Question about Hoisting
The piston will not go down - Hoisting
F28WW-fire gun. piston doesn't retract back, trigger is good gun is clean & oiled what could be the problem. nailer year old
Check band # 175520 (black rubber band around the outside of the cylinder) is what causes the piston to retract. If the check band is in place, then problem could be caused by cracked lower bumper, worn piston oring or cylinder seal on the headvalve. IF the cylinder seal is bad, air will leak between seal and the top of the cylinder and could push piston down cylinder. If piston oring is too loose, the piston will not stay at the top of the cylinder. If you point the nose of the gun up then down again and the driver moves within the cylinder, replace the oring. Good luck
Apr 04, 2013 | Stanley Bostitch Stick Framing Nailer...
1971 ducati 350 scrambler how do u set the timeing
Set the piston to TDC (top dead center) this is the higest point the piston will rise before moving on to the down stroke, either by lining up the marks on the crank rotor or a long screw driver (large handle so it wont fall in) down the plug hole and watch for the highest point lock or hold at this point. The cams should be fitted next on the 'compression' stroke meaing the all valves should be closed when the cams are seated (no valves being pressed by cams) generally at this point the cam lobs face away from the valves, next stroke down (ignition of fuel) valves should be closed with the exhaust cam moving round ready to rock on to the exhaust valve as the piston rises to the top again (4th stroke exhaust) as the exhaust valve lobe rocks off the intake cam lobe should be starting to rock on opening the intake valve on the down stroke of the pistion.
Trun the engine over by hand to make sure no valves are knocking the piston.
Should be as follows
1. all valve clearance free/rocking at ' TDC 1st 'down' stroke (ignition of fuel) valves closed exhaust moving round but not pressing valve ,
2. 2nd stroke 'up' exhaust valve rocking open and closing as piston tops with the intake ready to rock on as the exhaust closes and piston tops (exhaust),
3.3rd stroke 'down' (intake of fuel) as the piston moves down the intake valve should be opening.
4. 4th stroke 'up' compression of fuel all valves rocking closed as the piston rises for the compression stroke back to TDC all valves closed/rocking free.
Intake, compression , ignition and exhaust. (**** squeeze bang blow)
Feb 23, 2012 | 1972 Ducati 350 Scrambler
Making sure i'm on the compression stroke
The compression stroke is when the piston is traveling UP and the intake and exhaust valves are both closed.
Intake: Piston going down, intake valve open, exhaust valve closed
Compression: Piston going up, intake and exhaust valves closed
Power: Piston going down, intake and exhaust valves closed
Exhaust: Piston going up., intake valve closed, exhaust valve open
Mar 16, 2011 | Toyota Tacoma Cars & Trucks
How do I fit a piston into 80cc trail bike? I'm not sure of the model but it has a 2 stroke engine. Serial #JSiDC13A000503257
squeeze the rings tight against the piston and slide the cylinder down over the top off the piston. you can use WD40 to help slide it down smoother. once the cylinder is in place, hold it in place with one hand and push the kick lever down to make sure the piston slides up and down the cylinder smoothly.
Jan 12, 2011 | Suzuki GSX-R 600 Limited Editions...
I am replacing the rear brakes on a 2000 taurus wagon and it seems thea the piston on the caliber is frozen. How do I unfreeze it and if I can't is it difficult to replace the caliber?
The rear caliper piston has to be pushed and turned in, due to the emergency brake set up. There is a tool than can be used to turn the piston in, then press the piston in, then turn the piston again, until the piston is collapsed, you'll have to do this a few times, turn the piston clockwise. You might want to spray some WD-40 around the seal and piston to help turning the piston.
Oct 30, 2010 | 2000 Ford Taurus
Describe the differance between two stroke and four stroke engines
two strokes fire every time the piston gets to the top ( every two strokes of the piston, down, up)and the fuel in and exhaust out is controlled by holes in the barrel called ports, they need oil mixed with the petrol to lubricate the piston and engine bearings.
Four stokes fire every second time the piston gets to the top( or every fouth stroke of the piston, down, up down ,up) the fuel and exhaust are controlled by valves that are pushed open by the cam, oil is pumped from the sump to the top of the motor and to the bearings for lubrication
May 19, 2010 | Motorcycles
Tell me about 4 cylinder engine firing order 1342. and how its working?
1.****/air in,piston going down
3.squeeze/compresion,piston going up
4.bang/plugs fire,pistons going down
2.blow/exhaust.pistons going up
is that understandable??
Apr 28, 2010 | 2008 Volkswagen Jetta
Piston goes up but wont go back down but when the head covers off it moves up and down freely
piston should be flush with the barrel not going past the barrel. if piston hits the head it wont go back down so check if thats not your prob
Aug 12, 2009 | Yamaha YZ 125 Motorcycles
1996 Saturn SL2 had timing replaced, was on interstate for about 300 miles and threw a rod. If the timing was off could this have caused the rod to break?
If the timing was off, from my experiance, it would cause the valve to go down threw the piston. The rod more than likely was on its last leg before the repair. Because the timing actually keeps the crank shaft (that turns the rods/pistons up and down) and the cam shaft (makes the valves go up and down) in sequence. So if the timing were off then the valves would be down when the piston were up. This could cause the rod to break but usually it either cause the valve to punch a whole threw the piston or the piston to bend the valve. Either case is very bad but so is a broken rod.
Hope this helps
Jun 28, 2009 | 1996 Saturn SL
Europiccola
Use (2). And you could back it off by 1/4 turn, rather than 1/2 turn I think. You want the piston to almost touch the screen at the bottom of its travel. You don't want the piston to push the screen out.
Fergus.
Dec 20, 2007 | La Pavoni "PROFESSIONAL Chrome" 16Cup
Hoisting Logo
307 people viewed this question
Top Hoisting Experts
Jerry Kramer
Jerry Kramer
FIREFOX ENGINEERING
Are you a Hoisting Expert? Answer questions, earn points and help others
