Question about Marantz Televison & Video
How to open rc7200sr
How do i open the remote so that i can service it. particularly under the lens that covers the display
  • Marantz Master
  • 6,694 Answers
Posted on Nov 05, 2015
  • Bojan Dobravc
    Bojan Dobravc Nov 09, 2015
    Sorry, the Q was "How to OPEN" specific remote control unit. BTW, RC7200sr has NO screws, but 3 deep indentations with "empty" hole in each. Exactly as if screws are missing, but they obviously don't. Very odd system.
    Your answer is generic and about another skill, cleaning.
Samsung digital cam shutter not closing fully
Since it springs back then the part of the lens that opens it is broken. Then lens covers are very delicate, but usually reliable.
If it's still in warranty, let samsung deal with it. They can usually fix digital hd video cameras in a couple weeks and have service centres in major cities.
If it's out of warranty, try a bit of 100% isopropyl alcohol (see your drug store) on a Q-Tip. Swap it around the lens cover gently and then gently force the cover open several times. The lens cover should be a little wet from the alcohol, but not so much that there are droplets or puddles. Have some kleenex ready just in case of a little spill. That should help to remove any dirt inside that might be affecting the cover.
If that doesn't work and it's out of warranty, then consider repairing it. They will charge you for an estimate ($40ish). Consider replacing it, particularly if the repair cost exceeds 50% of the replacement cost.
May 29, 2012 | Samsung PL120 Digital Camera
When i turn it on it says turn off and on again
I have just had exactly the same thing on my daughter's NV3. In this case the lens cover would not open but if you power on the camera with you finger on the display button you can view stored images. If the lens cover is jammed you need to open the casing and maybe take the lens cover assembly apart. You need a very small cross head screwdriver (No.00 should be OK). There are 5 screws in total, 4 screws on the outside of the case (3 plus1 under the headphone socket cap) and 1 inside the battery compartment. You need to remove all 5 to remove the camera front casing. There are some retaining springs top and bottom on the front cover, gently prize off to reveal the lens cover assembly. Check to see if the lens cover will operate by switching on and off - if it works then the camera front casing is preventing it from opening and is probably bent out of shape. A little careful bending back into shape should resolve the problem. If it still does not work with the casing removed, read on. This is the tricky part. There are two extremely small, black retaining screws to the left hand side which hold the assembly onto the lens cover motor. Remove these screws and the front of the lens cover assembly to reveal the lens cover and the back plate of the assembly. Lift off the lens cover and switch on the camera. If the motor is still working, you will see a short black peg move from side to side as you turn the camera on and off. Thoroughly clean the lens cover and assembly, remove any obstruction and replace the lens cover making sure you locate the hole in the lens cover over the motor peg (described above).
The motor is magnetic and will attract the screws away from their holes if you replace the assembly front straight away, so when you replace the front of the lens cover assembly, place the screws in the correct holes before lowering it into place and then screw onto the motor/assembly back. Test that the lens cover opens and closes and replace the Camera front cover taking care not to bend it too much - if this becomes distorted it can stop the lens cover from operating resulting in the same problem.
Apr 01, 2010 | Samsung NV3 Digital Camera
The lens cover on my Canon Power Shot A530 will not close completely. The camera still works fine, but I am concerned about damage to the lens. Is this fixable?
A stuck lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it: 1) Try blowing lots of compressed air around the lens cover to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Use no heat mode if possible. 2) Slide a thin strip of paper between the lens cover shutters and the outer support ring. Work it around 360 degres to clear out any debris that may be in there. 3) With the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. Repeat the above three steps several times. If repeated tries don't work (keeping in mind that it usually does), it then may be necessary to open the lens barrel to access the lens cover mechanism.
You can open the lens barrel up to fiix the covers, but only as a very last resort. The above procedures normally work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty).
Oct 13, 2009 | Canon PowerShot A530 Digital Camera
When opening len cover I get display on monitor
I do not have a solution to this, but do share the same problem. This was my first digital camera and I was quite happy with the quality of the pictures until it stopped working. I have replaced the camera a long time ago, but wanted to give this little guy a second chance. I have tried to keep the lens open with a piece of tape, and am thinking of breaking it apart to see if I can remove the cover. Any ideas, anyone?
Jun 30, 2009 | Fuji FinePix 2600 Zoom Digital Camera
Camera will not show image when shooting on lcd, why?
press the "disp" button in your camera twice or thrice.
even if the display is not coming means check if the lens cover is opening in front of camera.
if its open and display s not getting displayed means try to reset the camera.
Have you tried a hard reset on their camera by removing the main power batteries for 60 seconds and the reinserting them as if it were the first time power up. This may not fix your particular problem, but when the processor that runs all of the electronic features of the camera gets confused, this is the best way to clear its confusion.
even if problem is not cleared take it to service centre.
Dec 23, 2007 | Canon PowerShot A510 Digital Camera
I cant take photos
ok.under the lens cover there is a small switch which may lose it's place.
to find it remove the batterry cover , remove the two screws on the body of lens cover,then remove the rear cover (plastic and metal-one body) and you''ll find the tiny switch.Put it in a right place to work when lens cover open.
Nov 13, 2007 | Sony Ericsson K750i Cellular Phone
Lens cover not open and blank screen
the problem of your camera is the ccd image sensor...better go to the sony service center for replacing the image sensor..i know it is free for replacing that sensor cause that is one of the model that sony recall produc and the cover not open error message is a poor contact of the lens cover switch...
Sep 09, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Camera lens cover is sticky
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Jul 27, 2007 | Casio Exilim EX-Z55 Digital Camera
Camera lens cover
Broken or damage a small switch under lense cover create this type problem
Apr 30, 2007 | Sony Ericsson K750
Kodak DX6340 Lens Cover Does Not Open
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
Aug 13, 2006 | Kodak EasyShare DX6340 Zoom Digital Camera
Televison & Video Logo
164 people viewed this question
Top Marantz Televison & Video Experts
 Grubhead
Grubhead
Are you a Marantz Televison and Video Expert? Answer questions, earn points and help others
