Question about Locks & Locksmithing
Kaba Ilco 790 series - Locks & Locksmithing
SOURCE: Bought house from bank and trying to retrive lock combination
I'm trying to remove a unican lock from my door but I can't see how to get the handle off. any suggestions?
Posted on Aug 22, 2009
  • 963 Answers
SOURCE: I have a Simplex Kaba
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
Good Luck!
Posted on Mar 06, 2011
  • 963 Answers
I believe you can find this to be relevant:
REMOVE THE KEY.
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the Simplex mechanical pushbutton locks:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Here's the website to continue your search:
http://www.kaba-ilco.com/access_control/products/eplex.aspx?id=6
Good Luck!
  • 963 Answers
SOURCE: i need a kaba ilco
SOURCE: How to reset codes in Kaba ilco Unican 4000 access control
The factory-default master code for Unican 4000 is 12345678
Posted on Mar 08, 2011
Kaba ilco series is accepting the cards but isnt opening the doors
I suggest that you contact Kaba Ilco directly with this problem. BE SURE TO HAVE YOUR MODEL #, AND SERIAL # & PURCHASE DATE HANDY IF POSSIBLE!
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Jul 22, 2012 | Locks & Locksmithing
Unican 1000 locked out of room! Donot know how to access the lock to open the door!
I don't think that you have much of a chance since the lock is doing exactly what it was made to do--preventing bypass and entry from the outside!
That said, I don't have a direct answer, but here is the contact info you need for customer service. They may be able to help you:
1-800-849-8324 (option 1)
Technical Support (Simplex, E-Plex, PowerLever, 4000 Series, Solitaire 850L, Solitaire 850/950)
1-800-849-8324 (option 3, and then option 6)
Kaba Ilco is in North Carolina, so it's probably best to call during Eastern Daylight business hours.
Good luck--and please provide feedback if this helps!
Aug 25, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
I tried reseting my combo on the simplex LP 1000/8100 series and messed up. I entered a new combo and the latch did not work. Not only did the new combo fail, I could not open it with the old combo. What...
Contact Kaba Ilco for technical assistance:
Jul 03, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
Cannot get it to accept the user pin numbers. Have entered the master code and also reset the manual reset to default.following the manual and using the # sign before and after master code. red light comes...
Recommend that you contact Kaba Ilco with your problem.
Jul 01, 2011 | Simplex Kaba E-Plex 2000 series Keyless...
Code was forgotten and need to reset somehow. is there any way to do it by myself?
You will find a link to download the manual for your model on this page:
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Go to the right-most column on the manual grid page, labelled "TIPS", and there you will find the files with the programming instructions.
As you will see, there is a reference in those instructions for the need for a DF-59 key. A Df-59 key can be purchased at this site:
Also, there is a need for a spanner wrench. The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
Kaba-Ilco Customer service can be contacted from this link:
Jun 20, 2011 | Simplex Kaba Ilco Unican 1011 keyless...
I have a 1000 series and the buttons do not push in properly when trying to enter the code, What can i do to fix this?
I can't help you directly, but I will steer you to further information.
May 17, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Can a L1000 series simplex kaba be switched to mount a right handed door
No. The Kaba L1000 is factory-handed and is not field-reversible.
That information comes from the grid found on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13&obj=1000
under L1000/Specification/SimplexL1000 Catalogue PDF
Apr 01, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
The backset spring on our double-pole lock/latch is broken. It is a Unicam 7014 series. The backset size is 2-1/4" length and 1" width and the projection is 9/16". Can we purchase just this...
Nov 17, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Is there a repair manual available for the Simplex 1000 series locks.
aspx?id=13
Good Luck!
Need to set multiple combinations need how to set them
Good Luck!
Oct 04, 2010 | Simplex Kaba E-Plex 2000 series Keyless...
Locks & Locksmithing Logo
75 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
