Question about RIM BlackBerry Curve 3G 9300 Cell Phone
Keypad not working
I have a problem with my blackberry keypad it is hard to press .This is not the first time the keypad is working this I tried removing my battery and my sim and put it back again the same thing happened.
  • RIM Master
  • 2,072 Answers
I'd say the keypad would need to be replaced. You could look up how to do it on ifixit.com most likely.
Posted on Nov 19, 2013
  • 173 Answers
SOURCE: My Blackberry Curve is basically
Best and easiest way is to just re-flash the phone with the latest software. However this will cause all your data to be wiped clean from the phone. If you can not afford to loose your data, then connect it to Blackberry desktop with a usb cable and play around with the phone to see if you get luck and it connect to your computer. If so then make a backup before reflashing the phone
Posted on Apr 27, 2009
SOURCE: i cannot delete texts from my blackberry pearl
push the blackberry dot button and scroll to delete
Posted on May 23, 2009
taran_2005
  • 10515 Answers
SOURCE: I just bought my Blackberry Bold a week ago and
It seems to be a hardware failure. I could tell you to open and fix the same, but as it is a week old, i would advise you to send it for repair/replacement as if you try to repair it, it might Void the warranty, if any.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 07, 2009
  • 194 Answers
SOURCE: My Blackberry say JUM Error 103
JVM 103- starting address for the boot.cod file is missing/corrupt. your phone is boned, time to start anew.
1- (optional) download JL commander and wipe it clean
2- did you back-up your info?? if not download DM 4.6 from the blackberry website
3- find an OS, get that from either blackberry site, or your carrier, OR do a search for bold 9000 os and see what comes up
Posted on Dec 14, 2009
SOURCE: My blackberry curve 8520 loading
my blackberry curve a red light comes on then it only loads half way then crashes what will a do
Posted on Jan 10, 2011
Im using Blackberry 8520 Curve.. my problem is some of my keys in my keypad are not functioning anymore & some are really hard to press.. what i my supposed to do with these problems.. im not convinced...
usually when its hard to press the keys, there are dirts under them, ask your technicians to clean your phone using compressed air and if it don't work you need to replace the cover of your blackberry. purchasing a cover comes with a keypads.
Jun 16, 2011 | RIM BlackBerry Curve 8520 Smartphone
Tip
How to Reboot a Blackberry Without Removing the Battery?
If you remove batteries and hardware while tinkering with electronic devices, you might run into trouble down the line. Blackberry devices must be rebooted time and again, but you can reboot your Blackberry without removing the battery. <br /> <b><i>Instructions</i></b> <br /> 1. When you install a new program or have a system failure, you must reboot the Blackberry. This is the same concept used in larger desktop or laptop computers. 2. Hold off on using the new program by selecting "Later" instead of "Now" when you are prompted by the Blackberry. This will allow you to wait awhile to reboot your device, especially if you need to use it at the moment and can put off the new program installation. 3. Initiate what is known as a soft reboot by pressing and holding down the key combination of Alt+Cap+Backspace on the Blackberry keyboard. Using this method will also work when the device stalls and you see only the white arrow, but it refuses to move. 4. Note that certain Blackberry models are different and require you to press and hold the Alt+Cap+Delete key combination to reboot the Blackberry without removing the battery. Make sure your keypad is correct for using this method of soft reboot before attempting it. Blackberry makes several different models, and they all operate differently under soft-reboot conditions. 5. Reference your Blackberry manual. Make sure that the keypad soft reboot will work with the specific model you are using. Larger models are typically more prone to working with the aforementioned soft reboot. If this does not work, you will have to use a secondary method. 6. Check to see if you need to install an application for your phone that allows for a soft reboot. Many models, like the Pearl, allow you to download an application for soft reboot. These applications may prevent you from pulling the battery to reboot. 7. Try all the available methods, and if it still does not work, request assistance from your Blackberry dealer. She may know of an alternative or a firmware update for your device. <br />
on Jun 06, 2011 | Cell Phones
The 'h' button on my blackberry vurve 8520 doesn't work properly. i tried pressing it harder but that didn't work. then i tried removing the battery and restarting it that also didn't work :( please help!
These phones are known to have problems with the keypads not working properly - especially if the owners carry them in their pocket instead of in a case. Your best bet is to start looking for a new phone. The one you have will only become more problematic as time goes by. And, replacing the keypad doesn't always work.
It's just a problem specific to these BB phones.
Jan 24, 2011 | RIM OEM BLACKBERRY CURVE 8520 8530 QWERTY...
My blackberry 8520's stuck in alt type mode and my phone is now inaccessible... help?
I can't promise that this will work but try turning the phone off, removing the battery and then operate the alt key several times before replacing the battery.
If that does not work then you have a faulty keypad.
Jan 20, 2011 | RIM BlackBerry Curve 8520 Smartphone
My bb pearl it`s flashing 3 times stop then 2 times i can`t start my bb i can`t upload anything my computer dosn`t see my phone.what can be done to fix my bb?
Perform a hard reset on the BlackBerry smartphone. To perform a hard reset, complete the following steps:
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
If the display is still not working, verify that the battery is charged by trying it in a different BlackBerry smartphone.
If the battery is working, download the latest BlackBerry Device Software and install it using the application loader tool in BlackBerry Desktop Manager.
Nov 21, 2009 | RIM BlackBerry Pearl 8100
I have an app error 523 ive reset it and it dont work
Hi, On the BlackBerry smartphone, the 523 app. error Reset error message appears after pressing the Mute button, accessing an application, or performing a hard reset: To resolve this issue, first perform a hard reset. A hard reset involves physically removing the battery from the smartphone and then reinserting it. To perform a hard reset, complete the following steps: 1) Remove the battery cover from the back of the BlackBerry smartphone. 2) Remove the battery, and then reinsert it after a few seconds. 3) Replace the battery cover. If this does not resolve the issue, the BlackBerry Device Software must be re-installed. Note: The BlackBerry smartphone will not show a Connected state in the BlackBerry Desktop Manager. Proceed to open and run the application loader tool. If BlackBerry Desktop Manager cannot connect to the BlackBerry smartphone, perform the following steps: 1. Remove the battery and run loader.exe from C:\program files\Common Files\Research In Motion\AppLoader. 2. Remember to reinsert the battery after the loading operations begin. I Hope it helped you. Thank you for using ' Fixya ' and have a nice day!!
Nov 19, 2009 | AT&T Blackberry Curve 8300 Smartphone
I think my keypad is locked - otherwise it is just not working
  • I am sure that your keypad is not locked.
  • Remove the battery and sim when mobile is turned on wait for few seconds and - Re-insert battery and sim and check
  • If the display is still not working, verify that the battery is charged by trying it in a different BlackBerry smartphone.
  • If battery is working .download the latest BlackBerry Device Software and install it using the application loader tool in (( BlackBerry Desktop Manager))
I hope this is helpfull for you..
Nov 09, 2009 | RIM BlackBerry Curve 8310 Smartphone
Phone just dies for a few minutes every so often--several times a day for the past ten days. Screen goes black and then there's a little white clock icon on the screen. A few minutes later it's fine...
A) Perform a hard reset on the BlackBerry smartphone.
smartphone.
B) If the display is still not working, verify that the battery is charged by trying it in a different BlackBerry smartphone.
C) If the battery is working, download the latest BlackBerry® Device Software and install it using the application loader tool in BlackBerry® Desktop Manager
Oct 19, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
What is the hard reset for a blackberry pearl? they keypad isnt working and i dont know what to do and someone said to do the hard reset and i dont know what that is
Remove the battery cover and take out the battery. Wait 30 seconds and replace the battery and your phone will automatically start back up. The start-up process takes a while, sometimes 15 minutes, so be patient and walk away. It seems like it takes forever, but just think of it like a watched pot never boils; a watched blackberry never starts back up! Haha, it will start back up though, just be patient. This is the way to perform a hard reset on the blackberries.
Jul 07, 2009 | RIM BlackBerry Pearl Smartphone
Keys not working
The following table shows the possible reasons for performing a hard reset on a BlackBerry device Keypad is not functioning correctly. For example, keys do not work, the trackwheel is not functioning correctly, or the handheld does not turn on. Handheld display is hard to read. For example, the display shows lines obscuring text. To perform a hard reset on BlackBerry smartphones
  1. Remove the battery cover.
  2. Remove and reinsert the BlackBerry battery to reset the BlackBerry smartphone.
  3. Replace the battery cover.
Sep 22, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry Curve 3G 9300 Cell Phone Logo
32 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
