Question about Whirlpool Duet Sport HT WFW8400TE Washer
Clean pump hose - Whirlpool Duet Sport HT WFW8400TE Washer
Not cleaning properly, and Water will not drain out. However when we pull the house out the water does drain. Assuming pump? KUDV24SE Kitchen Aid Built In
During normal operation the outlet hose should be higher than the outlet nozzle, if the water drains when youremove the hose it means that the pump is not working, open the bottom of the machine and remove the inlet side pump hose and check for any obstruction, clean and replace the hose. If this does not work you need to replace the pump.
Jun 02, 2011 | KitchenAid 34 in. KUDV24SE Built-in...
My lg washer and dryer wm3431hs isn't draining. I took of the hoses in the back, cleaned the filters and still nothing please help!
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps...
Daniel
Jan 10, 2011 | LG WM3431H Washer and Dryer
Front load KEnmore washer 44102300 won't drain
unplug the machine,remove the bottom panel to get at the pump,put towles down and around the pump and if you have a wet and dry vac have it ready,with a pair of plyers squeeze the clamp on the large hose that goes to the pump and push it back onto the hose,then turn on the vac and pull part of the hose back and **** up the water,when you drained it pull the hose all the way off and clean out the catch in the hose,some of the machines have a plastic piece inside the hose to stop coins and whatever else gets in there from hitting the impellar on the pump,if it's in there slide it out and clean out the hose,put it back together and run it,if it still doesn't drain you could have damaged the pump and need to change it out but most of the time it just needs to be cleaned.let me know how you make out
Oct 17, 2010 | Kenmore Front Load Washer
Prewash light flashing and machine not washing
I would suggest that you clean the pump filter.
Remove lower rear panel of washer.
Remove large black hose onto bottom of drum.
Remove and clean filter inside hose.
Remove the hose onto the pump, and check for obstruction here and in the pump.
Hopefully , this shouldn solve your problem.
Dec 08, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Front load waher will not drain
Hi, your washer water pump, could be burnt out, or clogged up, but first check drain hose for kink, remove back of machine, locate water pump, device that your drain hose are connected to, remove all hoses, pump from washer, and clean, sometimes foreign objects get into it, and prevent pump impeller from spinning, also check water pump winding (coil) with ohm tester, place tester lead, one on each terminal on pump (motor) if you hear beep sound, pump motor o/k, if not, pump burnt out, replace it, but first remove pump, and clean it. after cleaning replace pump, try machine. you could put drain hose, close to floor, into buck, and water will empty by gravity, if water is not emptying, that's evidence your water pump is block, small object (handkerchief, coins etc.) gets into them, from time to time, first clean your water pump, `and check for kink, in drain hoses. . always disconnect power, before attempting any repairs. good luck.
Aug 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Power sterring hose leaks. how is hose connected to pump
Most of the PS pressure hoses are Compression Fittings. If the fitting is straight on and is clean on the inside before you seated the hose, there may be a burr of the pump side where the fitting sits. Some of these fittings are replaceable and others require a new pump. Check your new hose also for cracks where the pipe section of the hose is that looks sort of like a trumpet end. If the fitting is in good shape, the pump fitting is clean and unmarred, you may need to tighten the hose a little more.
Jul 22, 2009 | 1989 Toyota Celica Liftback
Water does not pump out
If you have the WSXH208A that you posted under, you will have to take the lower front panel off (one 1/4 inch hex screw on each side, right by the floor) then take the hoses off the pump and the two 5/16 hex screws that hold the pump down. Be ready to soak up the water that is still in the hoses and pump when you remove the hoses. Clean the coins and other obstructions from the pump inlet hose and make sure nothing is inside the pump. Reassemble pump and hoses and test. Should be a Fix-Ya for your machine!
Jan 18, 2009 | GE WSXH208A Front Load Washer
Waont drain
I would check the pump.
Follow the drain hose back to the pump, disconnect the outlet hose from the pump and disconnect the inlet hose from the pump. Look inside both hoses and the pump for pillow pieces.
The pump may have to be removed for cleaning, you should be able to turn the pump by hand, if not, replace the pump.
Inner tub.
Run some water in the washer with the inlet hose disconnected from the pump. You'll need a pan or bucket for the water to run into and look for pillow pieces.
Dec 21, 2008 | GE Washing Machines
Will not drain
pull the check valve in line after pump this my be jamed if not the pump may need replacing
Feb 24, 2008 | GE 24 in. GSD5560GSS Built-In Dishwasher
Whirlpool Duet Sport HT WFW8400TE Washer Logo
12 people viewed this question
Dan Webster
Dan Webster
Sal De
