My round thermostat from honeywell doesn't turn off my broiler when it reach the right temp but it turns on.
    Master:
  • 571 Answers
Sounds like yours adjusting a zone thermostat (slave) for a circulating pump...Make sure you don't have any other thermostats in the building.
Posted on Dec 12, 2013
Rth2520b Honeywell thermostat won't turn on
If known-good batteries were installed correctly, the thermostat may have failed.
Dec 23, 2013 | Honeywell Programmable Thermostat Heater
My round non-programmable digital thermostat doesn't seem to be communicating with the heater very well. I set it to 70 degrees and it clicks off before reaching that temperature. Any ideas?
It sounds like you may have a round Honeywell thermostat. It could be that the temperature pointer you see on the face of the thermostat just needs to be adjusted. The next time your furnace or AC finishes running, remove the face off the thermostat and use a small screwdriver to set the dial so the pointer temp matches the other temperature indicator.
Oct 29, 2013 | Honeywell Heating & Cooling
My honeywell Thermostat reaches the heating temp. but the fan will not stop running.And yes the fan is set to auto.It just keeps running and running and running.It stays the same temp but will not shut off...
I want to give a simple explanation before I go any further. On the heating side of a unit even though tthe temp has satisfied the thermostat, the fan will run until it cools down the plenum where the air flows from the air handler. There is a bimetal switch called a fan limit that operates the blower when the plenum reaches the temp set on the fan limit switch. Now if your fan keeps running even after the plenum chamber has cooled down, then you could have a fan limit switch that is stuck in the run position and must be replaced in order to correct the problem.
Dec 07, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
Temp is ten degrees lower than temp called for
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Feb 20, 2010 | Honeywell Programmable Thermostat Heater
How to use a round circular honeywell thermostat? I turned round casing to mark heat , no heat on??
If you turned the ring and the pointer moved, then you are using the thermostat correctly. Turn the thermostat up above room temperature (the temp on the bottom of the thermostat) Make sure all your switches are on, and that the fuse or circuit breaker is also on. If you still do not have heat after verifing all these things, then it is most likely a problem with the heating appliance.
Also, if it is a heating and cooling thermostat, make sure your lever is in the heating mode. Hope this helps
Sep 17, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Gas heater shuts off & won't come back on
sounds like the thermostat replaceing it should help you could try cleaning the old one they can get dust it them
Feb 25, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Oven does not maintain temp.
It sounds like a thermocouple problem. While using the broiler, you gave the gas set to full and the thermostat is basically out of the loop.
Feb 20, 2009 | Frigidaire FGF316 Gas Kitchen Range
HONEYWELL T-STAT
it is always advisable to shut down the main swith to avoid further issues in replacing thermostat, if you follow the right color coding this should be no prob, unless otherwise it cannot detect the right temp then it will not stop until it reaches and senses the right temp.
Dec 21, 2008 | Honeywell Programmable Thermostat Heater
Honeywell round mercury thermostat - heat not coming on
If you tip the mercury switch so that it makes contact and the furnace doesn't start, it isn't the t-stat. Check the connections, then start checking the furnace.
In any case, ditch the mercury t-stat (recycle it properly) and get a new programmable one if at all posible. It will pay for itself many times over by turning your heat down in the middle of the night and back up by morning.
Feb 09, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Thermostat ct87b
Your thermostat could be shutting off too soon. What you have to do is take the cover off of the thermostat and look at the bottom right side of the unit. There will be a Zinc plate with little dashs and numbers on it. on top of the plate is a copper triangle, that is what turns the heat off at a certain temp. The triangle is probably out of place and is cycling the heat off before it reaches your set temp. Just carefully adjust the triangle tward the lower left side of the triangle (alittle but at a time) and hopefully that will fix your problem.
Jan 21, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
