Question about KitchenAid KEBC107 Electric Single Oven
Oven light switch
Oven light will not come on when the oven door is opened or when the "oven light" switch is turned on.
  • 2,113 Answers
Replace the bulb with an appliance bulb found at any store that sells bulbs
Posted on Nov 18, 2013
Oven light will not turn off
There is a door open sensor in all ovens and also some have a override switch so you can turn the light on without the door open, the door switch must be sticking or it is defective electrically.
Oct 14, 2016 | Ovens
Is it still safe to use as the light is broken, I have tried 3 bulbs.
Hello Carol;
My name is Peter. I am retired field service appliance technician.
Your oven requires a special oven utility bulb. If you have used common house hold bulbs they can not handle the heat.
Lets assume you did use a special utility bulb. On the face of your oven when you open the door is a little plunger button (Switch). This is may be a dual activation switch if you have a self cleaning feature. So, you will have either one circuit for the light or two circuits, one for self cleaning and one for the light.
The circuit for the light is a separate circuit and is strictly for the light to turn on when you open the door and turn off when you close the door. You can operate your oven safely without the light working.
You may have a short, but I will bet on a bad oven door switch.
Go into the following website and put in your model number. You will get diagrams and component part numbers.
Your model number is located on a label either on the face of the oven when you open the oven door or on the side of the door. Water Filters Lawn Garden Appliance Parts
Mar 11, 2016 | Neff Ovens
Oven light stays on all the time even when oven off.
Does your oven have a switch on the front panel for "oven light" or "light" ? If so, pushing it may turn the light on and off. Also, there may be a pushbutton on the oven's front edge where the door fits. The button comes out when the door is open and turns the light on. If you have one of those, the switch could be broken or defective. If the button is missing or damaged, it could leave the light on all the time.
Mar 22, 2014 | GE Monogram® ZET1PLSS Dual Single Oven
Oven is model 665.95781. I used the cleaning cycle.Oven door will not open. Message is E1 F5. Please help!
Based on your description, the E1 F5 error code likely indicates that the door latch is not operating.
Make sure that the oven door is closed when you start the Self Clean cycle. Check the door switch to see if it is apparently operating properly. Open the oven door and the oven light should turn on. Press in the door switch plunger and the light should turn off. If the light switch is not operating properly, it could cause this type of problem.
If the light switch is operating properly, then you could have a failed door latch assembly. A wiring failure or a problem with the control board could also cause this failure. I recommend that you unplug the range and access the door latch assembly at the back of the range. Pull the upper and lower back panels off of the range. Caution: The edges on these panels can be sharp. Protective gloves are recommended. With the panels off, check the wire harness connections on the door latch assembly.
Mar 20, 2011 | Kenmore Ovens
My frigidaire gas range has a F90 on it when I tried the self cleaning oven feature
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 16, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven Light is opposite what it should be
try reversing the wires on the door switch or replacing it
Mar 28, 2008 | Ovens
Oven Light does not turn off
The problem is due to a faulty door switch, this is part of the door lock mechanism. The reason is that the oven thinks the door is open , this puts on the light and stops some of the oven functions ie the fan the fan element and probably the bottom element.
The answer is to fit a new door lock mechanism.
Mar 08, 2008 | De Dietrich DOP390 Pyrolytic Electric...
5 year old Jenn Air double oven
the door switch contacts are stuck closed causing the oven to stay on.if you can access the door switch try to wd-40 on it.if that doesnt help you need a door switch.
Aug 16, 2007 | Jenn-Air JMW9527C Stainless Steel Electric...
KitchenAid KEBC107 Electric Single Oven Logo
88 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
