Question about GE Refrigerators
Need help to unclog a drain on a GE Profile Bottom Freezer Refrigerator Model PFSS6PKW/PFSF6PKW. Specifically, where does the drain end? Behind the freezer & how to access it? Also found eroding t
Need help to unclog a drain on a GE Profile Bottom Freezer Refrigerator Model PFSS6PKW/PFSF6PKW. Specifically, where does the drain end? Behind the freezer & how to access it? Also the top of my drain pan underneath the coils on the inside back wall had a metallic type tape over it that has eroded. It this tape necessary? If so, where do I get more to replace it? There is also quite a bit of rust stains near the drain area & around it. What is best to clean that off? I want to do whatever possible while I have the back panel off to clean it up. I would like to clean out the area where the drain ends if someone can tell me how to access that area. Unit was making slabs of ice under the deli tray while also draining water onto the floor on both sides of fridge. Had repairman come to home for $70. Said was clogged drain which I already knew from my own research. Now attempting to unclog it myself as he was going to charge $300 more to remove the back panel to run a snake and unclog it and they weren't going to get to it for 2 more weeks. So, I have gotten the back panel off inside the fridge, located top of the drain where the hole is in middle. Steamed about 3 cups of water and used a turkey baster to feed it into the drain hole opening. I don't have a snake or tubing that would fit so I took some weed trimmer line and fed it down thru the drain about three feet length twice. Where is this drain ending? I would like to check and clean that area if I can access it? And any help on what to do about the eroding tape on the drain pan and the rust removal? Any diagrams would be helpful. I have all the original product paperwork and there were no diagrams and nothing showing a drain pan or maintenance instructions. Thank you.
  • 1 more comment
  • Fix it Gal
    Fix it Gal Nov 18, 2013
    No. I do not see where it comes out. I'm attaching a picture. At bottom of this photo is...the top of the drain? This is a pic from the inside of the fridge back panel. You can see the metallic tape falling apart and the rust I mentioned. Is this draining into the bottom freezer section? Is that why I'm not able to find it. Going to try to take the drawers off now to see what's behind them if that's where it goes. Was hoping not to have to pull to much more off, with the parts. I read lots of reviews about the plastic parts being very fragile on these units. Thanks!
  • Brad Brown Nov 18, 2013
    The drain pan is actually under the unit! it is part #165 on this diagram:http://www.appliancepartspros.com/unit-p...
    The hose that you are trying to unplug is the evaporator drain hose that goes to the bottom of the unit.
  • GE Master
  • 15,729 Answers
You should be able to see where the drain tube comes out over the drain pan. Get some thin wire and run it down the tube and when it comes out in the drain pain, tie something onto it like a small piece of cloth and pull it back up through the drain tube to swab it out. The tape is no big issue, if you want to do something about the rust, there is a product that autoparts stores sell that turns rust into a hard, rigid metal. Or you can use a blow drier to make sure it is dried out and then spray rubber under coating on it.
Posted on Nov 18, 2013
  • Fix it Gal
fridgetech
  • 473 Answers
SOURCE: clogged fridge drain tube
The drain is behind the back panel in the freezer at the bottom. Sounds like it is frozen over which is pretty common. Will need to remove panel and thaw out drain by running hot water down. You can use a putty knife to break up ice first. Make sure you get all ice around the drain above and below the thin aluminum tray at the bottom. After the drain is free don't be alarmed if you get some water on the floor because the drain pan may not hold all of the water you ran down the drain. Not anything you can do to prevent this on this model.
Posted on Oct 07, 2007
tborn6
  • 700 Answers
SOURCE: Water on Floor Outside Freezer (Side by Side)
take a wire and run it through the drain until there is no resistance and then put hot water into it.
Posted on Mar 07, 2009
  • 358 Answers
SOURCE: water accumulating in bottom of freezer and leaking onto floor
Yes the drain is clogged and the water that supouse to go through became ice so it make it worse.Put hot water in the drain hole until it runs through,it'll go to an evaporative pan on top of the compresor to keep it warm and vaporize the water.
Posted on Apr 08, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
Posted on May 19, 2009
SOURCE: GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Posted on Jun 03, 2010
Ice maker freezes up
Replace temp sensor in freezer and main control board
Nov 06, 2013 | GE Refrigerators
Ge profile bottom freezer
i used a turkey baster to blast hot water through the drain to the pan took a few tries but it worked. sucked up all the old water first then gave it a good hard shot.
May 16, 2013 | Refrigerators
Pfss6pkw drain plugged
Unplug your refrigerator and remove items and shelves from the fresh food section. Not sure about what nutdriver so try a 1/4 inch nutdriver first and remove the screws holding panel number 98 in this photo HERE The beginning of the drain hole for the fresh food section is below the evaporator and in the center bottom of location number 96 in that same photo HERE For the freezer drain it will be behind panel 47 in this photo HERE You will only need the to remove the fresh food section panel ocation 98 and the freezer panel location 47 to clean these two drains. I have a video from You-Tube that shows where to clean out but his refrigerator had the drain visible without removel of these two panels. In most cases the drain cannot be seen without removal of the panels. I am here should you have questions Thanks Sea Breeze
May 16, 2013 | GE Profile Stainless Bottom-Freezer...
How do i remove the ice shoot on my ge profile model# pfss6pkw
pop the control panel off by taking a thin blade knife at the bottom of this panel and prying out on the two edged of it,then unplug the wire harnesses to it,then remove 4 phillips screws behind it remove the paddle assembly,dont lose the little spring on the paddle
Nov 04, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Good luck! :)
Vlad
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
The drain in the bottom of the freezer compartment seems to be clogged. It ices over an eventually and water drains out of the bottom of the door. It is a GE Profile. Is there a pan underneath that the...
You will need to remove the rear freezer wall I have a collection of photos I wish were mine but I do link them to their owners. So Follow me back to Sea Breeze Tip's and scroll to bottom of page where there are many ways people attempt a unclog the freezer drain. Sometimes it is slime build up that starts the cycle and sometimes the refrigerator is leaning a little enough to allow the water to pool on one side and creep as a frozen pool until the drains completely shut, One moment as I get the links Sea Breeze
Apr 10, 2010 | GE Profile PSW26P Stainless Steel Side by...
I have a PFSF6PKW Profile with bottom freezer. Our ice maker is making a clicking noise and not producing ice....???
look close and see if fingers are jammed with somthing, is there ice in it or is it emty (ice maker, not bin) and just rotating over and over.is the tube for water inlet plugged if it is buy a water valve.there are no parts for the icemaker you have to buy the hole thing $140.00 part # wr30x10097
Dec 20, 2009 | GE Profile Bottom-Freezer Refrigerator...
Refrigerators Logo
416 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
