Question about Briggs & Stratton Garden
Wont start most of the time
Briggs & Stratton 331777-1372-B2 engine how to replace spring for the compression release
  • 51 Answers
The decompression mechanism is located on the cam shaft, the engine would have to be opened up from the crank case, the whole decompression mechanism should be replaced...
Posted on Nov 18, 2013
mowerman1857
  • 389 Answers
SOURCE: timing for briggs and stratton 15.5 engine
There are no timing marks, timing is correct when the flywheel key is in place, the flywheel is properly torqued and the air gap for the magneto is properly set
Posted on Sep 29, 2009
huffman49
  • 235 Answers
SOURCE: Started using oil and smoking severely, all at once .
the best compression for a B&S is between 50 psi and 60 psi. if it's below 40 psi there is a problem with the rings or the tappet clearance (not letting the valves close all the way) but if it's smoking i would start with the rings...good luck
Posted on Apr 10, 2010
  • 23 Answers
SOURCE: engine wont start
go to youtube and type in valve adjustment on briggs,very simple procedure to do.
Posted on Apr 23, 2010
SOURCE: The recoil starter on my Briggs & Stratton not engaging flywheel
Andy, Hi, well I would start at the Starter myself, usually the thing called the "Bendix" spring jams up and stops it dead. Pull of the Starter, and power it up, off the unit. This will show you if it snaps in and out.
Sometimes a few judicious whacks with a soft hammer will sometimes free up the spring, if thats is indeed what's wrong. Anyway try that first. before any disassembly.
Make sure the Motor CAN actually be turned, by turning the flywheel, this should show you if the Motor is "Free" enough to move.
Also check ALL electrical connection to the starter. Use a meter and see if you are actually getting a voltage to the starter too. make sure your starter battery is good too.
Below is your support site, for any manuals or parts required. http://www.briggsandstratton.com/maint_repair/
Posted on Jul 21, 2010
The GR8 1
  • 7 Answers
SOURCE: Craftsman 42 inch deck mower.
That model number des not show up as a good number on the http://www.searspartsdirect.com site. Are you sure you have the belts on correctly? If it has 2 belts on the deck & 1 is not installed correctly they work against each other. Safely make sure that each blade will turn by hand. did you take the blades off? If they are too long by just a fraction, they will hit ach other, but that usually makes quiet a noise. Get your book out & systematically go over everything you touched or changed. It sounds like something really simple you have overlooked. you can go to http://www.searspartsdirect.com & enter a good model number & view all of the parts diagrams. Sometimes they are a big help, & at other times they just confuse you more:). Let me know what you find!!
Posted on Aug 13, 2010
I have a petrol golf cart wont start
Brian, If engine is of overhead valve type and engine turns over with plug out and will not crank when plug in or turns very slow, the problem is probable valve adjustment required or decompression release faulty on cam shaft. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.kohlerengines.com/maintenance/basicTroubleshooting.htm
briggs and stratton ohv hard start crank fix
How the compression release mechanism works on Briggs and Stratton OHV...
HOW TO ADJUST VALVES FIX HARD TO START Lawn Tractor with OHV Briggs Engine...
Aug 16, 2016 | Cars & Trucks
Replacing ohv cam on 17.5 briggs model 31c707-1346-b2
if you dont know take it to a proffessional if you make the slightest mistake you can bend valves or even worse break a piston
Oct 20, 2012 | Briggs & Stratton Briggs Stratton Intek V...
17.5 hp briggs and stratton mower - mowing fine - stopped to gas up - will not start back up - back fires a few times while turning motor over
sounds like you may have a broken valve spring. Do a compression test as you crank it. If the valve spring is broken, you will get nearly zero compression, it will turn over very easily and this would explain a couple of backfires.
Sep 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
How to remove valve from briggs and stratton modle #190702 how to remove clip, photos please
you need a valve spring compresser dont try useing two screw drivers to remove the clip use the valve spring compresser it so much easier
Jun 28, 2011 | Briggs & Stratton Briggs Stratton...
18 hp vanguard 165lbs and 180 lbs compression have to hand turn engine past compression or starter wont turn engine over
if its hard to get the engine to turn past the compression release then pull your valve coversand try setting your valve lash
.006 on intake
.008 on exhaust
Oct 25, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Engine will not crank with every try.
Still sounds like a valve adjustment problem and as for relying on a Sears serviceman.....well. lol I just did a valve readjust on basically the same engine with identical symtoms and it starts fine now. As for the 10w-30, Briggs recommends 30w in the warmer climates.
May 28, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Engine drags while trying to start
It may be a problem with the camshaft-compression release. Some of the Briggs & Stratton models had a weak spring on the compression release whis is parts of the camshaft. you may also want tocheck that all wires are clean and tight. Also if it's a over head valve model check the valve clearance.
Jan 26, 2009 | Garden
Garden Logo
107 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
