Question about Sony PlayStation® 3 (80GB) Console
Wont read games spins and stops
I replaced the disk tray and it still spins and stops wont read games.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 41 Answers
Have you tried a laser cleaner?
Posted on Nov 21, 2013
4 Suggested Answers
  • 133 Answers
SOURCE: my playstation 2 disk tray wont spin
the thing is, there can be 2 things.
  • The motor that spins the discs has gone bad. you cant do anything then, just pay the local dealer 20$, he'll fix it for ya
  • Or, your Disc tray is not closed properly. For solving this, try to keep somehitng heavy upon the disc tray, and then try.
  • Please give ratings promtly :)
Posted on Mar 27, 2009
SOURCE: ps3 wont read disks
If YOUR WARRANTY IS UP. taking the ps3 apart is easy as long as you have the rght screw drivers. getting the plate off is the hardest part. there is a hex screw under the warranty sticker. after removing the screw, simply slide the plate down and it will pull off. then there are about 8 philips head screws on the casing itself. after removing these screws the top is hinged on the front side of the system... lift the back untin it is at a 90 degree angle and and remove the flat wire that goes to the SDcard slots by lifting the black flapwith your fingernail, then the top is removed. at this point the disk drive is no longe fastened by any screws of clips. pull the plug from the left side toward the front out to diconnect that set of wires. then there is a big flat silver strip connected to the bottom of the drive. once again lift the black flap to release this strip.now you are ready to open the drive itself. there are 2 silver screws on the bottom rear of te drive and 3 black ones at the front. you will need a very small philips head screwdriver for these. then the gray casing will come off. thelense is not exposed yet. there are still 5 or 6 tiny black screws on the top of the drive that will remove the black plastic case THERE ARE 2 TINY WIRES COVERED BY TAPE BE VERY CAREFUL NOT TO PULL ON THESE WHEN TAKING THE BLACK COVER OFF
. now the lenseis exposed. simply clean it with rubbing alcohol and q-tips and reassemble the machine. BE SURE NOT TO GET ANY OF THE WIRES PINCHED WHEN SETTING THE DRIVE BACK IN PLACE AND DONT FORGET THE LITTLE METAL GROUND ON THE RIGHT REAR OF THE DISK DRIVE. ANY ?S E-MAIL ME AT hartsedustin@yahoo.com
Posted on Apr 03, 2009
  • 136 Answers
SOURCE: my slim ps2 wont read any disk at all what should
It probably need a new CD assembly, you can get them on eBay.
Posted on Aug 09, 2009
Spins and stops wont read games
get a blue ray lens cleaner and use it
Nov 18, 2013 | Sony Playstation 3 (PS3) Console
Will not read disks. Cycled power usally worked not this time.
First Turn your X-box on
Second Take out your game or CD
Third Open tray
Fourth Close tray
Fifth Repeat Third and Fourth a couple times and let it load then open
Sixth Stop when you hear the xbox make a spinning noise like when it is reading a game
Seventh Open tray
Eighth Pit a game in
Ninth Close tray
Tenth Play you game!
Dec 30, 2010 | Microsoft Xbox 360 Console
My xbox 360 will not read the disks...
the grip may be worn off the disk "thingy" that makes it spin ha, so you may need to replace that, call it in to xbox as ring of death and they will fix it for free
Apr 24, 2010 | Microsoft Xbox 360 Console
Wont spin and says open tray
its possible that the mainboard is sending too much voltage through to the drive itself causing it to blow. on the other hand it could be that the laser was on its way out anyway and might be coincidence. its a hard one to eliminate.
Linda
www.xboxrepairkit.co.uk
Sep 06, 2009 | Microsoft Xbox 360 Console
It only comes up with open tray
If you here it spin up and it goes to open tray
you probley have a dead laser or hub/spindel motor. Its an easy swap for the laser. if the
spindel motor is weak ,your going to have to
replace the drive and swap the board.
Jun 26, 2009 | Microsoft Xbox 360 Console
One day i was playing halo 3 and my disk drive starting making wierd, grinding noises and stopped then after the noise stopped my disk would stop spinning and now eveytime i try to read my disk my motor...
This hard disk is a easy fix, You can buy a new one for the fraction of the cost, All you have to do is slip this off the unit and apply an new or even a used hard drive. Here is some links for some hard drives http://catalog.ebay.com/Microsoft-Hard-Drive-120-GB-9Z600001-for-Xbox-360_W0QQ_fifptsZ1QQ_pcatidZ413QQ_pidZ70884347QQ_trksidZp3286Q2ec0Q2em271
you can get some for under 30 bucks. if this information helps please rate accordenly Thanks
May 02, 2009 | Microsoft Xbox 360 Console
My Xbox 360 stopped spinning the CD and playing the games.
i myself have the same problem and currently working on it. go to youtube and type in "how to fix a broken xbox360 dvd disk drive" this guy is amazing and helped me out with the red rings of death. all u have to do is buy a new disk drive for about $50 and take some parts apart.
Mar 14, 2009 | Microsoft Xbox 360 Console
The motor wont spin the disk
well sounds like whats wrong with my xbox and the open tray problem..wont read any media. if its still under warranty return it for a fix
Mar 11, 2009 | Sony PlayStation 2 (PS2) Console
Sony psp
have you tried various disks? certan disks may either be scratched or dusty so you coul take a can of compressed air and ust out both some umd's and the umd tray of the psp. also, if you're usuing a custom firmware, you may find it will work once you revert to an official firmware
Jan 19, 2008 | Sony PlayStation Portable (PSP) Console
Disk wont spin
Your, dvd playing in your ps2, may be malfunctioning, your best bet is buying a ps2 dvd player, taking the old one out, and putting the new one in, and I guarantee that that will help you continue on your massive killing rampage on vice city.
Aug 20, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation® 3 (80GB) Console Logo
29 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
