Question about Garden
I have a craftsman 10hp 32" trac-plus snow thrower and after about 15 min. of run time it quits running.I noted that the intake manafold was hot the touch so I thought yhe fuel was vabor locking.How c
It also has a 120v. electric start. I also noted that the exhaust muffler is just above the carburetor.
  • 51 Answers
Replace spark plug with a new NGK plug... Also check fuel cap vent to see it it's plugged, try loosing the gas cap a run it, if it stays running, you'll need a new gas cap.
Posted on Nov 18, 2013
4 Suggested Answers
  • 16 Answers
SOURCE: CRAFTSMAN SNOW THROWER DRIVE WHEELS WILL NOT MOVE
well if it is a walk behind style it could be the drive is out of adjustment, also craftsman were famous for the cable mounts bending and that will throw them out of adjustment. follow the traction drive linkage down to the base of the blowe and there should be an adjustment, or it will be under the belt gaurd or even on the handle on some.
Posted on Feb 04, 2010
SOURCE: possible carburetor problem? Mower runs for
i have a lt 1000 2005 when i start it with cold engine it boggs for a minute then it starts to run smoothly please help me
Posted on May 08, 2010
SOURCE: Motor runs for 5-10 min. then starts missing and quits.
I have GT6500 26HP runs for awhile begins miss firing runs on one cylinder, must be running hot ( fuel may be vaporizing ) removed the Hood and it runs fine.
Posted on Jul 28, 2013
I have a 26 in craftsman snow thrower brand new engine runs erratically hunting
The choke does not have to be all the way open on a snow blower engine. The choke control has notches or steps for that reason. With the engine running adjust the choke one notch at a time until it smooths out. Once the engine warms up you may have to adjust the choke a notch or two to keep it running smoothly.
Mar 11, 2017 | Craftsman Garden
Can I use 0w 20 Mobil 1 oil in my snow blower
It can be used, although the manufacturer recommends;
Super S 5W-30 Snow Thrower Engine Oil - Sears
www.sears.com/explorer-5w...snow-thrower...oil/p-07188298000P
Sears Rating: 4.5 - ‎5 votes
Oct 21, 2010 - Explorer 5W-30 snow thrower engine oil is a premium formulation for use in all four cycle engines when temperatures are below 32 deg. F. Explorer 5W-30 snow thrower engine oil protects the engine by lubrication, cooling, cleaning and sealing internal moving parts.
Aug 23, 2015 | Craftsman Snow Blower / Snowblower Bottom...
My craftsman snow thrower runs for about15 minutes before it requires more chock until it finally cannot run. Why is this happening
First i would check engine compression. It will change once it gets hot and cause you to use more choke until finaly it wont run.and if that is okay i would rebuild the carburator. A rule i use in my shop is to always check compression first then go from there.
Dec 13, 2014 | Craftsman Garden
Craftsman 32" 10 hp
3600+/- 20rpm. That's the top end, I'd say idle should be between 1200 and 1500, but I don't know what model motor it is. I'm assuming its a Tecumseh snow king engine
Nov 22, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Craftsman 32" 10 hp snow thrower
Around the back of the engine, just below the cylinder cooling fins. The shut off should face you if standing in front of the recoil starter, for the fuel tank. The fuel line should wrap around I the side of the carb and be protected by the metal cover surrounding it.
Nov 20, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Craftsman 8hp snowblower starts but will not stay running.craftsman 8hp electric start dual stage modle 536881800 snow thrower
Your snowblower carburator is gummed up. Go to an auto parts store and get a can of a carb. cleaner called seafoam. Follow the directions as far as how much to put into the snowblower gas tank. Run it for a few minutes and it will clear up. Regards, Joe
PS Please rate my answer. Thank you.
Dec 19, 2009 | Garden
Snow thrower won't stay running
Replace the spark plug being sure to use the plug recommended in your owner manual, and the gap recommended. Then clean or replace the air filter. Finally use high test, new gasoline. Not gas that has been sitting around for months. good luck
Jan 11, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
