Question about Vehicle Parts & Accessories
Why does My ford fiesta heater switch only work on setting 4
Heating is only warm
  • 26 Answers
Odds are it is the blower motor resistor usually located somewhere in or under the dash inside your car. If you are friendly with your Ford dealer service counter guy he will look up where it goes for you. It is not labour intensive so the dealer should do it for a minimal charge if you don't want to be bothered..
Posted on Nov 19, 2013
Ford fiesta heating intermitant
Check your thermostat and or your heater core then get back with me
Jan 12, 2014 | Cars & Trucks
Ford fiesta heater blower
Bad resistor or faulty heater blower motor.
Dec 08, 2013 | Cars & Trucks
Ford fiesta heaters blow cold i rev the car and get warm why is this
The Ford Fiesta certainly isn't the most affordable small car, but especially if you consider the Fiesta's stylish appearance and surprisingly stout feature lists, it's one of the better ways to downsize-without feeling like you're moving downscale, that is.-----------------------------------------------------------------------------------------
Car Diagnostic Tools
Nov 20, 2012 | Ford Cars & Trucks
Heating not working in ford fiesta 1.2 encore
A couple of problems may exist.
First, the heater core could be clogged.
Or, the flap that opens up the flow of air through the heater core to the
vents or floor or defrost is not functioning as required.
Jul 13, 2010 | 1998 Ford F150 Regular Cab
Heaters blow cold
could be heater core failure.
If the temp guage remains cold....the thermostat is stuck open, therefore coolant is running thru the motor always. Therefore, no heat anywhere, and poor gas mileage.
Apr 01, 2010 | 1993 Ford Festiva
1997 FORD FIESTA HEATER FAN ONLY WORKING ON SETTING 4 SETTINGS 1/2/3 NO WORKING AT ALL
You need to look underneath the dash. Find the wires (4 of them) that goes into the blower box. They are very thin and corrode with time. You might even see some melted plastic bits as these wires are too thin and overheat.
Feb 09, 2010 | Heating & Cooling
My 1999 fiesta blowers will only work if set on number 4 it blows hot and cold (it is a fiesta but the website didnt give me the option for it)
Hi you need a new heater control panel, you may be able to repair that one but will have to take it out to see.
here is some on ebay http://shop.ebay.co.uk/?_from=R40&_trksid=p3984.m38.l1313&_nkw=ford+fiesta+heater+control+panel&_sacat=See-All-Categories not sure what trim your car has so look to find the best match.
they are very easy to fit, let me know if you need more info
Regards
Dan
Feb 03, 2010 | 1999 Ford Escort
Heating`not`working`on`my`ford`fiesta`02`model
Sounds like the heater control valve/ blend door. The actuator may be stuck or broken. The actuator opens and closes to adjust for the heat setting in the car. You might be able to take a coathanger and manually open the door if you can get to the control arm. They are usually hard to get to and pretty expensive. It is located under the dash at the heater core box. Good luck.
Dec 18, 2009 | 2003 Ford Freestyle
Heater blowing hot all the time turning control valve switch makes no diferance any solution ford fiesta 1997
Change the heater contol switch.They are a big problem with the fords.Fiesta and Ka.
Jul 13, 2009 | Ford Focus Cars & Trucks
Heater only works on number 4 in MK6 fiesta
needs a newfan switch. contacts are corroded on inside of switch. self contained. it will have to be replaced no fix there. hope this helps
Oct 28, 2008 | Ford Fusion Cars & Trucks
Vehicle Parts & Accessories Logo
113 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
