Question about Electronics - Others
Lexar n12610 - Electronics - Others
Want to delete old photos from lexar
you will need to connect your lexar to your computer
click start click on my computer to open from there you should see your lexar then right click to select open you should see
the data / photo's in there select what you want to delete right click select delete or you can right click select format this will delete all data on hard disk
hope this helps
Oct 05, 2012 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
Lexar 16g pro 133 sd card in canon ixus 750 says memory error card locked which ever way slide switch is. card is ok in computer Help
I'm a member of the PR team. Sorry to hear you are having these issues. We'd like to help.
Lexar support can be reached via email: support@lexar.com or by phone: 1-877-747-4031(US and Canada) or 1-208-363-5862 (Outside US and Canada).
Sep 07, 2011 | Lexar Professional High-Speed 2GB Secure...
Lexar MDA256-100 RevA "Format Error"
i want to know how to correct reformatting of my lexar
Jan 16, 2010 | Lexar MDA256-100 MP3 Player
My mp3 player tells me incorrect format reformat the player?????
either it is faulty or u should reformat it. it should be easy. you can find instructions on the internet.
Aug 10, 2009 | Lexar MDA256-100 MP3 Player
My memory card won't work in my camerakeeps telling me to format the Lexar 2GB card every time I insert it
Use the camera to format the SD card not your computer. There should be a menu option to format it.
May 28, 2009 | Lexar Professional High-Speed 2GB Secure...
Transfer music from computer to lexar 1gb
You just need to connect the Lexar 1Hb to the USB port on your computer and let the computer recognize it and then after that double click Mycomputer and you should see there the Lexar , just double click on it and now you can copy and paste music from your computer to the Lexar...
Jan 02, 2009 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
Lexar card reader
yes surely sanddisk adapter will work with a lexar card reader.....
Dec 24, 2008 | SanDisk 2GB microSD Memory Card
Lexar mda256-100 player from bose
The solution is correct. I emailed support@lexar.com and received an email the next day with a firmware patch that reformatted my player.
Just an FYI, this did NOT work under Vista and since I had an XP media center laptop sitting next to me I didn't play with it. On the XP system it worked flawlessly. I ended up with a fully functional MP3 player again, nothing in the folder at all and it only took a minute.
Send them an email and I would expect you'd get a response within 1-2 business days. As mentioned, my response was within 18 hours.
Jan 06, 2008 | Lexar JumpDrive MP3 Player
Lexar MP3 player
Connect the device in Storage Device (USB Mass Storgae) Mode and then format the storage disc to FAT you can use the DOS command: format X: /fs:fat where X: is the storage disc drive letter.
Jan 29, 2007 | Lexar LDP-200 MP3 Player
Electronics - Others Logo
556 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
