Question about Poulan Pro 25CC 2Cycle Gas Blower
Can Poulan pro BVM210VS pull rope that won't retract be fixed and how?
  • 21 Answers
SOURCE: Poulan rope broke and pulled out of unit. How is
I have manually fixed these starters before and it is really more trouble than it is worth (and not one unit I fixed ever worked exactly the same afterwards). I would suggest taking it to your local small engine repair shop. They have both the patience and the tools to do the job right and the cost is well worth it--trust me!
Posted on Nov 06, 2009
rwvanlue
  • 486 Answers
SOURCE: Hi, I have a Poulan gas blower, the rope will not pull out
remove spark plug for inspection
1) silver or aluminum color
STOP the piston is seezed. TOO costly to repair
2) plug dark brown or black (pretty much normal)
remove recoil housing for tangled rope or broken rope rotor
Posted on Nov 08, 2009
Testimonial: "Thank you very much for your help, I did just what you said. The spark plug is brown, so that's good news!"
SOURCE: reattach pull cord for poulan pro bvm200vs
how to replace cord in apoulan pro gas blower
Posted on Mar 27, 2010
blueextc3221
  • 15935 Answers
SOURCE: pull rope came out of poulan pro blower
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 13, 2010
HansPP
  • 2510 Answers
SOURCE: I have a poulan/Weed-Eater blower
Try a now spark plug first. If it is still hard to start then it is probably because of low compression due to worn rings and these need to be replaced.
Posted on May 22, 2011
How do I replace the pull cord to my Poulan 446T PRO. It's a combination of a pole chain saw (8 inch) and a trimmer.
You will take the recoil assembly off the saw. You shoud see where the knot broke off the cord in the pulley. Put the cord through the case and the small hole in the pulley and tie a new knot. Count the number of turns it takes to take up the rope. There should be a small notch in the edge of the pulley you place the rope in to wind up the spring and not take up the rope.Add one or two turns more than you counted so the rope is coiled up snug then pull out the rope from the notch and let the spring retract it.
Aug 02, 2013 | Garden
Poulan lawn mower cord won't retract
New or used unit? If new can you return it ? If not you will need to take the recoil assembly off the engine and rewind the spring. Check inside the recoil assembly to see if the spring is broken or just popped out of place on either end. If it is broken your done. You will need to find a Poulan dealer to get a new spring. If new take it to a Poulan dealer for warrenty replacement. If you want to try to rewind the spring look to see where one end of the spring fits into the housing and the other into the spool. On the edge of the puley should be a notch. Place the rope in the notch and turn the pulley it in the direction needed to wind the spring about 4 or 5 turns. If it now pulls all the rope in you are done.If not put the rope back in the notch and wind the spring tighter till the rope is all pulled in.
Jul 25, 2013 | Garden
My Poulan Pro 150E pull cord will not engage to start the weed eater. The rope comes out adn retracts back with no problem, but there is no pressure on the clutch to cause the motor to start. There is...
Sounds like the starter dogs are broken. They are little plastic teeth that engage to turn the engine when you pull the cord. You'll need to replace the whole starter assembly to fix this.
Aug 26, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Attempted to start unit, second pull, the pull rope seized up and would not release or retract. Approximately a foot of rope hanging loose.
It has either broken the starter spring, or the pulley has jammed in the flywheel, remove the cover screws and take away the starter, if the c ord then retracts it was jammed, if not, slacken the centre fixing screw, does it retract now , if so the centre post is worn, and the fixing screws is clamping the pulley before it bottoms out on the top of the post, if it still does not retract, remove the centre screw and pulley, check the spring behind has not broken, be careful as it is a long spring under tention.
Jul 19, 2011 | Poulan 14" Chainsaw
Rope will not retract.
I am assuming you tried to pull start and the rope is stuck out. Just try pulling the rope while it is out, but stand on the hedge trimmer. Sometimes when this happens to me, I just pull the rope a little extra and then hang onto it when it goes back in. Alot of times, I think the rope gets caught on the outside of the retraction pulley causing a tangle.
Aug 05, 2010 | Poulan Ght225 25cc Gas Hedge Trimmer
The rope doesnt retract after pulling it to start. it will slooowly retract while it sits.
The pull cord is catching inside the housing or the mains spring is damaged it needs a miny service
Jul 17, 2010 | Poulan Pro Gas BlowerVacuum ()
The pull cord will not retract back into the saw. When I tried to start the saw, I pulled the cord and now it did not retract back. It is all the way out and will not recoil.
When I have had this happen it means that you need to manually rewind the cord and put some additional tension on the take up pulley. To do this you'll have to open the saw up and untie the handle. Turn the pulley like one turn, put the rope back through the hole and tie the handle back on. All this is done while maintaining tension on the rope.
Feb 05, 2010 | Poulan Pro Chain Saw 46cc 20"
Starter rope will not retract.
inside the rope pull housing is a flat spring,it may have come loose from its anchor, its an easy fix...unscrew the 3 screws on housing, lift off housing, and the rope pull is inside the casing, you will then see if its broken, or just come off anchor, 10 minute job if its just loose......
Jul 21, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Pro 25CC 2Cycle Gas Blower Logo
49 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
