Question about Kohler K-11466-0 White Cimarron Comfort Height Complete Solution elo
Sloan valve whining - Kohler K-11466-0 White Cimarron Comfort Height Complete Solution elo
Sloan valve makes long whining noise when flushed
Some of them do that. Disconcerting.
Sep 25, 2017 | Sloan Home
How do I lower the water level in the toilet bowl of a Slone Flushmate? It keeps getting higher, little by little after each flush.
The flush valve may be defective but some tinkering with the refill level setting may work.
Jun 24, 2017 | Home
I have a Sloan m101526 toilet tank and it's constantly making a running /hissing noise. At first it was just a drip noise then more then like a flowing noise.
Lift the top of and look. It will either be the flapper in the bottom is being held up by the chain or something, or the inlet valve is faulty. Flappers do wear out and warp. If you get 4 or 5 years you are lucky.
After typing this, you have a Flushmate in it. I would call a plumber!
Sloan m101526 toilet tank Google Search
Jan 11, 2017 | Sloan Home
The Sloan Flushmate is spraying water out of the bottom valve; instead of down, the water is spraying up and all over the tank. How can I fix this?
Without more specific detail about the origin of the spray (lower supply, discharge extension, drain valve, etc) it's hard to say what the problem is or exactly how to fix it. I suggest you call Flushmate Tech Support at 800-533-3460 (M-F, 8 - 4:30 ET). For best results, call right from the toilet.
They'll need to know the serial number, model number, fixture manufacturer, etc. to get you taken care of.
Best of luck!
May 31, 2011 | Sloan M-101526-F42 Flushmate?® Complete...
I have a Sloan urinal that will not stop flushing. I have rebuilt it with a total rebuild kit. I cleaned the inside of all surfaces and I flushed the entire piping system to no avail. It will not stop...
The rubber vacuum relief needs to also be changed if you have not. It is located in the tube that runs down to the urinal from under the flush valve. The handle could be hanging up.....or there could still be sediment stopping the diaphragm from working properly.
Nov 21, 2009 | NRS 180-1.5 Sloan Exposed Urinal...
I need a blue print on how a sloan urinal flush valve works and how the water flowes through it. if posable exactly how it works.
SLOAN FLUSH VALVES ARE SIMPLE. IT DEPENDES ON THE PROBLEM. IF THE VALVE KEPS RUNNING AFTER IT IS FLUSHED THE RUBBER DIAPHRAM IS DIRTY OR OLD AND THE RUBBER DIAPHRAM IS GETTING HARD. AND STICKING. THE VALVE WORKS ON A VACUME TO CLOSE THE DIAPHRAM TO STOP THE FLUSH PROCESS. WHEN YOU PULL ON THE FLUSH HANDLE YOU BREAK THE VACUME THAT FORM ON THE TOP OF THE DIAPHRAM WHICH ALLOWS THE WATER TO FLOW AS THE WATER FLOWS IT IS ALSO STARTING TO PULL A VACUME IN THE TOP OF THE DIAPHRAM TO CLOSE THE DIAPHRAM AND STOP THE FLUSH.
AS THE DIAPHRAM GET OLD AND WORN IT GETS HARD AND DOES NOT MOVE AS FREELY AND STICKS OPEN AND WON'T LET THE VACUME CLOSE THE DIAPHRAM AND THE URINAL WILL CONTINUE TO FLUSH. HOPE THIS ANSWERED YOU QUESTION
Oct 01, 2009 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
Regal Sloan Valve operates only intermittently
The diaphram has a little metal by-pass or air-flow hole thats probally stopped up or the vacumn breaker is bad.
Jun 21, 2009 | Home
My sloan flushmate toil I think is backiing up. When I take the lid off and flush the toilet water shoots out the front side of the flushmate. What could the problem be or is it broken.
You may have a leak in the discharge extension, lower supply, or drain valve. I suggest you call Flushmate's tech support line (on the Flushmate label) and see if they can help you out.
Good luck
Apr 14, 2009 | Sloan M-101526-F42 Flushmate?® Complete...
Kohler K-11466-0 White Cimarron Comfort Height Complete Solution elo Logo
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
