Question about Karcher Garden
My presure washer will not turn on.
Washer is 6 months old and used one time and will not turn on
    Problem Solver:
  • 7 Answers
Does it make any noise when connected to mains,if yes then two possibilities, capacitor is faulty, or motor damaged.
If no noise, then input fuse or motor open circuit. also check cable for damage.
Posted on Nov 21, 2013
Have an Amana NAH6800, I must unplug it and plug back in to get it to start wash cycle. Also, keybord is locked until a couple of minutes after the wash cycle starts. Called repairman, he said control...
WELL IT IS POSSIBLE THE SECOND CONTROL BOARD WAS BAD ALSO? A 6 YEAR OLD WASHER IS YOUNG U CAN GET A GOOD 10-15 YEARS OUT OF A WELL KEPT WASHER.
Dec 03, 2014 | Amana Washing Machines
The presure washer head will not turn or will stop turner when engaged
The head probably needs some cleaning. I use a spray bottle of general cleaner. Then I'll shoot some wd40 in the head.
Jun 09, 2014 | Homelite Pressure Washer. 2600 psi 2.3 GPM...
It's a Karcher presure washer K2.54, one and a half years old. Was working fine last time but when turned on now there is very little pressure through the hose and the water seems to be filling up inside...
this sounds like the seals may have been damaged inside the pump or that the water inlet/outlet could be damaged. If you take off the front cover (use a star bit screw driver) then run the pressure washer you will be able to see were it is leaking from and then you can get the right part to replace it.
Mar 16, 2011 | Karcher Garden
Pressure washer is pulsating when powered on
it just the presure building back up ,it will last years doing this,i would not worrie as replacing the presure pump will only be a temp fix and it will do it again ,most washes do this after a year or lots of use.
Dec 31, 2009 | Karcher 1750 psi Electric Pressure Washer
No water comes out of washer, hot or cold. I disconnected the hoses from the back, checked the water presure and the screens, looked good. I poored some water in and used the spin cycle to check the drain,...
Could be a bad water valve. to access the valve you need to flip up the conrtrol panel. Get a putty knife and release the spring clips on each end and flip up the panel. Pop the cabinet clips and tip the cabinet forward so you can get to the water valve. I generally just unplug the quick connect and power up the valves with a test cord. 3 months old it ought to have a frigging waranty on it anyway.
Jun 14, 2009 | Washing Machines
GE washer no main motor run so no agitate or spin
This is the electronic washer. Unplug for two minutes, plugin then open and close lid 7 times. This will reset motor. Also make sure belt is not broken.
Jun 07, 2009 | GE WBSR3140DW Top Load Washer
Sport_Duet F-28, fails on spin
f28 is a communication error, so i would check hte wiring connections to the control boards, not ness. the control boarditself, also quite possible that a safetry ground switchno t making contact propery, ( talked with tech line on this very issue on friday(6 month old duet sport model) turned out to bew aloose connection at the motor control)
Jan 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Portable Whirpool washer, floods the floor when in use
dose it stop flooding when you stop the timer or turn off the water.if timer your presure switch hose has come off.have to empty washer to reinstall because water in tube gives false reading.if when you turn off water its your water level switch.God bless,tom
Jan 02, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Lopsided during spin
  This can be caused by a brake that has failed.  Try to spin inner tub with washer off.  It should NOT turn.  If it turns the brake is bad and is allowing the tub to spin when agitating.  This causes clthes to bunch up.
Oct 27, 2007 | Maytag PAV2300 Top Load Washer
Garden Logo
79 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
