Question about Marathon Car Audio & Video
My marathon ma-3000 professional power amp wont turn on
    Problem Solver:
  • 11 Answers
MAKE SURE TO CHECK YOUR REMOTE LINE, MIGHT BE BROKE SOMEWHERE. IF NOT CHECK THE CONNECTION.
Posted on Nov 20, 2013
Motor red error light comes on, pump won't turn on
if power to motor bad pump motor if no voltage to motor bad relay
Mar 01, 2015 | Marathon Electric Marathon imPower...
I cant get the water temp below 125 and I need to for our day care. I have the lower thermostat set to 110 and it still is 125 to 130 degrees. Is there something else I need to do. There is a upper...
You have marathon water heater?
Thermostat is probably bad. Has gone out of calibration.
Replace both upper and lower thermostats for $25 from local hardware store, takes about 20 minutes, turn off power, take photo of wires before starting. These thermostats can be adjusted all the way down to 90 degrees, and then dial up a bit to reach 110.
Copy following link for instructions how to replace thermostat yourself.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If problem continues, then replace both elements.
Elements are special order made specifically for marathon.
Requires 1-7/8" socket to remove elements.
Upper 3800 watt, order part SP610130
Lower 3800 watt, order part SP210197
http://hometips.me/Mar/Rheem-Marathon-parts-2.pdf
http://waterheatertimer.org/How-to-replace-water-heater-element.html
More information about Marathon:
http://waterheatertimer.org/Review-Rheem-Marathon-water-heater.html
Gene
h
Aug 26, 2013 | Rheem MR105245 Marathon Electric Water...
Rheem marathon tripping breaker
Turn power off. Open covers and inspect for burned parts.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
Test elements. Marathon takes specific element, and does not use generic element from hardware store.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Oct 27, 2012 | Rheem MSR50245 Marathon Electric Water...
What model ma audio amp i have
HelloYour MA amp {M600XE} is a two channel car amp having 700WRMS output power. OK.
Dec 19, 2011 | MA Audio M600XE Car Amp
Wont power on
Ssometimes the antenna wire is not enough to turn on the amp , some cars use relays in thier power antenna turn on set up which require low 500 ma 's . hit the amps turn on post with 12 volts directly from a jumper wire with alligator clips from main poower wire , if it still wont tunr on the amp the amp may be faulty , also check amps ground , metal its grounded must be free of paint , undercoating rug ect ....
Nov 17, 2009 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Setting up my bands new pa!!!
You can work forwards from the mic to the speakers, or backwards from the speakers back to the mic.
The mixer and the amp both should have lights to indicate when there is signal present -- if you don't have lights at the mixer, then you won't have any sound downstream at the speakers. In this case, the problem is with the mixer or the sound source (mic or instrument)
If you *do* have lights at the amp, then the signal is getting that far, and the problem must be with the amp or the speakers.
Jun 02, 2009 | Marathon DJ-2000 Amplifier
What does parallel mean on my marathon 3050 power amp?
parallel mean that you connect speakers wire together to amp(positive side with positive side and negative side with negative side)in this situation you got less resistance from speakers and more current.
i mean more sound level.
Apr 11, 2009 | Marathon DJ-2000 Amplifier
Marathon 2000 amp... PROT light
Ok this means the AMP is in protection mode!..most likely the cause is a short in your wireing from the speaker wires! check all wires going in and out of amp! Look for stray wires touching metal or other contacts! (If this does not fix it the short may be inside of amp!
(This has nothing to do with a fuse!)
Please rate this FREE response!
THANK YOU!
Jan 19, 2009 | Marathon DJ-2000 Amplifier
Amp ???
Ever find a solution? i am having the exact same problem... didnt happen until i plugged in the bass remote they send with it...
Dec 28, 2006 | MA Audio HK4000D Car Audio Amplifier
Car Audio & Video Logo
37 people viewed this question
Top Marathon Car Audio & Video Experts
xxxxxx xxx
Are you a Marathon Car Audio and Video Expert? Answer questions, earn points and help others
