Question about Fisher and Paykel DEGX1 Electric Dryer
The display lights on my top loading fisher paykel dryer don't always stay lit when the dryer is running
Sometimes the power button has to be pushed several times to get it to work
  • 739 Answers
Make sure the wire connections are all tight, if they are, replace the power button
Posted on Nov 20, 2013
4 Suggested Answers
SOURCE: Fisher & Paykel ED56 Dryer alarm on. Nothing else works
Replaced electric control panel. Looks like power spike fried the works
Posted on Mar 02, 2009
localwonder
  • 6784 Answers
SOURCE: The dryer won't run. Dry, extra dry, and coold down process lights are lit.
Hi, the lights are signaling a control fault the is concerning the logic sector of the control board/timer. you will need to make sure that the wiring harness is connected to all points and it should be in good condition. if there are no apparent issue with the wiring harness, replace the control.
Posted on May 29, 2009
SOURCE: my fisher and paykel dryer ( mod# ED56 ) wont start, power is on
I had this same problem with my Dryer. It is making the few quick beeps because it thinks the door is still open. Near the bottom of the opening to the dryer there is a sensor switch that gets pushed in when you shut the door. Try holding the switch in with a knife or something and then start the dryer with the door open to check if that is the problem.
After i did this, i closed the door and my dryer started as normal.
Posted on Jul 16, 2010
I have a Yamaha RX-V367 receiver and the factory remote does not work properly.
The remote is on the way out replace it
mine have gone the same way from over use
Dec 11, 2016 | Tablets & eReaders
Power button on my rca tv wont turn on sometimes
A number of possible reasons for this---failing part in set or even bad connections on main board in the set----model listed is prone to going dead with high pitched squeel etc.
Oct 31, 2012 | RCA TruFlat 27F520T 27" TV
I have a FinepixJ40 with the ZOOM ERROR and tried to turn the lens several times, still can't fix the problem, is there something else I can do? Thanks Paul
try when u push the power button to twist the lens and see if it works...if not try pushing on the lens when pushing power button...i have fixed some while pushing power button and giving it a little hit with the palm of your hand..hope this helps
May 05, 2011 | Cameras
No power to headlight!
Some bikes by design shut off the headlight while cranking the starter to conserve power. I'm not positive on your model, but Goldwings have this feature.
They do this by having 2 sets of contacts behind the starter button...so as you push in, first the headlight contacts open...then as you push further the starter circuit contacts close. Sometimes as these bikes age...the button doesn't fully release, so the starter contacts open, but the headlight contacts don't close.
With key off....spray a little WD-40 around the button and work in and and out several times, letting it snap out, then retry.
Apr 03, 2011 | 1984 Honda VF 1100 Sabre
Asko washer w6021 doesn't work. I've checked
See whether water is flowing into the wash machine. Then the door close switch.
Mar 28, 2010 | Asko W6021 Front Load Washer
The screen says F0 and it keep beeping. whats wrong?
One or more push buttons are stuck. Push all buttons at random several times each. Sometimes this will release the stuck button. If that does not work you will have to replace the keypad.
Oct 12, 2009 | Dacor Ovens
1999 RCA mm36100 TV The buttons on the front panel are all messed up sometimes they work and sometimes not. The menu keeps popping up from time to time randomly and sometimes runs though the menu items all...
Bad push button board, best thing to do is just unplag the board and use remote to operate TV, board is mounted under front cover where button are.
Aug 09, 2009 | RCA MM36100 36" TV
Model CS- 40307 40 inch Mitsubishi TV will not turn on
continue to push power button until light turns green. verie rate of push and hold
Jul 15, 2009 | Mitsubishi WS-65819 TV
New start button?
Hello Colette,
When a component sometimes works and sometimes doesn't work, it suggests the component itself is functioning correctly. Check for loose wire connections on the door switch, the start switch, and on the cycle-reset switch which is located on the cam-timer assy of the machine (if so equipped). Cam timer assy is behind the kick-plate, under the door.
Jun 25, 2008 | Jackson 24 in. JPX-300H Built-in...
CDC-X304 in permanent DEMO mode
I HAVE SAME PROBLEM. AFTER I REPLACED MY DEAD BATTERY MY AIWA CDC-X304 IS STUCK IN THE DEMO MODE. ONLY CD WORKS BUT ALL BUTTONS ON FACING DO NOT RESPOND. ANY SUGGESTIONS HOW TO RESET.
Jan 16, 2008 | Aiwa CDC-X304 CD Player
Fisher and Paykel DEGX1 Electric Dryer Logo
76 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
