Question about Coleman Mach 15 Air Conditioner
Rv ac compresser
Will not get cold
  • 739 Answers
Vehicular airconditioning systems have issues with leakage of R-134a. Check your pressures while unit is running, low side should read about 70 psig. if much lower than that, purge system and add as prescribed on the labeling. might want to use a leak detecting variety so you can see where you are losing refrigerant.
Posted on Nov 20, 2013
Fan run compressor run but no cold air
DuoTherm by Domestic-Fan runs, no cold air - iRV2 Forums
www.irv2.com > ... > RV Systems & Appliances
Jan 22, 2012 - 12 posts - ‎4 authors Duo Therm by Dometic 13500 BTU air conditioning with ducting, furnace. I. ... If the fan runs but no cold air and the compressor feels like it is ...
A/C just stopped blowing cold.....any ideas??! - RV Forum
www.rvforum.net > ... > RVing message boards > Trailers & Fifthwheels
Jul 27, 2008 - 23 posts - ‎6 authors We have run it continuos like this before without any troubles. Thanks for the help! ....When you switch the AC unit on, the fan runs, but the compressor doesnt fire up. You used to be able ... You can find Dometic here. Logged. Dometic Duo Them Air Conditioner Cycles
Jul 21, 2015
Dometic SL-135 A/C problem
May 29, 2012
Dometic ac compressor runs but fan does not on auto
Jun 5, 2011
AC blower runs full time w/ AC on
Sep 2, 2009
More results from www.rvforum.net
Nov 18, 2015 | Dometic 705600009 A-284, SMX II Retrofit...
Rv fridge works on AC but will not get real cold on lp gas
Check / clear burner and jet by blowing through with compressed air or nitrogen
May 19, 2012 | Refrigerators
Water dripping out of rv ac into rv.
Is it a ducted system? If yes, check that there isn't gaps between the divider that separates return air at the front, with forced(cold) air. You can usually use a flashlight and look for gaps, or even (very carefully) feel it blowing cold into the warm air return. If you find some gaps, buy some foil tape, and tape them off good and retry and see if it still happens. Some older units experienced cracks in drip trays that allowed condensation to drip inside as well. Get back to me with year of your RV, and whether it's ducted or non-ducted system, and perhaps I can guide you better on what to look for.
Jun 20, 2010 | Dometic Rooftop RV Air Conditioner
How cold should it be in rv with two low orofile
Most AC units only change temperature approximately 20 degrees F from ambient.
Aug 17, 2009 | Dometic Rooftop RV Air Conditioner
My Duo Threm RV AC wont get cold
this could be the controls for the compressor circuit (thermostat) or the starting components for the compressor, (capacitor) or the compressor itself. Start at the compressor with a call for cooling, verify voltage, if there is voltage a tht compressor terminals, most likely the compressor will need to be replaced...trace back to the source of power if no voltage is at the terminals, and you should locate the culprit...hope this helps..
Aug 15, 2009 | Dometic Rooftop RV Air Conditioner
Recycling to soon?
sounds like the unit is low on freon. it will need to be serviced so the leak can be fixed then recharged.
Jun 01, 2009 | Coleman Mach III Air Conditioner
Coleman Mach 15 Air Conditioner Logo
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
