Question about eMachines EL Computers & Internet
Fan is too loud
If there is more than one fan, I think that it's the power supply fan because the loudness is constant.
  • eMachines Master
  • 27,725 Answers
Every computer comes built with a processor cooling fan system.
The fan's main function is to keep the processor from overheating.
After long periods of use, processor fans can start to malfunction.
If your eMachines computer's fan is excessively noisy, it will need some maintenance.
If you don't deal with a noisy fan promptly, your computer's processor could overheat and cause significant damage to your motherboard as a result.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
Power down the computer.
Disconnect all cables and peripheral devices from the computer's back panel.
Rotate the computer so the back panel is facing you. Lay the computer on its left side.
Remove the Phillips thumb screws that fasten the right side access panel to the computer's frame.
Remove the side access panel from the computer to reveal the motherboard and all internal components.
Locate the cooling fan assembly near the center of the motherboard.
Remove all Phillips screws fastening the fan to the motherboard.
Disconnect the fan's power cable from the motherboard.
Then lift the fan out of the computer.
This will reveal the processor chip.
Place the fan on a flat work surface with the label sticker facing upward.
Use a thin, flat-head screwdriver to peel away the label sticker from the fan.
This will reveal the access hole to the fan motor's bearings.
Apply one to two drops of lightweight mechanical oil into the fan motor's bearings.
Replace the fan's label sticker.
Use a can of compressed air to spray the dust and debris from inside the fan blades.
Place the fan back into the motherboard on top of the processor chip.
Replace the retention screws and reconnect the fan's power cable to the motherboard.
Replace the side access panel and its two retention thumb screws.
Place the computer tower vertically, and then reconnect all cables and devices to the computer.
Posted on Nov 18, 2013
4 Suggested Answers
Crankstart
  • 696 Answers
SOURCE: Fan makes loud noise after computer warms up. I do not want to purchase a new power supply. Can and where can I purchase a new fan and can I easily inststall it?
**** is right in general it's not much more to replace the whole unit.
This unit however is a pain due to it's unusual size and high price.
Although typically I advise recycling the old one and buying a new one this is one of those rare cases where the repair would be significantly cheaper.
Two major issues to be aware of if you plan to attempt a repair:
1. size is not the only thing that matters, you must find a fan that within 1/10 of a volt and amp matches this one and it must have as greater or greater airflow
2. orientation is everything. before removing the old fan verify which direction the air is blowing and be absolutely sure to put the new one in the same way as the change in direction may bugger airflow not just for the AC but for the whole unit.
If you're adept in repairs including saudering PCB boards, go nuts and have fun. If not your best bet is actually a stereo repair shop as most computer techs these days don't own let alone use a saudering iron. Stereo repair guys typically sauder new fans fuses and other small components far more often than us computer guys who tend all too often to toss parts rather than repair them in order to save ourselves time and our customers money.
Chris Armor-IT
Posted on Apr 24, 2009
luis356
  • 53 Answers
SOURCE: Fan runs constantly
one reason that a CPU fan may be running constantly is that it may not be able to cool the cpu down. usually this could be due to dust or debri clogging the incoming or outgoing vents or even dust accumulated on the fan itself or the heatsink.
Posted on Jun 03, 2009
SOURCE: dell dimension 4700 power supply fan has gotten very loud
All the above answers are correct to some extent. Problem is that your fan hasn't stopped. It's hard to diagnose something that isn't broken.
Depending upon how critical the computer and your finances, your fix could be:
1: Do nothing and wait for it to stop working.
2. Spray fans with DW40 and wait for it to eventually stop working.
3. Replace first one, then the other fan.
4. Replace both fans at the same time.
5. Replace computer.
Posted on Jun 03, 2010
Loud buzzing noise.
IT SOUND LIKE YOUR lamp ballast IS FIXING TO GO OUT ON YOU OR YOU HAVE SOME BAD CAPS IN POWER SUPPLY LOOK OVER TO SEE IF THAT IS YOUR CAPS BUT IAM THINK IT LAMP BALLAST
Dec 24, 2013 | Televison & Video
Compaq presario desktop sr1503wm fan at rear of cpu box won't turn. can it be fixed or replaced? apparently the other fan is overworking and causing a loud buzzing which goes off and on again every few...
If it is the fan in the power supply, replace the power supply.
The case fan is easily replaced. Measure it (in mm) and purchase a new one. The standard fan is usually 40 mm, I think.
Oct 07, 2010 | HP Compaq Presario SR1503wm PC Desktop
Desktop computer fan runs constantly
Desktop fans do run constantly, you cannot avoid this.
The reason they get loud is because there will be a build up of dust on the fan blades.
To rectify this problem turn off the computer and remove the power cord from the rear. Then you need to remove the side panel from the base unit to expose the motherboard.
You will see that inside the case it is full of dust. Look at the CPU fan (the fan on the motherboard) also take notice of any case fans too, they are at the back.
To clean the fans and the case you can use a clean dry paintbrush or compressed air.
Once the inside of the case is cleaned you will see a noticeable drop in noise.
Regards.
Jul 03, 2010 | HP Compaq Presario SR2150NX PC Desktop
I have a Presario SR1950NX that is not booting. After turning on power, the fans come on and the DVD drive flickers, then nothing else happens. The keyboard and maonitor stay dormant. Normally, a loud fan...
It may be the clogged fan that caused this problem then resulted to overheat. possibly you need to replace the motherboard. or first, try using a bootable cd to boot your pc up. it may also be an issue with your hard drive not booting up.
Mar 29, 2010 | HP Compaq Presario SR1950NX PC Desktop
Emachines shuts itself off.
This sounds like either a power supply issue or a CPU fan issue to me. You say you hear a fan spinning loudly. Try and determine which fan it is. Take the left side panel off your case and start your game. When the fan gets loud identify which one it is. It's possible that the heatsink on your CPU is clogged up (pet dander, dust, smoke, etc.) and needs to be blown out. Get a can of compressed air and try blowing out the inside of your PC. It's possible your CPU/video card/power supply is just getting too hot.
Dec 24, 2009 | eMachines T3604 PC Desktop
Ultra 350 Power supply very loud fan
It's not normal for the fan to be loud, what makes them loud is either a build up of dust on the fan blades or the bearings are going on the fan itself.
If the PSU is working fine then you can replace the fan itself from an identical PSU. It does mean taking the PSU out of the computer and fitting the fan yourself.
Alternatively you can purchase another PSU.
Regards.
Aug 30, 2009 | Ultra (9PA3501609) 350-Watt Power Supply
Loud fan and wont turn on
power supply is probably shot and you are feeding a voltage way over what is needed. I have a dell that refused to operate one day. I went to www dot affordablesurplus dot com and found a 350 watt power supply with all the RIGHT plugs. Never had a problem since.
Dec 04, 2007 | Dell Dimension 8400 power supply ** FREE...
Computers & Internet Logo
138 people viewed this question
Top eMachines Computers & Internet Experts
brian soufane
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
