Question about GE 10KW Generator System With Symphony, I Whole House 200A SED
10k GE home generator starts then shuts down after 12-15 seconds
    Prodigy:
    An expert who has answered 500 questions.
  • GE Expert
  • 573 Answers
There can be several factors:
Assuming it is doing it even when the local run switch on the unit is used versus the transfer switch test.
Check oil level and viscosity, too thick can affect oil pressure switch.
Check oil pressure switch, then check the generator slip rings for tarnish, they should be clean and shiney, after that check the stator windings and rotor windings for shorts and continuity. If you are unable to do the latter, have a pro take a look at it.
Posted on Nov 19, 2013
I have a Kohler 12 RES home standby generator. Once in a while when the power goes out the generator will start and then immediately shut down with no fault codes. When I flip the control in the unit
Check the inlet fuel pressure, on exervise there is no load, when power is out it is loaded and demands more fuel. Also check for bugs blocking gas regulators vents etc
Nov 12, 2012 | Kohler Generator. 12 kW and 14 kW Home...
I have a Briggs and Stratton 7KW standby generator. I accidentally spilled some oil on it during a hurricane and cleaned it. However, when I try to start it, it will go on for about 15 seconds and then...
sounds more like a fuel problem not oil being spilled on it but check the oil level some have a low oil shut off see if you can keep it running spraying carb cleaner in the air filter that will tell you if it is a fuel problem more so a fuel problem if you left fuel in it for more than 30 days
Aug 14, 2012 | Briggs & Stratton 15,000 Watt Home Standby...
I have a 12kw lp gas genwrator that starts and runs for about ten seconds and then shuts down.after maybe 25 tries doing this the generator will stay running and then i try and start it again and it will...
These type of gens have a low oil shutoff. Check the oil. Always have spare spark plugs, a cheap fix. My gen always wanted a new plug every year. Look to see if it has a fuel filter.
Sep 24, 2011 | Generac 13,000 Watt / 13,000 Watt Home...
The monitoring system of our Kohler propane generator has sent a "UU" message. What does this mean as it causes the generator to shut down 10 seconds after starting? Also how can this be...
The monitoring system of our Kohler propane generator has sent a "UU" message. What does this mean as it causes the generator to shut down 10 seconds after starting? Also how can this be corrected?
May 28, 2011 | Kohler 12 kW Emergency Power System -...
My Kohler 17RES has stopped doing it's scheduled weekly exercise. How can I get it exercising again?
On your Automatic Transfer Switch ( the little gray box you see on the right in the picture above) you have two blue buttons. One is a Manual test switch. The other has a clock on it and this is your exercise set button. Hold it down for a FULL 3 seconds if you want it to excercise without a load (not powering your home) Hold it down for a FULL 6 seconds if you want it to exercise with a load every week. Your generator will start and run for 20 minutes, and then shut down. Now every week your generator will exercise at the time and day that you pushed the set button.
Aug 08, 2009 | Kohler 12 kW Emergency Power System -...
Asco transfer switch does not shut down the generator after utility power is restored and the cool down period has been completed.
Same problem here with the ASCO 165, after a couple of fierce lightning strikes yesterday that did over $10k damage to my neighbor's electronics, and also took out my garage door opener.
I'm pretty confident the control board is the problem, but I don't plan to try to replace components. Will probably opt for a new control board from ASCO, or another source, assuming they are still available.
May 07, 2009 | RTO ASCO 165 Series 200A Automatic...
TV powers up for literally a second then shuts down (PT-47WX49)
check R517 on the power supply board if burnt replace with 5% 1/4 watt 10K carbon resistor.
Dec 12, 2008 | Panasonic PT-47WX49 47" Rear Projection...
GE 10KW Generator System With Symphony, I Whole House 200A SED Logo
114 people viewed this question
Top GE Electrical Supplies Experts
Steve
Lawrence Oravetz
robert
Are you a GE Electrical Supply Expert? Answer questions, earn points and help others
