Question about Belling DB3 Dual Fuel (Electric and Gas) Kitchen Range
Cooker and timer broken
Our oven within out family home often gets knocked, and a couple times before the timer has fallen into the cooker, unfortuneatley i trusted an unskilled friend to fix it, yet instead he arced it and it reesulted in the circuit board 'blowing' andi am looking everywhere to get a new one, and even went to maplin to get all the parts to fix it, yet it has been unsuccessful
Can i by pass the clock or timer to be able to use the main oven they are worked by electricty
Cooker dead or oven not working or clock flashing - YouTube
? 3:05
https://www.youtube.com/watch?v=FDz4UpFMXq0
Dec 20, 2011 - Uploaded by Richard Saupe
Can be quite a problem when your cooker or oven is dead and always ... want to use it. watch this video on tips to re set theclock and get it up and ru. ... I try to set time I'm after a video clip on how to change the timer any help .
My Rangemaster 110 oven will not light, the timer/clock is ...
www.howtomendit.com > Kitchen Appliances, Gas Cookers
Free repair help - rangemaster 110 oven will not light timerclock broken too. ... I turned off mains electric then took out the 5 screws .... all I was interested in was bypassingthe timer and not fixing the timer -like others ..... Like I say, you will have no clockfunction but will be able to use the oven in the way it was meant to work.
Nov 24, 2015 | Kitchen Ranges
HOW DO YOU SET THE CLOCK? I CAN'T GET THE OVENS TO WORK
If the clock is showing time you may have accidently knocked the auto button this will shut off the power to both ovens until the timer times out you must press the manual button it usually has a little hand printed on it. If you do not have any lights on the clock or oven it may be due to
1. a blown fuse or tripped power supply
2.Thermal cut out tripped or failure
3.A broken live or neutral wire isolate the power before doing any continuity tests.
4. A faulty timer.
Apr 30, 2015 | Ovens Ovens
Rice Cooker Timer
I had one, it's just takes practice, time the batch and use a measuring cup, this will help you get dialed in to being the master rice cooker, that hides within you Grasshopper !
Jay the pool pump motor repair guy Longwood Florida
Feb 08, 2014 | Kenmore Digital Rice Cooker
Turn on oven cleaning, but clean indicator stops after few seconds
hello
what this need is to set the reprograms
here are solution below
You can set the timer on a Corning ware slow cooker to automatically switch to a warming setting when you estimate Foods will finish Cooking The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the Work, and come home to a fully cooked meal.
  • Fill the insert of the Corning ware slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  • 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
  • hope this hope ?
    thanks
    Oct 03, 2010 | Ovens
    Resetting the clock
    You can set the timer on a single oven slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking.The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
    INSTRUCTION BELOW.
  • Fill the insert of the single oven slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • Please rate this solution after use.
    Thank you and thanks for using fixya.
    Oct 03, 2010 | Maytag CWG3100A Gas Single Oven
    The clock on the stove was flashing and now I can't get time set and the oven buttons don't work to put on broiler or oven. I don't know how this happened or how to correct it
    hello,
    You can set the timer on a range slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking. The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a range slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
    Fill the insert of the range slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
    Aug 18, 2010 | Tappan TGF657 Gas Kitchen Range
    I didnt get a user manual with my creda cooker dont know how to set the timer
    try this site for your manual
    kitchen.manualsonline.com/manuals/.../creda/creda_oven_product_list.html
    hope this helps
    Apr 28, 2010 | Ovens
    Stoves Newhome GL916
    The timer has broken and needs replacing
    I had the same problem, we checked all the wires inside and all ok, so phoned stoves and they said that the it sounds like the timer as this is the first port
    Replaced the timer and cooker is now working fine - only thing to remember when ordering the timer - my cooker is green and now has a red light instead of green
    Hope this helps
    Cost of timer from stoves £56.83 inc vat and delivery
    Oct 28, 2007 | Ovens
    Lofra MXD96AMFE/C Dual Fuel Range Cooker
    Hi
    The timer on our Lofra MXUD76MFE broke about 2 months after the 12 month warranty ran out.
    Being a bit of a fiddler i took the top off the cooker to access the timer (not that difficult) when i ispected the timer i was astonished that it had lasted the 14 months it had such was the quality of it.
    The timer was easy to set to ensure the cooker worked but unserviceable to restore the timer mechanism.
    I thought given that it was such a cheap looking part (even allowing for the exorbitant price of parts) it would be worth replacing.
    Came across the new appointed distributor - Premier Appliance Brands - based in Warrington (01925 248980)
    They gave me a part No of 03010631 but didn't have stock and initially could not give me a price. i left it a couple of weeks and rang back this week.
    They quoted £77 - needless to say i didn't order it
    Oct 23, 2007 | Kitchen Ranges
    Belling DB3 Dual Fuel (Electric and Gas) Kitchen Range Logo
    15 people viewed this question
    Top Belling Kitchen Ranges Experts
    paulcarew
    John Tripp
    John Tripp
    Mike Carew
    Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
