Question about Xerox WorkCentre 6015NI
Fixing a recharged toner trouble (CRUM ID 093-962)
My cyan toner was recharged, and the toner chip was changed too, but the printer shows the message "CRUM ID 093-962 - restore cyan cartridge". How can I fix it?
  • 49 Answers
SOURCE: 17H Service Required
Please follow the solution in the link below. Also as you putting in the cartridge always check for loose toner in the area and on the cartridge itself as this can block the sensors.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=74,E=0000000001343666831,K=8485,Sxi=0,Case=obj(3510)
Niallbt
Posted on Mar 30, 2009
  • 110 Answers
SOURCE: error message: cyan imaging unit is either missing or unseated
The problem is with the top cover assembly. It could be a few things. I would first try the toner sensor flags(the magnet may not be strong enough to read properly). Also replace the toner cartidge because it's magnet may also have gotten weak. Third, I would try the Toner sensor board.
I have had this problem with many printers and normally it is just the flags because of the weak magnets.
Posted on Sep 08, 2009
  • 18 Answers
SOURCE: After removing toner cartridges error display said replace various colour toners.
it is not according to your printer or your head of cartige is not clean or damage. try replace new one
Posted on Sep 11, 2009
MUKHTAR
  • 2017 Answers
SOURCE: I have put a new Cyan toner cartridge in the C525A
make sure the cyan toner is not empty just remove and shake it and install it again.
Posted on Jan 19, 2010
  • 217 Answers
SOURCE: Xerox 6180 MFP's cyan cartridge isn't recognized
There are a number of possible causes of this.
1. Faulty chip on the cartridge, or badly fitted chip.
It will look obviously 'odd' if the chip is incorrectly fitted to such an extent that contact cannot be made between the cartridge chip and the printer. If it looks OK, and you still have the old cartridge, try swapping the chip (complete in its 'carrier') from the new one onto it. If the stays, it's the chip. Confirm this by putting the OLD chip back on the OLD cartridge, and you should get a different message telling you the catridge is empty.
2 Broken cartridge (I've seen quite a few like this - see pictures - the broken one had probably been dropped).
First picture - undamaged cartridge, note 'lug'.
Second picture - missing 'lug' (cartridge has probably ben dropped)
There is an opto sensor that checks the presence of the cartridge by 'looking for' this lug. The matching one at the other end of the cartridge has no effect.
It is possible to glue a broken lug back onto the cartridge, if the lug is missing, make something that matches the overall size and profile and glue that on - make sure the glue has set/hardened fully before putting the cartridge into the printer.
3 Faulty circuit board, or sensor in printer.
If you've tried the instructions under 1, and the error message stays the same through all the combinations of OLD chip, OLD cartridge, NEW chip, NEW cartridge, AND 2 is not applicable, this is where you are. It could be the opto sensor that 'looks' for the cartridge - you could 'short' this out (be careful to do this on the correct side of the device). Otherwise its a circuit board problem.
Posted on Apr 15, 2010
Y - CRUM Error / Error 093-950 Restart Printer
093-950 Y - CRUM Error
Error 093-950
Restart Printer
The yellow toner Smart Chip error is detected
Error with detecting or defective yellow toner cartridge. Replacing cartridge should correct it.
Paul
Nov 25, 2013 | Lexmark X560n Laser Printer
Please on my Sharp copier Mx 4501n display error code F2-65 what is the cause
Your machine is starved for cyan toner. Either the toner supply pipe is blocked or the CRUM counting chip on the back of the cyan toner cartridge has burnt out or wound down to zero. Try replacing your toner cartridge. If still no go you'll have to take out the drums, developer tanks and transfer belt, hold a piece of paper under the cyan supply pipe spout and tap the pipe to break up the toner.
Jun 08, 2013 | Office Equipment & Supplies
F2-65 shows on my sharp mx4501n copier what will i do
Your machine is starved for cyan toner. Either the toner supply pipe is blocked or the CRUM counting chip on the back of the cyan toner cartridge has zapped out or wound down to zero. Try replacing your toner cartridge. If still no go you'll have to take out the drums, developer tanks and transfer belt, hold a piece of paper under the cyan supply pipe spout and tap the pipe to break up the toner.
Call for service u2-40 sharp ar 275
CRUM chip communication trouble = the chip on the toner cartridge is faulty.
1, Try to clear the code press P, *, C, *, to enter the service simulation, on the key pad press 1,6, then the copy start, press execute on the screen.
2, Change the toner cartridge.
If it is a brand new one return to supplier as faulty, if it is a refilled new one take back to supplier (the CRUM chip serves as a genuine supplies protection for sharp and 'blows' when the toner is empty the re-filler will have to put a new chip on it)
Nov 16, 2010 | Sharp AR-275 Copier
I have a sharp ar-235 what does call service code U2-40 mean
If it is a brand new one return to supplier as fault, if it is a refilled new one take back to supplier (the CRUM chip serves as a genuine supplies protection for sharp and 'blows' when the toner is empty the re-filler will have to put a new chip on it)
Nov 04, 2010 | Sharp AR-235 Copier
I have an older Sharp AR-168S printer with U2-40 error code.
U2-40 CRUM communication error
Detail-Toner cartridge CRUM data read
error
Cause-A toner cartridge of a different
destination is installed.
EEPROM trouble
Check the destination setup.
Toner cartridge CRUM PWB trouble
MCU PWB trouble
CRUM connector disconnection
Check and
remedy-
Install a specified toner cartridge.
Check the SIM 26-6 setup.
Replace the EEPROM.
Replace the toner cartridge.
Replace the MCU PWB.
Check connection of the CRUM
connector.
Execute SIM 16.
Feb 09, 2010 | Sharp Office Equipment & Supplies
My sharp ar5316e show f2 04 solve this
clear the memory of the machine, change the destination of the toner or fixe in a new toner crum or also known as toner sensor
Jul 01, 2009 | Sharp AR-5316 Advanced Digital Imager...
CLP 300 toner cartridges invalid toner
the drum has chips encoded,need cartridges with chips.
May 29, 2009 | Samsung CLP 300 Laser Printer
Crum data read trouble in sharp ar 207
The CRUM chip is what tells the copier that the correct toner is installed. It is specific to the toner cartridge. If it is a new cartridge then it should have a new CRUM chip and there should be no problem. If it is a recharge it's possible that the chip was not changed or the wrong one was used.
Oct 16, 2008 | Sharp Office Equipment & Supplies
Please help with diagnosis of following error for Dell 5110CN CRUM ID -093-693
crum has happened to me when using the wrong toner cart or using a non-Dell cart. If that is the case, replace the chip from the old Dell cart into the new non-Dell - easy to do by prying the small circular top off. You'll probably need to switch to non-Dell toner on the printer - go through menu to find it and your toner usage software will be disabled - that's life.
I also had this happen with real Dell toner cart and I did the same thing to rectify.
Mar 16, 2008 | Dell 5110cn Laser Printer
Xerox WorkCentre 6015NI Logo
846 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
