Question about HP LaserJet 3050 All-In-One Printer
How to clear print head nozzal on epson l 200 series printer
    New Friend:
  • 87 Answers
Use ultrasonic head cleaner. Its effective and clean.
Posted on Nov 19, 2013
Print head doesn;t move at all in epson stylus tx100
Anon, epson stylus tx100 print head doesn't move when turned on.
epson printer problems
Feb 08, 2014 | Epson TX100 Series
Www kodak com go itg
check follows :-
print Black Cartridge nozzals, if jam Replace black cart.
Head carriage assembly or replace
Nov 03, 2013 | HP Officejet 5610 All-In-One InkJet...
Why doesn't my black ink work in my Epson WorkForce 600 series after replacing the black ink cartridge?
The Epson printer may only use genuine ink cartridges which contain a chip so that you cannot fill the cartridge with ink or use non genuine ink cartridges.
OR
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 01, 2013 | Office Equipment & Supplies
BLACK INK NOT PRINTING
Hi Hmmg,
This is a clear indication that some thing is gone wrong in your printer's circuit. Please get it checked by an authorized service engineer.
Regards.
Nat
Jun 29, 2012 | Epson Stylus CX9300F Series
Epson SX515W black ink jet blocked. Anyway to clear it myself?
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, thenprint head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jul 20, 2011 | Epson Stylus Multifunction Inkjet Printer/...
My Lexmark printer 1270 only prints in black and white although the colour cartriges have good ink levals. This has just started happening, it was happily printing in colour not long ago. Many thanks.
Jast go to print option. Then Mantainance. Then try to print a nozzale. If all the colour comes out properly ( with out dot or misline), your cartrige head is goog for print. If not, your printer cartrige head is block. To reque from the problem follow the proces:
1. Unpluge colour cartrige.
2. Try to clean the cartrige head with soft cloth and amonia gentaly.
3. Try to out the ink through the head nozzale pore by using shaking or gentaly swape by soft tissue.
4. Now put the cratrige head upon a soft tissue. ( ink will comes out). If not, repit stage 1-4 until ink come out.
Thank you
Jun 07, 2011 | Lexmark X1270 All-In-One InkJet Printer
PLSE HELP IM TRYING TO PRINT BUT NOTHINGS HAPPENING, IT IS ALL SET UP
test the printer first, so that we can isolate the issue. print a nozzle check to eliminate the possibility that the nozzles are clogged by dried inks. if nozzle check prints blank page or it printedr but w/ gaps or breaks, do head cleaning
Check the Print Head Nozzles: 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus CX4400 Series. 3. Hold down the cx4400_ug.1.79.1.jpg Stop button as you press the cx4400_ug.1.79.2.jpg On button to turn the Epson Stylus CX4400 Series back on. Hold down both buttons until the cx4400_ug.1.79.3.jpg On light begins to flash, then release the buttons. cx4400_ug.1.79.4.jpg 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. cx4400_ug.1.79.5.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. Clean the Print Head Nozzles: 1. Load a few sheets of plain paper in the sheet feeder. 2. Hold down the cx4400_ug.1.80.1.jpg Stop button for at least 4 seconds to start the cleaning cycle, which lasts around 1 minute. cx4400_ug.1.80.2.jpg The cx4400_ug.1.80.3.jpg On light flashes throughout the cleaning cycle and stays on green when the cycle is finished. Caution:
Never turn off the Epson Stylus CX4400 Series during a cleaning cycle or you may damage it. 3. Run a nozzle check to confirm that the print head is clean. You may need to clean the print head up to 2 times. You can also turn the Epson Stylus CX4400 Series off and wait at least 6 hours. Then try printing again.
Feb 15, 2010 | Epson Stylus DX4450 All-In-One InkJet...
Does not print
***hi there,il be willing to help you on that. ****
the nozzles of the printer might be clogged by dried inks thats why when your printing, its feeding the paper, as if its printing but no inks on the paper. print a nozzle check to see which part or color have clogs, if there are gaps or breaks, do head cleaning untill no more gaps then try printing.
Running a Printer Check
1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. nx100_tx100_ug.1.96.5.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. If your printouts are unexpectedly light, or dots or lines are missing, you may need to clean the print head. This unclogs the nozzles so they can deliver ink properly. Print head cleaning uses ink, so clean it only if quality declines.
You can also clean the print head by holding down the stop button on the printer for three seconds. (This only works when the red ink light is off.) Run a nozzle check to confirm that the print head is clean.
Caution: When you don’t turn on your printer for a long time, print quality can decline, so turn it on and print a few pages at least once a month to maintain good print quality. ***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Jan 10, 2010 | Epson Stylus NX100 InkJet Printer
EPSON 1400 PRINT HEAD
Printheads on that EPSON...as almost all Epson brand printers are IMPOSIBLE to change. Are made for waste containers! It's trgough. If you can change head on that, maybe in a bit less than 200 hours! It's NOT a joke! Better, i nought a K8400 HP large format...It's 4 seconds to change heads. Also, they are cheap price and LAST very very long...but NEVER let any inkjet printer without printing all 4 colors for a minimum of 1 page in 3 weeks. Heads would dry. If you care you'll print with the K8400 for about 100,000 pages.
Nov 30, 2008 | Epson Stylus 1400 InkJet Photo Printer
HP LaserJet 3050 All-In-One Printer Logo
26 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
