Question about HP LaserJet Office Equipment & Supplies
Spilled water - LaserJet HP Office Equipment & Supplies
    New Friend:
    Problem Solver:
  • 14 Answers
Clean it up, replace paper and toner is necessary. Let it dry out. Test it.
Posted on Dec 03, 2013
I have Macbook pro and spill water.It is now 6days and dying out.Very hard to remove battery as Macbook has 6-8 screws to remove batteryMac book is only year old.Is there any easy way to start without
Was it just water or was there any salt or sugar in the liquid water? Did you set the Macbook vertical ( so the water would not sit on the motherboard?
BTW: The first thing you should have done after water spillage was to remove power and the battery!
http://www.wikihow.com/Save-a-Laptop-from-Liquid-Damage
Feb 03, 2013 | Apple MacBook Pro Notebook
Washer doesn't reach enought output pressure. motor starts and stops at rendom.
First you have to do is try the machine without load. Attach everything as usual but do not attach the lance. Put on machine with water supply already on. If you close the gun the machine should stop. If you open the gun ( always with out lance)....the machine should start sending the water a bit far. If this is OK....then you have a lnance with a faulty, blocked NOZZEL.
NOrmally the machine stops when gun is released because there is a valve (Spill Valve) that actuates a electrical micro switch. This in turn closes off te elecreic supply...stopping the machine.
If with out lance your problem is still there....then the spill valve is faulty. AS I first said you must be sure that the nozzel is OK, so that you can blame the Spill Valve.
I raely service Spill Valves (Control Valves). I change with a new one. When open the cover using a TORX T15 screw driver....you locate the spill valve where there are 2 wires coming out. Some machines have the spill valve incorporated with the head and the intake and delivery valves unit. This I advize to change with new parts. These all in one heads are very good because at one go you change the spill valve and the other valves in one go.
Therefore in a few words you either have a blocked nozzel...or you have the spill valve faulty.
Also the delivery valves could be blocked...thus creating pressure inside and activating the spill valve to close off the electricity. You can also try to start the machine without gun and hose attached...but always with water being fed. NEVER put on a power washer without water being fed. And never store a power Washwer withpressure in it.
Fulltech.
Apr 25, 2011 | Karcher K2.26 Electric Power Washer
Karcher G2600 VH - low water pressure
If the spill valve activates is "spills" water under the washer. There is a restriction or the pump has become inefficient and will not pump the volume and pressure it should at full RPM.
Jul 20, 2010 | Karcher G 2000 MK 2000 PSI 20 GPM 87cc Gas...
Water won't come into the dishwasher
The anti flood system could have been triggered due to a water leak or spill at the bottom of the washer, This device (polysireene float and micro switch) when triggered shuts off the inlet water and puts the washer in pump out mode only. Use a torch and check if a small amout of water is causing the float to trigger the microswitch attached to the float. If a small amount of water leak / spill is causing this you need to first fix the spill / leak. before you try again.
Apr 21, 2010 | Crosley 24 in. CDU600 Built-in Dishwasher
What do i use for a roundup wedd killer spill?
From MSDS:
      SMALL SPILL: Soak up spilled material with paper towels and discard in trash.
      LARGE SPILL: Liquid spills on floor or other impervious surfaces should be contained or diked, and should be absorbed with attapulgite, bentonite or other absorbent clays. Collect contaminated absorbent, place in plastic-lined metal drum and dispose of in accordance with instructions provided under Section 13. "DISPOSAL". Thoroughly scrub floor or other impervious surface with a strong industrial type detergent solution and rinse with water.For liquid spills that soak into the ground, contact the applicable Federal, State and or County Health Dept. for disposal recommendations. If disposal is required then refer to Section 13 "DISPOSAL" for instructions.
      Leaking containers should be separated from non-leakers and either the container or its contents transferred to a drum or other non-leaking container and disposed of in accordance with instructions provided under Section 13 "Disposal". Any recovered spilled liquid should be similarly collected and disposed of.
      Do not contaminate water, foodstuffs or feed by storage or disposal.
      GENERAL PROCEDURES: Observe all protection and safety precautions when cleaning up spills -- see Section 8. "EXPOSURE CONTROLS/PERSONAL PROTECTION". For help with any spill, leak, fire or exposure involving this material, call day or night (800) 225-2883.
Dec 31, 2009 | Home
Water spilling
If water is spilling from the soap tray, try closing the water supply taps a little. Your water pressure may be too strong for the machine...common issue for front load machines when being used on water lines that have not been properly regulated.
Aug 05, 2009 | LG WM-2277HW Front Load Washer
Pressure washer lacks pressure initially?
Dear allbusiness9,
This problem is most probably due to a faulty Spill Valve( also called Control Valve). When the gun is released the spill valve is compressed and it either closes a micro switch or just opens from the bottom and keeps the water circulating. All spill valves keep the water circulating from the bottom part. Now when the gun is pulled (opened)...the spill valve extends and closes the bottom part, and thus water goes out of the nozzel. When you work with no nozzel, there is enough water flow to close the bottom part of the spill valve. So when the nozzel is placed back there is no chance that the bottom part leaks water. When the gun is started with the nozzel....the bottom part of a FAULTY spill valve,..will colapse and pressure drops. So to fix the fault you must change the Spill Valve. In some occasions, I also found that suction valves give this problem. A faulty sucktion valve will colapse under high pressure, and lets water pass the other way round.
But in my opinion and experience, your problem is in the Spill Valve.
Regards,
Fulltech.
Apr 23, 2009 | Karcher 2500 PSI Pressure Washer
I have an old kew pressure washer and when I pull the trigger on the lance, the water jet is only at mains pressure.
Dear dennis_partr,
In general all pressure washers have a control valve. This is sometimes refered to as the Spill Valve. When the trigger is pulled, the spill valve is in normal position. When the trigger is released, the spill valve compresses to let water circulate from its bottom part. If when the trigger is pulled and the bottom part of the spill valve does not close, then water keeps on circulating and hence no pressure. In this case change the spill valve with a new one. Also there could be a fault in the sucktion valves. If the sucktion vaves do not close, also water keeps on circulating. One also can examine the delivery valves. If these are not closing, then water is being sucked while delivering. Hence no pressure. Another cause but very rare, is that the swash plate that is pushing the pistons got loose. The electric motor will be turning, but the pistons stay in the same position.
I mentioned many causes, but usualy it is the spill valve. If with a new spill valve, there is still no pressure....then you must tackle the sucktion and then the delivery valves.
I wish to add that I assume that you have the correct lance and correct nozzel size. A worn out nozzel, will result in low prssure too.
Regards,
Fulltech.
Apr 21, 2009 | Electric Garden
PC damaged by water spill
Presuming that the water spilled on the actual pc, and it is no longer functioning whatsoever, you should contact the manufacturer (dell in your case) if you still have a warranty on it.
Dec 27, 2007 | Computers & Internet
27 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
