Question about Cobra Digital DC125 Digital Camera
Usb webcam 2.0 - Cobra Digital DC125 Digital Camera
My philips webcam (i have no clue what kind it is, but i bought it a few years ago) was working brilliantly until one day i go on msn to talk to friends i havent seen for a while, and it blurrs. i have NO...
1) Dirty lens
2) Some webcams have a focus ring around the lens that can be rotated to optimise clarity - others rely on the software to achieve the best focal length
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Click 'Next'
This takes you to the video setup
Set your webcam as default
Your webcam should be broadcasting
Use 'Webcam Settings' link to fine tune the picture.
Some webcams rely on a USB 2 (high speed or enhanced connection) On my laptop I have a mixture of 1.1 and 2.0 USB ports
If I use a USB 1.1 port the webcam quality is poor
3) Test your USB connection
1) Connect webcam and run MSN
2) Navigate to Device Manager
(XP) Right Click on "My Computer" and select "Properties".
In the "System Properties" window, click the "Hardware" tab.
Under the "Hardware" tab, click the "Device Manager" button.
(Vista) Right Click on "Computer" and select "Properties".
Select "Device Manager"
3) Confirm that your device is listed under the USB 2.0 Enhanced Controller
In "Device Manager" go to "View" and select "Devices by connection".
Expand "Advanced Configuration and Power Interface (ACPI)".
Expand "Microsoft ACPI-Compliant System".
Expand "PCI bus".
Locate and expand the "USB 2.0 Enhanced Controller" entry (see note).*
Expand "USB Root Hub" and verify that your camera is listed.
Note* Confirming your device is listed under the USB 2.0 Enhanced Controller' may produce a manufacturer listing that differes from the following example depending on the USB chipset that is included on your motherboard. The example shows "Intel" as the chipset manufacturer. When performing this step, please notice the keywords "USB 2.0 Enhanced Controller"
Dec 27, 2010 | Philips Computers & Internet
The picture in my logitech webcam is not clean but cloudy
Launch the logitech toolbar from your desktop or 'All Programs'
Start your webcam from the 'Quick Capture' menu and then move to the 'Settings' menu - try and trim the image from here.
1) Try rotating the focus ring around the lens to achieve the optimum clarity
2) Make sure you have DirectX installed
3) Check your USB ports are 2.0 ('enhanced' - on the USB info in Device Manager) My laptop has 4 USB ports
2 are 1.1 and 2 are 2.0. The difference it makes to my logitech is amazing
4) If all else fails - re-install your software
Jun 11, 2010 | Logitech Webcam
Hi there - my webcam is not recognised on my computer anymore - can you please direct me to a driver download that is not a zip file, and also - my laptop no longer reads my phone as a USB device nor does...
ok shanthi...goto control panel> device manager > check for the status of usb drivers.... you can double click on usb to check for the status....if your usb status is working properly then try to install the driver for your webcam...
if your usb status is not working, then first install the usb driver...
Apr 04, 2010 | ASUS F5R-AP038A Notebook
Can't Acess My Chicony U.S.B Webcam, no icon, ALWAYS WORKED
try to start the interface of webcam using :
1. start menu > programs > chicony webcam
2. open C: drive > program files > chicony webcam and double-click "chicony.exe" file
3. in the properties, check "show in task bar"
Dec 31, 2009 | Computers & Internet
I loss my enter web cam2.0 software
hello. what you need is called a driver and it is a free download from the net. just google webcam2.0driver. and do as it directs you.
Oct 02, 2009 | A D S USB Turbo 2.0 WebCam
How to check a usb 2.0 webcam
Plug in the web cam to a PC. If it is not a USB 2 devise then a balloon pop up will emerge showing that this devise can perform better and asking the user to update USB 2 driver.
Mar 25, 2009 | Computers & Internet
I have just purchased a web cam - labtec usb webcam - it is working but will not connect to msn, can you help
1. Verify your internet connection. If it is possible change your DNS IP Address.
2. Try Updating your MSN messenger >> http://www.microsoft.com/downloads/details.aspx?familyid=D78F2FF1-79EA-4066-8BA0-DDBED94864FC&displaylang=en
THE PROPER WAY ON INSTALLING USB DEVICES
A. Enable usb ports on the BIOS.
1. Do not plug in your device right away. Install all drivers and software first!
2. Reboot
3. Plug the power or turn on your USB Device
4. Plug in the USB Port.
5. Windows Will detect the Device Automatically.
Finish!
Hope this helps Please vote
Dec 31, 2008 | Labtec Webcam Plus 0403
Webcam crashes system
1. If the interface of the webcam to PC is via USB, use the USB ports at the back of the cpu
2. Try to close other applications in your computer when using webcam
3. If a webcam requires any driver or software for it to work, then try using the lastest software for it.
Nov 08, 2008 | Computers & Internet
Trying 2 connect 2 my webcam
plug in web cam to usb port install software acording to directions..
Sep 08, 2008 | Logitech Webcam
Help me
1:)Do you have installed driver?
2)The green light on webcam working???
Nov 01, 2007 | Radio Shack VGA PC Camera Webcam
Cobra Digital DC125 Digital Camera Logo
24 people viewed this question
Top Cobra Digital Cameras Experts
Daniel Dollive
Daniel Dollive
Greg Cann
Greg Cann
Are you a Cobra Digital Camera Expert? Answer questions, earn points and help others
