Question about NexxTech (DR30G0) System
Main fuse on power board keeps blowing - NexxTech (DR30G0) System
Why will my hp officejet 6100 turn on it keeps blowing main fuses from mains plug
Short circuited component/s at it main power regulator board. Your printer needs service. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 17, 2015 | HP Hewlett-Packard - CB863AB1 Officejet...
Wy fuse keeps blowing
Fuses blown when an overload occurs. More often than not caused by a short circuited transistor in the main amp section. Possibly also on the power supply too.
May 22, 2014 | AMC Multimedia CVT-2030 2-Channel...
My 39 inch tv fuse blown constantly
Either a short or incorrect fuse being used--fuses have become specialized beyond amperage and voltage ratings--a lot are special fuses and or either a slow blow or even a thermal type fuse.
If not a fuse issue, look for a short in the power supply or wherever that fuse is located.
Dec 19, 2012 | Emerson LC391EM3 39 in. LCD HDTV
My emerson model lc320em2f keeps blowing the fuse on the circuit board what can cause this
Check the main power supply regulator board. It will have shorted component/s. That is why, the fuse blows up. In most cases, the components to these type of TVs are vary difficult to get from open electronic spare part market. So it will be best to replace the power supply board as card basis, rather than trying to get it repaired.
Jun 13, 2012 | Televison & Video
Arcam alpha 8 amp keeps blowing fuses
When the fuses keep blowing suspect an overload in the power supply or on the Main Power Amp board. Chances are that a semiconductor has developed a short and is acting like it was just a piece of wire. The main suspects are power transistors. These can be tested with an Ohm Meter, even in circuit! For when the test probes are applied to each terminal, the meter will act just like you were touching the probes together.
Sep 07, 2010 | Audio Players & Recorders
LaserJet 5550dtn Printer: blows mains fuse and power supply board fuse and b...
The fuse blows all time on High Voltage Poewr Supply, on HP Color Laserjet 5550dn,
May 16, 2010 | HP LaserJet 5550dtn Printer
My sd-533hd5 keeps blowing the 5 amp 125v fuses
Yes! it sounds like a power supply problem! or the flyback in the main board needs replaced ( part is in the $70.00 range
Dec 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
WT 46809
22 is a error code for a short protect which is triggering shutdown . Try unplugging the crt circuit boards and seeing if the fuses still blow when you press power.
Jun 22, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Main fuse blown on CT-32G11 32" Panasonic TV, Replacement fuses continue to blow.
If the main fuse keeps blowing, check the horizontal output transistor for a shorted condition and diodes in that section as well.
Jan 12, 2008 | Panasonic CT-32G11 32" TV
NexxTech (DR30G0) System Logo
Top NexxTech Audio Players & Recorders Experts
Josh Whitehead
Josh Whitehead
Pieter Vleeshouwers
Pieter Vleeshouwers
Willem.
Willem.
Are you a NexxTech Audio Player and Recorder Expert? Answer questions, earn points and help others
