2010 | GE Profile Harmony DPGT750EC Electric...
Dryer made a cracking noise as wife attempted to turn on, dryer won't work as well as washer stopped at same time. have reset circuit braker no luck.
does the dryer use a 240 volt plug in there are two brakers one for heat and the other to run dryer look for two 60 amp brakers they may be at pannel or located out-side depending how old house is.
Dec 16, 2009 | Maytag Neptune MLE2000A Front Load Stacked...
2year old ge dryer trips breaker when it's turned on, but sometimes will run a complete cycle before it shuts off.
HELLO THERE
Electric dryers require the use of a 220 volt line. The dryer heating elements run off of 220 volts. An excessive draw of electricity, or a short in the wiring can blow a fuse or trip a breaker. This happens to protect sensitive components from damage, and to help prevent fires. Every other dryer component operates off of 110 volts, the timer, motor, etc. Usually when a fuse blows or a circuit trips, it's because there's to much draw on the power line.
It is very possible for one part of your dryer to work fine, and yet another to have a problem, such as a short circuit. A short circuit may be caused by the heating element, internal wiring, or the main power cord.
To troubleshoot this problem, unplug the dryer and check to see if the circuit breaker or fuse remains on when the dryer is unplugged. If they stay on, it's more than likely the problem is somewhere in the dryer.
If your fuse blows, or the circuit breaker trips when the dryer is unplugged, it's likely the problem is with the circuit breaker, fuse box, or house wiring; contact a professional electrician.
OK I hope this is very helpful for you
Best regards Michael
Dec 01, 2009 | GE DBSR453EBWW Electric Dryer
GE DVLR223 Not Heating--Is there a reset?
There is no reset. What he did was probably replace the thermal fuse. Why did he not clean it out for ya? Anyway when the thermal fuse goes bad either the whole dryer or the heat won't work. If you can open the dryer up by removing the front panel, you can test your thermal fuse for continuity. If none replace it. While you have the front off undo your belt and remove the 3 screws that secure the rear of the drum (inside drum in middle at back) pull drum out and make sure heat element is not broken. Here is a site for your dryer check it out. www.repairclinic.com/Appliance-Parts?s=t-dvlr223-%3d%3d&z=100 Good Luck
Jan 11, 2009 | GE DVLR223 Dryers
Loud Pop, blown Breaker
Pull the unit away from the wall and inspect from rear. However, if all is fine, perhaps you simply overloaded the circuit that once. Were you running any other appliances (overhead microwave) at the same time?
Mar 28, 2008 | GE 30 in. JP340 Electric Cooktop
Dryers Logo
55 people viewed this question
Top Dryers Experts
