31.13.02 Jam in document feeder - Office Equipment & Supplies
  • 186 Answers
SOURCE: Document feeder jam
if you open the cover where you feed in the documents to be copied, look on the back side of that cover and you should see a little black plastic piece that dangles from the cover. Make sure first of all that is is there, and it moves freely. This makes contact with a sensor when the cover is closed. And of course make sure the cover is closed tightly. Let me know if I can be of any further help.
John
Posted on Nov 25, 2007
SOURCE: Jam in the document feeder
I think I found my answer. You don't have to un do any screws. Lift up the cover to the automatic feeder. You will see a spring on the side of the mechanism towards the front; remove the spring; that will allow you to lift up the little arm the spring was attached to and remove the roller or bar and the light blue/green plate just under it. Then you will be able to see the jammed paper, which which I was able to carefully pull out with a pair of tweezers. Some was under rubber rollers, but when I pulled the paper sideways it slipped out. Now it works!
Posted on Mar 09, 2008
  • 2072 Answers
SOURCE: jamming of documents in autmatic feed for scan mode
One way to unjam that would be to take a stiffer plastic or manila folder and insert it slowly into the document feeder and the slowly push it through the feeder until you dislodge the jammed document out of the bottom of the feeder.
That is a common practice in removing jams in the feeder.
Posted on Mar 14, 2008
SOURCE: paper jam in the automatic document feeder
I have a Laser Jet 3050..when I try to load a oaoer to copy or fax, paper does not move...just gears moving but paper is not being pick up...any solutions?
Posted on Feb 20, 2009
SOURCE: HP laser jet 3055 document feeder jam
document feeder jam
Posted on Jul 27, 2009
What does ADF document mean?
"Document in ADF", usually means that there is a document in the Automatic Document Feeder. Or to put it differently, there is a paper jam in the document feeder (probably of the scanner part).
The fix is to check the feeder and clear the jam. Sometimes it indicates there is a piece of paper stuck or a faulty paper detector.
Dec 26, 2014 | Office Equipment & Supplies
An automatic document feeder paper jam has been detected
my scaner icon window show this messege:
an automatic socument feeder paper jam has been detected. clear the jam and try scaning again
Jan 13, 2012 | HP Scanjet 5590 Flatbed Scanner
Canon imageclass D1120 printer says: feeder paper jam,
Hi Try this method
To "Settings/Registration Table"
You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
  1. Press b_in_add.gif(Settings/Registration) ? [Function Settings] ? [Common] ? [Scan Settings] ? [Feeder Jam Recovery Method].
  1. Select [From 1st Page] or [From Stopped Original] ? press [OK].
Details of each item are shown below.
[From 1st Page]: If a paper jam occurs in the feeder, scanning starts again from the first page of the document. [From Stopped Original]: If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
Jun 10, 2011 | Canon ImageCLASS D1120 All-In-One Laser...
Dell 1815dn jam in automatic document feeder on last page.
Message saying document Jam but can't find any paper stuck anywhere. Do you have any suggestions?
Feb 06, 2010 | Dell 1815dn All-In-One Laser Printer
Doc. feeder jam, after paper removed completely
HP LaserJet 3030 All-In-One Printer
Mar 11, 2009 | HP LaserJet 3030 All-In-One Printer
get rid of that hp piece o crust. demand your money back.
Mar 01, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Paper jam in the automatic document feeder
Aug 01, 2008 | HP LaserJet 3050 All-In-One Printer
Jamming of documents in autmatic feed for scan mode
Mar 13, 2008 | Office Equipment & Supplies
1,661 people viewed this question
jasbo
jasbo
