Question about Amana NFW7200TW 3.5 Cu. Ft. Front Load Washer
I get the nf error code sometime but there water leaking into the washer from the inside at the top?
Water dripping from the top inside of the and it will not stop until I shut off the main water source of the washer.
  • 37 Answers
NF--Washer tried to fill but was unsuccessful
maybe a faulty water valve
Posted on Nov 19, 2013
Nf code and donnot continue to next cycle
Samsung Washer Error Code NF (Fixed ...
www.appliancerepairlesson.com/.../samsung-washer-error-code-nf-fixed/
Jan 11, 2014 - What does the error code NF mean on a Samsung washer? ... You can set the washer to any cycle and test each solenoid for proper voltage. ... Next would be to check the screens on the back where the water hoses connect. ..... Hi, you don'thave any power to the water valve wires when it should be filling?
Dec 15, 2015 | Frigidaire Affinity ATF7000E Front Load...
What is Nf code
Dits a no fill error so you probably need to replace the water inlet valve. The link below goes into it in more detail. Samsung Washer Error Code NF Fixed
Oct 24, 2015 | Samsung SW62ASP Top Load Washer
Error code of NF (no fill) on samsung top load washer (WA422PRHDWR/AA) even after checking lines for restrictions and ensuring clean line filters (red and blue). Now, when it does work, it will only do a...
Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, start machine. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, start machine. Now there should be twice the flow of water than there was with HOT and COLD temps. I suspect it is the HOT side of inlet water valve that has failed because machines usually rinse with COLD water.
Jan 20, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
Error code nf
Hi and welcome to FixYa, I am Kelly.
The Error code "nf" is No Fill. Turn off the water at the wall connection and remove your fill hoses at the washer. Inside the inlet to the water valve there are inlet screens. Use a thin knife blade or a scribe on the outside of the screens and remove them. Wash them under slowly running water while rubbing them with your fingers to clean them off. After cleaning reinstall the screens and connect your hoses to the washer.
Next remove the hoses at the wall faucett / hose bibb and check for inlet screens in the hoses. If there are inlet screens in the hoses at the wall connection remove them and clean them. Otherwise reconnect the hoses.. turn on the water... check for leaks and test your machine for proper filling. If it still does not fill or you get the nf code again you most likely have a bad inlet water valve. Either the diaphragm is stuck or... one of the water valve solenoids have failed. The solenoids and water valve assemblies are NOT repairable. IF they fail the only remedy is replacement. Solenoids will read resistance with a meter. The resistance should be the same for both soloenoids. If either one of them reads open the water valve must be replaced.
If the steps above do resolve your problem, respond here and I will help you at that time.
Thanks for choosing FixYa,
Kelly
Apr 16, 2011 | Maytag Neptune MAH5500B Front Load Washer
I am getting error code...NF
Hi
Thanks for using FixYa. Error NF means No Fill. The washer has tried to fill but was unsuccessful. NF indicates No Flow. There is something that is interrupting the inbound flow of water to the washer, either hot or cold. Sometimes this happens when water service in the area is interrupted, creating an air pocket that causing the water valve not to sense water.
Try running the diagnostic test by—
  • Press the delicates and heavy soil keys together for 3 seconds.
  • You are in the service mode.
  • Now, press wrinkle free key, cold water should start entering.
  • Then, press the cotton sturdy and hot water should flow.
  • To exit the test mode, either unplug the machine or press the delicate and heavy soil again for 3 seconds.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 04, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL Washer leaking water on the floor....had a code of nf? I have been reading the message boards and they say could be water pressure sensor tube or switch...but where do I fink these in...
If you have water leaking out of the wash tub that sounds to me like it is the issue. How much water is in the wash basket when your Control Board signals the NF (No Fill) error code?
It's time to remove thr front cover and see where the water leak source is. If it's over the Clutch Pulley then you could have a Tub Seal issue. See if you can identify the leak source. Follow all saftey warnings in the Service Manual or call in a repair service........Big Dollars
See this post Clutch Fix I describe in the front of this fix action for dC/uC error codes how to remove the front cover of the machine.
let me know your DIY skills if you want to try a fix. I have many post on troubleshooting the Pressure Switch in the FAV6800A/FAV9800A machines in this forum both under FAV6800AWDIY and dh1200s logins.......D*ick
The Service Manual for reference. Sears Parts Direct for reference.
Aug 30, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag Neptune will not spins and gives the code nf. I have been told that there is a reset code. Does anyone know the code?
Hi
Thanks
Rylee
Aug 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
"nF" error code at end of cycle, and water leak
nf means u have a bad water valve u may also have a bad hose underneath the lid as well if u have water in your control
Mar 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag atlantas top loader water keeps dripping from top of drum
Your water inlet valve is probably leaking by. If the water pressure is too, or if there is sediment build inside the valve, sometimes the solenoids will not close properly. Try cleaning the valve to see if this helps. If not, I would recommend replacing it. Depending on which valve you have, repairclinic.com has two listed for this model washer for $20 to $30. Let me know if this helps, or if you need further assistance.
Apr 23, 2008 | Maytag Atlantis MAV6260AWW Top Load Washer
Error code
My problem was simply that the screens where the hoses connect to the washer were clogged with rust from my well water. I cleaned them and we're back in business.
Nov 28, 2007 | Maytag Neptune MAH5500B Front Load Washer
Amana NFW7200TW 3.5 Cu. Ft. Front Load Washer Logo
308 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
