Question about Zebra MZ 220 Thermal Printer
Labels are skipping on my zebra mz 400 printer
SOURCE: label printer
Try reseting the auto gap detection.
http://www.fixya.com/support/p257130-zebra_lp_2844_thermal_printer/manual-19245/page-15
Posted on Mar 30, 2008
  • 5 Answers
SOURCE: Printer = Zebra TLP 2844-Z Problem = will not calibrate
just switch off the printer ,and then hold the green button power on the printer now and wait upto 4 bliknks of green led then remove the fingers.now printer will calibrate the label..
if still the problem exist .check the notch in the ribbon core.an adjust the spring tenson of rippon supply and take of roolers in printer
Posted on Dec 05, 2008
SOURCE: Zebra LP2844 printer prints garbage
Sounds like you might be using a bad driver, or the printer is in dump mode.
Try hitting the green button and see if it says exiting dump.
If still having trouble, inside the printer it tells you that if you are having printing trouble:
  1. turn off the printer
  2. Hold down the feed button
  3. turn on the printer and at the third red flash release the feed button
  4. it will then feed some pagessome info and ask you to hit feed again to exit dump
  5. hit feed again and it will say exiting dump
This process re-reads the label length (so only do it with the labels you want to use in, or it will waste labels until you do it again with those in it) - but I'm suggesting it only because it enters and exits dump mode (which I have read can cause the garbage when you try to print).
Posted on Mar 11, 2009
  • 185 Answers
SOURCE: I am having problems with Zebra printer MDL#ZM400
Try entering the Menu system and exiting, whilst exiting and instead of saving permanent, cycle around to load defaults. once you have done that make sure the settings are as you need such as Thermal Transfer etc and save permanent. You won't have a problem after that. If you do I would be checking the page setup in the software to make sure it fits the lables.
Posted on Jan 25, 2010
  • 31 Answers
SOURCE: Zebra 2746e will skip leaving a blank label while printing.
You need to calibrate. Hold down the feed key while powering the printer on, then let go. The printer will calibrate, print a config label, then fo into dump mode. Press the fee key again to go out of dump. Of your issue persists, there could be a problem with yoru media, or with the commands that you are sending to the printer.
Posted on Jan 31, 2010
Advancing blank labels inbetween printing
Do you use adhesive labels? It looks like the printer is unable to make the difference betwen the labels. Verify that the printer it's not set on Continuous mode for the media type. Verify if there is any label (or pice of label) stiked on the upper media sensor (gap sensor). You can locate the upper media sensor using the User Manual (page 74). There is an User Manual available for download from Zebra website. You will find there precious information. The manual is very explicit and you will learn how to maintain your printer and how to troubleshoot some common errors. Clean your printer, assure to put the supplies on the right path, close the printhead and press Pause to enter in Ready state.
You can clean the sensor with an coton cloth dampened into isopropylic alcohol.
Here is the link to user manual:
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/105sl-ug-en.pdf
Dec 03, 2013 | Zebra 105Se Thermal Printer
Skipping labels
Nov 27, 2013 | Zebra 105Se Thermal Printer
2 partial labels being printed on 1 label
most likely to do with sensor --- label has a notch in it it in middle make sure it is clean --- do labels have a hole that align with sensor?
Look at Cleaning printer to locate sensor
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/ql-qlp-qrg-en.pdf
Mar 18, 2013 | Zebra QL420 Plus Portable Thermal Barcode...
Hi there, I am printing on Zebra S600 using Seagull Scientific Driver, The printer only prints every alternate label that is prints one label and prints a blank. Thank you for your help
Skipping labels is usually a printer driver issue. You should use Seagull Scientific printer driver only if you are using the corresponding Seagull Scientific label design software. It is important to have the printer driver and label design software be from the same manufacturer.
Jul 01, 2011 | Zebra Stripe S600 Thermal Label Printer
ZEBRA z4MPLUS LABEL PRINTER
Do Media and Ribbon Calibration . in printer parameters
Jun 29, 2010 | Zebra Z4Mplus Label Printer
My Zebra Z4Mplus printer is skipping labels when I print
check the label margins, and label dimensions, and spacing , normaly is these problem, or is a printer driver problem, try reinstall driver
Jan 13, 2010 | Zebra Z4Mplus Label Printer
Settings seem correct, but labels will print on 2 labels, or skip labels. Zebra s4m
The printer is not calibrated to the media length. You need to perfrom a calibration with the labels loaded. This is in the users manual on how to do it. The printer should be set to automatically do this when powered up.
Oct 20, 2009 | Zebra S4M Thermal Label Printer
Zebra stripe s500 skips 5 labels prints 1 skips 1
He are the steps you need to calibrate your printer
Label Length Calibration
Note: This is typically the only procedure required when first installing the labels.
1. Load the printer with media and ribbon.
2. Press the printer front panel MODE key until the CALIBRATE LED is lit.
3. Press the FEED key and allow the labels to feed.
4. When the labels have stopped press the MODE key once to save the value in memory.
Jul 10, 2009 | Zebra Stripe S500 Thermal Label Printer
May 28, 2009 | Zebra 2746e Thermal Printer
An extra, blank label prints from a Zebra 2746e.
Check media settings in the printer driver. Check version of printer driver. Zebra printersuse an internal printer driver with their Zebra Designer software (Zdesigner driver) or a ZUD (Zebra Universal Driver) for other windows applications. These drivers can be downloaded directly from the zebra website.
Alternatively you can download the seagull scientific driver and use that instead. (used with bartender program)
Label skipping occurs if the media dimensions are not specified correctly. The important ones are label height, and media setting for type of media.
Perform a media calibration before you go changing settings. Power on printer, Hold top and bottom buttons in on control panel for 5 seconds, release bottom button only then when printer starts feeding labels release top button. When printer finishes press feed button.
Mar 16, 2009 | Zebra 2746e Thermal Printer
Zebra MZ 220 Thermal Printer Logo
27 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
