Question about Sanyo Microwave Ovens
How to replace bulb,sanyo microwave mod. em-s7560w
How to change light bulb, sanyo nicrowave mod em-s7560w
tiway1
  • 100 Answers
SOURCE: Turntable motor - Sanyo Microwave Model EM-S8000W
There are actually two, both Panasonic motors...
Here are the full links...
http://microwaveglasstrays.com/shop/120v-microwave-turntable-motor-253w-b6326408ap-p-215.html
http://microwaveglasstrays.com/shop/120v-microwave-turntable-motor-6rpm-f63265g60ap-p-217.html
Here's the link to their main page for motors...
www.martinmicrowave.com
Posted on Sep 06, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Change light bulb in Sanyo Microwave EMS6786V
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Oct 20, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: light bulb replacement for sanyo ems3553 microwave oven
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Posted on Mar 06, 2009
  • 82 Answers
SOURCE: Changing Microwave bulb
Remove lid, you'll probably need a pozi drive screw driver and a tamper proof torx drive.
The bulb is located near the front.
Posted on Mar 16, 2009
SOURCE: REPLACING LIGHT BULB
i have a cookwork microwave the light stoped working
Posted on Apr 11, 2009
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ...
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
I purchased a Sanyo microwave oven (Model EM-S7560W; Serial # 1011USM42789 A) about a month ago and there was a card in the box that was titled "Record of sale, award or lease of microwave oven"....
I have no solution but did look up the Title 21 subchapter J as well. As with ALL federal regs and documents I did not have time to read a frickin book. Lol. I will continue my research on this as we purchased the same model Sanyo last week. Defiantly threw up a red flag for me as well. Just don't ask me to register my guns. Haha. Sorry I was not any help but if Dealers/Wholesalers are required to do this then we as consumers need to know what needs to be done if anything.
Mar 28, 2011 | Sanyo Microwave Microwave Oven
How do I change the lightbulb in the unit?
remove the screws holding the outer shell and carefully remove it.... the bulb should be accessable then. make sure the replacement bulb is equivelent to what is in the microwave now. do not operate the microwave without the cover on it. if possible test the bulb before you put it in.
Jan 17, 2010 | Sanyo EM-P410W Microwave Oven
How to replace light
there is either a panel on back of unit you can remove and light bulb is there, if not you will need to remove case to change bulb.
Nov 25, 2009 | Sanyo EM-S5002W Microwave Oven
Replace light bulb on SANYO EM-U1000W Compact Microwave Oven
PLESE BEFORE YOU DO ANYTHING RFER TO A GUI HOW TO DISCHARGE A HIGH VOLTAGE CAPACITOR OR SEEK THE HELP OF A MICROWAVE TECHNICIAN. As for changing the bulb, if you remove the case you will be able to locate the bulb, and merely a case or removing ad replacing with a new one. Good luck.
Nov 16, 2009 | Sanyo Microwave Ovens
How do i change bulb in sanyo microwave EM-SL30N What do i do must i take the cover off what is the easy way please.
Make sure it is unplugged. Yes you must take the cover off and you will see the bulb. Gain access to it and replace it. Do not interfere with anything else.
Nov 09, 2009 | Sanyo EM-Z2100GS Microwave Oven
Mar 15, 2009 | Microwave Ovens
Sep 16, 2008 | Microwave Ovens
Sanyo microwave mod # EM-2100GS
unscrew the unit replace fuse near the transformer. this fuse is for heating....
Feb 02, 2008 | Sanyo EM-Z2100GS Microwave Oven
Microwave Ovens Logo
24 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
robert landry
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
