Question about Bosch Axxis WFL 2060 Front Load Washer
My washer doesn't heat the water even on power boost; the door remains locked after every cycle and would not open even after several hours. Thank you very much!
I drain water from drum and read out say's open door and you hear door release active but door will not open.
Posted on Feb 26, 2008
May 19, 2012 | Washing Machines
Feb 26, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Aug 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Aug 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The door will remained locked while draining water. If during installation the washer was plugged in and turned on without water hoses attached, the washer may attempt to drain for 8 minutes before the door unlocks. Let the washer run until the door unlocks. Do not turn off the washer or unplug the washer.
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Select Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle. For models that have Rinse/Drain & Spin, push the Extra Rinse button to turn off the rinse to remove excess water.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
Trying to gain access into a locked door can be a bit frustrating. Upon researching your question I found some links that may help you unlock your washer door. I attached all links below. I hope this helps!
http://www.managemylife.com/mmh/questions/204092-how-do-i-get-the-door-open-on-my-kenmore-washer
http://www.managemylife.com/mmh/questions/220303-does-front-loader-door-open
http://www.managemylife.com/mmh/questions/134692-why-wont-the-door-open-on-my-kenmore-frontloading-washer
Jun 10, 2011 | Washing Machines
Apr 27, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Oct 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Jun 22, 2007 | Bosch WFMC 3200 Front Load Washer
141 people viewed this question
I have the same problem. Mine will work just fine but only using cold. When set to any other setting will fill with just a little water. Stop. Then remain locked.
Any suggestions.
