Question about Kitchen Appliances - Others
How to add a switch light - Kitchen Appliances - Others
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
Add a switch light to what device?
Posted on Nov 23, 2013
How do i wire multiple lights on one three way switch
Multiple lights are just connected in parallel to the first light off the three way switch. See my article on how to wire two 3 way switches to control one light and then just connect more lights to the last light. Remember not to add too many lights to the circuit. Check the amperage rating on the switches being used.
Jun 09, 2014 | Electrical Supplies
How do I hook up a Leviton Decora no 5601... I have a white, a red, and a black wire
Wiring is unclear without more information.
Question posted under 4-way switch.
Wiring sounds like 3-way switch is possible.
And Leviton 5601 is single pole switch.
Add a comment and say what load the switch controls. Load means light, fan, motor, etc.
Say if another switch controls same load.
And include what type of device you are replacing.
Include what screws and screw colors are on old device.
When you add a comment, it sends email, and I will respond to comment.
Sep 01, 2011 | Leviton 112-05604-2WS 15A 4-Way Decora...
110 line in to light switch. How do you continue 110 line out to other oulets or switches?
Add another line to 120V switch.
To begin, inside your switch box, there must be at least two cables.
Each cable has a black-wire and white-wire and bare ground wire.
If your box has only one cable, then you cannot use that for your junction.
OK, your box has 2 cables.
One cable comes from circuit breaker box. These are called Line wires. There is a Black Hot and White Neutral.
The other cable goes to light. These are called Load wires.
You are going to add a new cable with a black-wire and white-wire
In back of box, the white wires are twisted together and covered with wire nut.
These white wires are called Neutrals.
Add your new white wire to these other white wires.
The switch has 2 black wires. One black wire is the Hot line wire.
Add your new black wire to the switch screw that has the Hot.
Of course the switch has 2 black wires, so how do you know which is the Hot.
Turn light switch off, turn power ON, and test each black wire to bare ground wire.
Tester lights up on the Hot.
Review:
New white wire connects to other white wires that are twisted together and covered with wire nut.
New black wire connects to Hot wire.
Ground wires are connected together.
On your new receptacle, the black wire connects to brass screw, and white wire connects to silver screw.
Screws are color-coded to tell electrician how to wire.
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Mar 08, 2011 | Leviton 5634 Dual 1 Pole Switch Decora...
I want to change . alight switch ito a combination switch. outlet and light but thiers only two wires runin to light switch
You only have two wires, because it is wired for a switch leg. You only have the incoming hot and outgoing hot to the light. You need a neutral and grounding conductors also. If you're putting this in a bathroom, it should be a GFCI receptacle. You will have to add another wire, or just add another box in the wall.
Aug 01, 2010 | Cooper Wiring Devices ACE AC-DC...
Adding an additional light switch to an existing light
To add a second switch to control an existing light, you need to get a 3wire cable between the two switches, Thats red, black, white, green wires in the cable. Then you would have to use two 3way switches to make it work. I posted a "tip" on how to wire the 3way switches ..
Please Vote !!
Mar 28, 2010 | Cooper Lighting Lighted Switch
Add a light when the cruise is on
the extra load from the light could blow a fuse,
I would go with a LED light with a relay this way the light is ran off its own line[you would have to add].
Nov 27, 2009 | 1997 Lincoln Continental
Light switch
You Need to Test with a electric tester and Identify a Hot and a nuetral in t the Box. If you find them that is what you need AT LT.If you are missing either you will have to add it. 3W switches can be installed numerous ways.If you have More info let me know.
Master Electrician
Oct 14, 2008 | Electric Door Light Switch
Kitchen Appliances - Others Logo
53 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
