Question about Archos AV700 Digital Media Player
Factory reset restore
How do I restore to factory settings?
I don't know my password to Ipad need to hard reset
Can only be done via a computer that has iTunes on it. Log in with Apple ID, back up the device and then Reset.
If you know the password it can be reset via Settings.
Mar 23, 2017 | Tablets & eReaders
IPhone 5c. How can I restore?
Restore your device
Connect your device to your computer using the cable that came with it.
Select your iPhone, iPad, or iPod when it appears in iTunes.
In the Summary panel, click Restore.
Click Restore again to confirm that you want to restore your device to factory settings and delete all data and content.
Feedback
iPhone 5c - How to Reset Back to Factory Settings - YouTube
z? 5:22 https://www.youtube.com/watch?v=__ujKpff2B4 Sep 29, 2013 - Uploaded by H2TechVideos For More Videos, Check Out My Website at http://H2TechVideos.com NEED HELP GROWING YOUR YOUTUBE ... gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==
How to perform a hard reset when my Apple iPhone 5c is ...
support.bell.ca/.../Apple-iPhone-5c.how_to_perform_a_hard_reset_whe... iPhone 5c - 8 GB (iOS 7) Insert the USB cable, then hold the Home key while connecting the iPhone to iTunes. On the computer, when prompted that iTunes has detected the iPhone in recovery mode, click OK. gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==gif;base64,r0lgodlhaqabaaaaach5baekaaealaaaaaabaaeaaaictaeaow==
Use iTunes to restore your iPhone, iPad, or iPod to factory ...
https://support.apple.com/en-ca/HT201252 Oct 21, 2015 - Restore your device. Connect your device to your computer using the cable that came with it. Select your iPhone, iPad, or iPod when it appears in iTunes. In the Summary panel, click Restore. Click Restore again to confirm that you want to restore your device to factory settings and delete all data and content.
How to Factory Reset an iPhone (Any Generation) ' Digital ...
www.digitaltrends.com > Mobile Dec 15, 2015 - How to factory reset an iPhone with or without using iTunes, no matter what generation it is.
Apple iPhone 5c hard reset
www.hard-reset.com > APPLE hard reset Reset iPhone 5c: Press and hold the On/Off Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears.
Perform a factory reset - Apple iPhone 5c 16GB Certified Pre ...
support.sprint.com/...factory-reset...iPhone-5c.../WScenario_542_50265... Perform a factory reset - Apple iPhone 5c 16GB Certified Pre-owned. Last updated: Oct 01, 2015. article View all tutorials. Did this solve your problem? Explore ...
Videos
Feedback
Feb 01, 2016 | Apple iPhone Smartphone
How to delete previous owner WiFi data and security code
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Mar 26, 2015 | HP LaserJet 4500 Printer
Mfc7340 where is factory reset
Restoring all settings to the factory settings, you can restore all the settings you have changed to the factory settings. These settings will stay until you change them again.1 Press Print Setting.2 Press a or b to display Factory Reset.3 Press Factory Reset. 4Press Yes to confirm.5 Press Stop/Exit.
Jun 10, 2014 | Office Equipment & Supplies
Cod resoftare nokia 7100s2
Restore to factory settings
To restore the phone back to factory conditions, select Menu > Settings > Rest. factory sett. and from the following options:
Restore settings only -0 to reset all preference settings without deleting any personal data
Restore all - to reset all preference settings and delete all personal data, such as contacts, messages, media files and activation keys
Apr 17, 2014 | Philips Televison & Video
Reset factory settings on hp deskjet 1050
Reset the Printer to Factory Default Settings Restore factory settings Restoring the factory-set defaults returns most of the settings to the factory defaults. It will not reset the page count, tray size, or language. To restore the product to the factory-default settings, follow these steps.
  1. Turn the product off. Disconnect the power cable from the product for 30 seconds and then reconnect.
  2. Turn the product on while you press and hold the Resume c02469297.gif button for 10-20 seconds. The Attention c02469293.gif light turns on.
  3. Release the Resume c02469297.gif button. The Attention c02469293.gif and Ready c02469296.gif lights cycle while the product restores factory defaults.
Reset HP 1050 DeskJet Series Cartridge
Jun 07, 2012 | HP Office Equipment & Supplies
How can i reset Encore enRTR-104 router to default factory settings? When i push the reset button after few seconds begin the light nr. 4 faster to blink. When i release the button - the reset is done in...
I found these instructions for resetting the router to the defualt settings:
Use the "Backup Settings" tool to save the Broadband Router's current configuration to a file named "config.bin" on your PC. You can then use the "Restore Settings" tool to restore the saved configuration of the Broadband Router that you set before. Alternately, you can use the "Restore to Factory Defaults" tool to force the Broadband Router to perform reset and restore the original factory settings.
􀁺 Restore Factory Default
To restore the factory default settings of the Broadband Router, click on the "Restore" button.
􀁺 Backup Settings
Press the "Backup Settings" button to save the current setting in a filed "config.bin" or given filename.
􀁺 Restore Settings
To restore the backup file to the Broadband Router, enter the path and filename on the restore settings.
You can find the manual here:
http://www.encore-usa.com/us/support/ENRTR-104
May 05, 2011 | Encore ENRTR-104 Router
I forgot my pasword, and i want to restore my factory setting on this phone been nokia 3600 slide so help me
Straight from the manual:
Restore factory settings To restore the phone back to factory conditions, select Menu > Settings > Rest. factory sett. and from the following options: 1. Restore settings only - to reset all preference settings without deleting any personal data 2. Restore all - to reset all preference settings and delete all personal data, such as contacts, messages, media files, and activation key
Best of luck!
Mar 15, 2011 | Computers & Internet
Forgot password to acess< and or its still default setting. could you tell me what the wireless 700 routers default password is
Restore Factory Default Settings When you restore factory default settings to the base station, you clear your Internet connection settings and any special base station configurations that you have established. After the restore is complete, you will need to reconfigure your base station settings or restore these settings from a backup file. You should restore the original factory default settings only under the following circumstances: O You are experiencing serious problems with your base station, and resetting the base station does not fix the problem. O You cannot remember your base station password. In this situation, you must restore the factory default settings by using the Restore button on the base station, and then use the default password admin to log on to the Base Station Management Tool. To restore factory default settings 1. Open the Base Station Management Tool, and then click Management. 2. On the Management menu, click Back Up and Restore Settings. 3. Under Restore factory default settings, click Restore Factory Default Settings. While the original factory default settings are being restored to the base station, the Power light on the base station turns orange. When the light is solid green, the settings have been restored. If you want to open the Base Station Management Tool after the settings have been restored, type admin as the password on the Logon page. Do not attempt to log on to the base station until the settings are restored and the Power light on the base station is solid green. After you restore the factory default settings to the base station, you should navigate to each page of the Base Station Management Tool and reestablish the network settings you want, or restore the base station settings by using a backup file. For information about creating a backup file of your settings, see the following section. Be sure to establish your unique base station password as soon as possible after restoring the factory default settings to prevent unauthorized users from logging on. For more information, see “Change the Base Station Password.” please rate this answer, thanks
Jan 30, 2009 | Microsoft MN-700 Wireless Router
Archos AV700 Digital Media Player Logo
49 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
