G-Sonic aux code sound bar
I need the code for a g-sonic sound bar for my remote control
SOURCE: Sentry RMC-10 "Really Big Remote"
try this site and download the codes...good luck
Posted on Aug 28, 2009
  • 108 Answers
SOURCE: Replacement Remote Control
This site may have what you are looking for. www.electronicadventure.us
Posted on Sep 07, 2009
diodeic
  • 1622 Answers
SOURCE: I just had a Telus
Common faults are: some buttons not working, not working at all, corroded battery terminals. Often buttons are sticky because of some dirt accumulated over the years from the sticky little hands of your kids?
The hardest part of repair is often to open the covers. You do not need much experience in electronics repair to repair a remote. Also it is perfectly safe as there is no way to get an electric shock as they work with batteries.
step 1Test your remote with Digital Camera
Check your batteries first or buy new batteries. Once you have good batteries, you can test with a digital camera by pushing the buttons and having camera on and pointing to the infrared led. You should see red light if the remote is working. If no light comes up you obviously have a dead remote but do not despair and proceed to the next step
step 2Open the remote control but there is a catch or a few catches.
Remove the screws if any. Sometimes screws may be hidden under a sticker or rubber feet. Often there are no screws at all but just plastic catches hidden so you have to be clever to open it without breaking the case. Use something blunt and flat to click the covers open. This is often a challenge but should not be too difficult.
step 3Take a picture of every phase so you remember how to re-assemble
Since you are using a digital camera you might as well take pictures of the dis assembly so re-assembly will be easier.
step 4 Pull everything apart
Did you take a picture of the keypad layout? Sometimes keypad is just one rubber membrane but sometimes the keys fall away like pieces of a Lego puzzle. And if the buttons are marked with numbers and functions you may struggle to re-assemble them in right order? Use a small plastic takeaway box or similar to store the bits so you don't lose parts.
step 5 Inspect the circuit board and repair dry joints
Remotes are often dropped on the floor and may develop dry joints on the battery contacts or circuit board. Inspect the contacts and circuit board under good light with a magnifying lense or if lucky you might have a microscope or just a very good eyesight? Solder all suspicious joints. If there is a sign of water damage you can use methylated spirits and toothbrush to...
step 6 Wash the covers and the buttons
Use a small bowl or similar to wash and contain all the parts so you don't lose bits down the drain. Use old toothbrush to clean all button holes and buttons. Warm water with dish wash liquid does the job. Take particular care with those small buttons and clean them properly. If you can leave the bits to soak overnight they come clean easy. Ultrasonic cleaner would be goo...
step 7 Rinse, drain and dry the parts
Rinse with warm water. Use a drainer to contain all the parts without losing small bits down the drain. As extra security use sink plug. Dry with a paper towel. Wipe the buttons dry individually as they may still have some dirt which makes them sticky when in use.
step 8 Repair case and re-assemble
If there is damage to the case or buttons you need to do the required repairs. Use hot glue or super glue depending on fault. Let dry overnight if you had to glue something. Re-assemble bits in reverse order and make sure you have the buttons in right place and right way around. Small nicks and dents on plastic cover can often be repaired by heating carefully with a h...
step 9 Test with Digital Camera
Test every button as before. Sometimes you have to push two remote buttons simultaneously .
That's it, I hope you got it going again?
Posted on Dec 17, 2010
danbusa
  • 185 Answers
SOURCE: I HAVE A VIZIO SOUND
Hello, Daniel Busa with Dish Network's customer service try these steps if the remote will program this will do it
Posted on Dec 29, 2010
raycalo
  • 358 Answers
SOURCE: I am looking for the
ronwright22
I have provided a link for you to Vizio's Website. The information below is for a VSB210WS sound bar. I would go to this link and research your model number and look for the code. You may try the code on this screen to see if it will work. I have also provided a link with instructions on programming your DISH remote to other components.
Vizio Website:
http://www.vizio.com/vsb210ws.html
This is the VSB210WS sound bar.
Programming a Universal Remote to operate the HD Sound Bar System If you own a VIZIO TV with a Universal Remote that uses a 5-digit programming code, you may program a device button with code 31517. This will map the Universal Remote button to operate the HD Sound Bar System as follows: Pictured at right is the VIZIO VUR8P Universal Learning remote.
Ray Calo
DISH Network
Posted on Jan 22, 2011
I need the remote code for Cox remote to control my g-sonic sound bar
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Dec 31, 2016 | Televison & Video
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Your remote reprogramming woes solved - Rogers RedBoard
redboard.rogers.com/.../your-remote-reprogram...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
HOW DO I BUY A REMOTE CONTROL FOR MY SEIKI SB201C (2.0) SOUND BAR
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability.
Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Jan 11, 2015 | Televison & Video
Code for huayu rm-36e+) for Sonic tv
Try code 014 and sonic blue 148
Aug 17, 2013 | Televison & Video
I need the cox remote code for philips sound bar css 2123/f7
I too need this code, if such a code exists. I have found several that control the mute and volume, but none so far control power.
Jul 19, 2012 | Televison & Video
I need the code to use a universal remote for a Soniq QV420PH 42" tv
Hello
Three digit univeral remote code for Sonic TV is: 014
Four digit universal remote code for Sonic TV is: 0014.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
OK.
Jun 28, 2011 | Televison & Video
I Have a 5.3 IR Remote and a vizio VSB200 Sound Bar. The remote will not program to the Sound Bar. The Optical Audio is connected to the TV. What do I need to do.
lojr,
We have code to use with amplifiers, TVs, VCRs, and DVD players. I do not have a code that will work on this sound bar. What is the code you are trying to use? Did Vizio supply a code with your sound bar. They do have codes to use for their TVs to program DISH remotes. Please let me know if you have a code or you can contact Vizio to see if they have a code available.
I have provided the Power Scan instructions on programming the remote to a sound bar. Use the VCR button to attempt to program the sound bar.
If you have further questions, please post it here.
Ray Calo
DISH Network - Executive Offices
Power Scan Instructions Power Scan Instructions
1. While at the sound bar location, point the remote at the sound bar. Press and hold the VCR MODE button on the remote until all four MODE buttons at the top of the remote light up.
filestream.ashx?id=435
2. Press the RECEIVER POWER button on the remote.
filestream.ashx?id=436
3. Press the UP ARROW on the remote, about one press every two seconds. Stop as soon as the sound bar turns off. This process may take several minutes.
filestream.ashx?id=438
4. Press POUND (#) on the remote. The VCR MODE button will flash three times.
filestream.ashx?id=440(VCR button instead of TV button)
5. Press VCR MODE button, then red TV button on the remote to turn on the sound bar. Press VOLUME on the remote to confirm the remote controls the sound bar. If this does not work, return to Step 1.
filestream.ashx?id=442
Remember to press the SAT MODE button to return to the Satellite mode to change channels.
Jan 13, 2011 | DISH Network IR Remote Control
Need dish code for remote for vizio soundbar
Hey there, this is Cheri Torres with DISH Network customerservice. I wanted to see if I could help you with the question you posted aboutthe Vizio sound bar. I was unfortunately not able to find any codes for theVizio sound bar. Another option you can try is running a channel scan to findyour code that will work best to control your sound bar. I hope that theseinstructions are useful to you. If you have any further questions or concernsplease feel free to post back here or email me at Cheri.Torres@Dishnetwork.com.
Remote: All Remotes (except Basic)
    1. With the desired equipment on, press and hold the correct Mode button until all mode button back lights illuminate, then release.
    2. Press and release the Power button. AUX Mode: Before pressing and releasing the Power button
      • Press 0 for a TV
      • Press 1 for a VCR/DVD
      • Press 2 for any other device.
      Then Press STAR (*)
    3. Press the Up button once a second while pointing the remote at the desired equipment. Note: If the code for the equipment comes up, the equipment will power off.
    4. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
Dec 27, 2010 | DISH Network IR Remote Control
I need codes to program my vizio sound bar to my dish remote
need 3-digit code to program Vixo sound bar to Dish Network 5.4 IR remote
Dec 16, 2009 | DISH Network IR Remote Control
Codes
I NEED CODES TO PROGRAM MY TV W/ REMOTE CONTROL URC-4021BOO
Jan 29, 2009 | One For All URC-4021 Remote Control
Televison & Video Logo
628 people viewed this question
Top Televison & Video Experts
Electro Med Services...
