Question about Canon PowerShot SD500 / IXUS 700 Digital Camera
Focusing wont work after dropping
Powershot s500 my son dropped the camera and at first the zoom would not retract...i finally fixed that but now none of my pictures will focus...is it doomed????
  • Anonymous Nov 09, 2007
    same problem,some times it says e18 and beeps
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 114 Answers
Probably the lens inside is damaged or the mechanism which moves the lens is damaged. Focus works with a moving mechanism which moves the lens back and forth.
Posted on Oct 08, 2007
SOURCE:
The camera was dropped on the lens and zoom won't retract
HI there, the camera lens gear is damaged from internal. So you must changed that. Other wise it gives you lot of trouble. Thanks.
Mar 12, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
I had the E18 error--lens wouldn't retract and
Focus problems are quite common after a lens error, it sounds like you still have an issue with that lens unit. If you need help, there's a great site taht just specializes in the powershot problems, nothing else at all. Try going to www.camerasandparts.com and you'll see the fix for this for your SD890 camera. I hope that helps, that site is amazing for the powershots and that's where a lot of people go for help with these. Good luck with it.
Feb 21, 2010 | Canon PowerShot SD890 IS Digital Camera
Hi, the zoom wont retract and it says focus error
It won't focus because ya lens is out of focus due to it being stuck had same prob wig my Sony worked out cheaper to buy a new camera than have it fixed.very fiddley to repair hope if bin some help
Nov 23, 2009 | Fuji FinePix A500 Digital Camera
Lens will not retract
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 11, 2009 | Canon PowerShot S500 IXUS 500 Digital...
PowerShot SD600 will not focus
If the camera was open (lens extracted) the camera lens may be damaged. If you can retract it (power off), then maybe it's just dirty. Can you zoom in or out?
Jul 26, 2008 | Canon PowerShot SD600 Digital Camera
Broken zoom
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
Jan 16, 2008 | Canon PowerShot A520 Digital Camera
Canon powershot S2IS
1>>u may have dropped the camera in some place.
2>>the camera POWER ON switch must have got pressed while the camera was inside pouch. if this has happened, the lens system gets jammed and so lens wont retract. for this problem it costs nearly 1800rupees in indian service center.
Dec 21, 2007 | Canon PowerShot A75 Digital Camera
Dropped camera lightly, lens wont retract
my acm dropped and i messed up the lsenes it wont go in please help me how can i fix it my self?
Nov 03, 2007 | Canon PowerShot A540 Digital Camera
Wont Focus
If its making a noise when you try to zoom in and out I would suspect physical damage. The more you mess with it the greater the chances of damaging it beyond economic repair. I would take it to the local authorized canon repair shop.
Jul 26, 2006 | Canon PowerShot S1 IS Digital Camera
Canon PowerShot SD500 / IXUS 700 Digital Camera Logo
220 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
