Question about Mitsubishi WS-65611 65" Rear Projection Television
LEAKY CAPS WHAT DO THEY LOOK LIKE?
DOES THE STUFF THAT LEAKS OUT FEEL SOFT SOME WHAT LIKE RUBBER AND IS YELLOW IN COLOR?
    Genius:
  • 1,153 Answers
Yes it could be considered that way! Where is the cap and what is the problem?
Posted on Oct 08, 2007
SOURCE:
2005 Kawasaki EN 500 Vulcan gas cap leaks
Hi, Fred and the usual suspects are:
1. Faulty gas cap one-way valve has failed.
2. The gas cap rubber seal is old-hard-cracked.
3. Fuel tank vent line clogged-pinched
4. Faulty EVAP canister or clogged-pinched lines.
5. Faulty EVAP solenoid valve stuck.
6. Charcol in EVAP canister soaked with fuel.
7. Excessive engine heat or ambient temperature.
8. Fuel tank overfilled.
9. Vapor lines filled with fuel.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Gas cap leak Kawasaki Vulcan Forum Vulcan Forums
http://www.kawasakimotorcycle.org/forum/kawasaki-cruisers/144499-leaky-gas-cap.html
Kawasaki EN500 Vulcan 500 LTD Service Manual
OEM Parts for Kawasaki
2005 Kawasaki Vulcan 500 LTD Owner Manual
Aug 03, 2013 | 2005 kawasaki EN 500 Vulcan
Leaking water under the car when parked it just started last week.
Is the liquid clear or colored? If it is clear and you have been using the air conditioner, it is just condensation and not a problem. If the fluid is colored yellow/green or orange and feels slippery, it is coolant. This means you may have a loose hose fitting, a leaky hose, a bad radiator cap or a bad water pump. You'll need to look under and over the engine to see where the fluid is coming from. If you added fluid recently, you may have added too much and it may be coming from the overflow tank. That tank could have a leak or a loose hose going/coming from it. Good luck. Make sure you have plenty of antifreeze in the radiator and overflow tank at all times so you don't overheat the car. Check the levels while the car is cold.
May 27, 2013 | Cars & Trucks
Defrost does not work but the heat goes to the floor only
check the plastic vacuum lines that control it.... many find the problem is the soft dry rubber that connects the plastic tubes has rotted and leaked.
colors for the tubes are yellow, red, white, and green, but vary from car to car.
They connect behind the control and go under hood/pass side near the firewall.
Dec 10, 2012 | 1991 Cadillac Brougham
Leaking oil from a plug on the top front of my engine
Spark plug can work it way out of the thread.
Inspect plug ceramic tip for damage.
Tighten plug and clean the valve cover.
The two sources of leaks are from valve cover gasket and leaky rubber under oil cap.
Jul 29, 2011 | 1984 Oldsmobile Cutlass
My code for my 2000 hyundai accent is: P0442 Evap system small leak im sure that the gas cap is on all the way.
may have a leaky vacuum line somewhere. The rubber seal on the gas cap could be cracked or worn out. they are easily replaced.
Oct 02, 2010 | 2000 Hyundai Accent
Check engine light on (Code P-2096)
P2096 is bank 1 lean code. This can be caused typically by a hole in a vacuum hose coming from the motor. Typically a hole will be found from heat and oil damage in a 90 degree bend of a hose running from the air intake to the PCV valve. You may have to remove that whole section (multiple bends usually) and do a very close visual inspection or feel around for a soft spongy area on the hoses. If it feels soft, there is very likely a hole at that point and it feels soft because the rubber thickness is thinner from melting. Other vacuum leak places to check includes the large rubber hose from the brake booster to the intake. If this is not the issue you could have a faulty fuel injector and typically using injector cleaner will not fix that problem.
Jul 25, 2010 | 2006 Chrysler Sebring
Dash light came on, I have a 2002 f-250 7.3 diesel, light has arrows with 2 rows of dots, upper right hand part of dash light area
That light indicates that it is time to replace your air filter. After replacing the filter you will want to reset the lamp. On the air filter housing is a filter indicator. It is a small (2" round) cylinder with red, yellow and blue colors on it, as well as 2 wires. Push in the rubber yellow cap on top of the cylinder until you feel a snap and see the yellow plunger in the cylinder move. This should reset the light.
I hope this helps
Apr 10, 2010 | 2002 Ford F250 Super Duty SuperCab
Black stuff on & around fuel cap. What is it?
I guess it pretty much has to be exhaust. How is your exhaust system? Could it be leaking and rising up into the cap area? Is the pipe secure in the gas compartment? Does it look like rubber or plastic, or soot/ exhaust?
Oct 18, 2009 | 1997 Geo Tracker 2 Door
Yellow Toner leak inside printer
I generally use small soft-bristle brushes to move the toner to locations where I can easily get to it with a small hand-held vacuum unit and just **** it right out.
Apr 07, 2009 | HP Color Laserjet 3550 Printer
MItsubishi ws65611 wont go on Please help
actually its a cap. just not an electrolyic. Its probably a mylar cap but without a parts listing it will be hard to tell you the specifications.
Oct 14, 2007 | Mitsubishi WS-65611 65" Rear Projection...
Mitsubishi WS-65611 65" Rear Projection Television Logo
44 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
