Question about Simer A5000 Ace In The Hole Battery Back Up Sump Pump System
Looking for fuse in ace in hole pump - Simer A5000 Ace In The Hole Battery Back Up Sump Pump System
No power to fuel pump
I see that you posted the question yesterday. Hopefully by now you have resolved the problem.
If the problem still exists, check to see if you have power to the Fuel Pump Relay in the black plastic Relay Box located at the right front corner of the engine compartment. But first, give the box a modest tap with a hammer-like device. (A mechanic would never do that.)
If the relay is stuck, maybe time to replace it.
Write back with a status report. If we need to look elsewhere, let us know.
Sep 12, 2014 | 1997 Chevrolet Lumina
WHY THE PUMP WONT TURN ON,
It is possible that the pump itself has failed.
May 08, 2014 | Simer A5000 Ace In The Hole Battery Back...
No fuel coming up
See user manual or contact Service Professional(s).
Apr 23, 2014 | 2007 Toyota Hi-Ace 220
The flood light stays on and the pump will not work
Can anyone help? My Simer backup sump pump flood light is on continuously. All the rest of the lights seem to be working fine and the pump looks like it is in working order. When I toggle the lood light button it just gets brighter. tHANKS...SCOTT!
Jan 14, 2013 | Simer A5000 Ace In The Hole Battery Back...
1990 Town ace- where do they hide these parts?
WHAT MAKE, MODEL AND YEAR IS THIS.
Aug 28, 2012 | Cars & Trucks
Alarm won't shut off
This system does not have an alarm. The accessory alarm is something else. Check it's sensor and make sure it didn't get knocked into the pit.
Jun 30, 2012 | Simer A5500 - A5500 - Super...
My windshield washer pump isn't working on my 2006 Dodge Durango. I want to know which fuse to check for my windshield washer pump.
More than likely it's the pump itself. I say this because in a nutshell your pump is computer controled. It receives power through the CAN system on your vehicle. If it were just a fuse MANY other things would not be working. I would see if you are geting power and ground to the pump. If you are then replace the pump. If you are not you may be looking at the switch or a wiring problem or in the system itself. Wish I could give you just a fuse but it's not that simple on your vehicle. I gave you a descrition of how it works but it can be a little confusing.
Dec 10, 2011 | Cars & Trucks
2003 honda shadow 750 ace water pump gasket leaking. Can I replace the gasket only?
There is a round o-ring that seals the water pump to the motor (oil seal). Then there is a shaped cover o-ring that seals anti-freeze into the pump. The cover o-ring is also replaceable. If your pump has coolant leaking it is probably coming from a small weep hole in the bottom of the pump. Check where the leak is carefully, my guess is that the water pump seal is bad and you actually need to replace the water pump assembly. To see a break down of the pump look here.
http://www.bikebandit.com/houseofmotorcycles/2002-honda-vt750cda-shadow-ace-deluxe-black/o/m2894#sch94027
Mar 17, 2011 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
Toyota Town ace Diesel turbo pump continuously
is it the primming pump? if so replace it if its the the injection pump it may have to be removed and send to a service centre for repair. to save time and money you can look for a junk town ace with engine intact and take the pump from that once its ok
Sep 27, 2009 | 1992 Toyota Corolla
Simer A5000 Ace In The Hole Battery Back Up Sump Pump System Logo
103 people viewed this question
Top Simer Plumbing Experts
Renee Knafel-Bullock
Tom Chichester
Bill Boyd
Are you a Simer Plumbing Expert? Answer questions, earn points and help others
