Question about Locks & Locksmithing
Kaba 790 lock instructions - Locks & Locksmithing
4 Suggested Answers
  • 963 Answers
SOURCE: need to find instructions to
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF
SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the Simplex mechanical pushbutton locks:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Good Luck!
Posted on Mar 06, 2011
  • 963 Answers
SOURCE: Need a instruction manual for
REMOVE THE KEY.
Good Luck!
  • 963 Answers
SOURCE: kaba lock won't open with code
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Posted on Aug 24, 2012
Kaba lock won't open with code
Aug 18, 2012 | Simplex Kaba Ilco Unican 1011 keyless...
How to reset a 7000 series lock
Go to this web page:
http://www.kaba-ilco.com/kaba-access-control/Literature-Support/292720/simplex-mechanical-pushbutton-locks.html
To download the instructions, go to to 7000 on the chart, and under the TIPS column, click on PDF
This will download a PDF file of the instructions for you to open.
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Apr 01, 2012 | Locks & Locksmithing
Dissassemble a KABA L1021
Of course disassembly is the reverse of assembly, so I will get you to the assembly instructions.
First, go to the grid on this page:
Across from model L1000, go to the "Manual" column and click on PDF to download the installation manual. Once downloaded, if you can't open it, return to the grid page and click on and install Adobe Reader, which you need to open PDF files.
Yow will probably find that you need a DF-59 key and a spanner wrench to proceed (You wouldn't want anybody with to be able to remove your lock!). A Df-59 key can be purchased at this site:
Good luck-and please provide feedback if this helps.
Nov 04, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Code was forgotten and need to reset somehow. is there any way to do it by myself?
You will find a link to download the manual for your model on this page:
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Go to the right-most column on the manual grid page, labelled "TIPS", and there you will find the files with the programming instructions.
As you will see, there is a reference in those instructions for the need for a DF-59 key. A Df-59 key can be purchased at this site:
Also, there is a need for a spanner wrench. The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
Kaba-Ilco Customer service can be contacted from this link:
Jun 20, 2011 | Simplex Kaba Ilco Unican 1011 keyless...
I have a unucan 1000 lock! i want to know how to insall it. Thanks
This link will take you to the literature grid for Kaba-Ilco locks, where you can select the PDF download for your particular model lock, including installation instructions:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13&obj=1000
Apr 13, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
The lock is staying open when the door is shuting i need to lube it but dont know how to open it up to do so
The installation instructions for simplex keyless locks can be found using this grid on the KABA website. You will need Adobe reader to view-- these are PDF files:
Dec 17, 2010 | Simplex Kaba Ilco Unican L1000 keyless...
I have forgotten the code for my code lock which is on my bedroom door.
aspx?id=13
You'll need Adobe Reader installed, as these are PDF files. The manuals show installation and reprogramming instructions.
You can also research other models of locks from this page.
Dec 09, 2010 | Simplex Kaba Ilco Unican 1011 keyless...
We are trying to recode our simplex 7000 unican ilco lock (5 button). can you send instructions
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=14
Sep 08, 2010 | Simplex Kaba Ilco Unican L1000 keyless...
Lost code for keyless unican lock
I just performed this on my lock and it's quite simple. The instructions are in the attached manual.
http://www.kaba-ilco.com/access_control/access_download.aspx?File=simplex_1000_installation_instructions_d8_pkg_2280.pdf&Attachment=True
Cheers.
May 16, 2009 | Simplex Kaba Ilco Unican 1000 keyless...
Bought house from bank and trying to retrive lock combination
I'm trying to remove a unican lock from my door but I can't see how to get the handle off. any suggestions?
Nov 12, 2008 | Simplex Kaba Ilco Unican 1000 keyless...
Locks & Locksmithing Logo
107 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
