Question about Stanton C.402 CD Player
Stanton C402 won't spin disc, but clamps it, reads "no disc" on display
4 Suggested Answers
SOURCE: c-314 stanton cd player, reads no disc, but disc is in cd player
as with my other posting - all i could do was mail it to be fixed. then it stopped working again so perhaps its time to go elsewhere.
Posted on Oct 13, 2008
SOURCE: my stanton c324 i replaced
Make sure that the solder dot is removed from the new mechanism or it will not play. One of my C-324's stopped working at a school carnival and later I found out that some solder had dripped on the same spot and caused the mechanism to quit.
I hope this helps.
Posted on Dec 18, 2010
  • 1456 Answers
SOURCE: When I load a cd in my Stanton C324 it reads "No
Hello
Clean your CDs before and after playing them. Although the compact disc has a much longer lifespan than does something like a cassette tape, it can be more fragile. Scratches, dust or other damage to the data side of the CD will cause many CD players to fail to read the CD or cause the CD to skip.
Examine the type and format of the compact disc if your CD player fails to read it. Verify that your CD player can read the type of CD and the files contained on it. Just because you've burned a collection of songs to a CD, for example, doesn't mean that your CD player will be able to recognize that information. You must burn CDs in a specially formatted "Audio CD" mode to play them on a CD player, or your CD player must be able to recognize the MP3 file format. Some CD players have limitations on the type of CD they can read. Verify that your CD player can read CD-R, CD+R, CD-RW or CD+RW compact discs.
Update your CD player's driver, if your CD player is a drive connected to your computer. Click "Start" and select "Control Panel." Click on "Hardware and Sound" and select "Device Manager" under "Devices and Printers." Right-click the icon for your CD drive and select "Update driver software." This may solve any issues the drive was having with playing CDs.
THANK YOU FOR VISITING FIXYA
Posted on Mar 07, 2011
Stanton c324 will not play disc after replacing laser
Have you removed the blob of solder on the laser board thats left there to protect it from static while handling it
Jun 07, 2014 | Stanton C324 Mp3 Cd Player With Effects...
My CD player keeps displaying no disk and wont play the cleaner disc, is something dirty or broken?
Hello
If it does not play the cleaner disc, just inspect whether the disc inserted in spins inside it. You can check this by open the upper cover of the player, and inserting a disc into it. If inserted disc spins inside, and the player won't read it, the fault is with its laser pickup unit, and it should be replaced with same type and number.
If the disc dos not spins, the fault is with the sled motor [the motor that spins the inserted disc], has damaged, and should be replaced. OK.
Dec 25, 2011 | Sharp Audio Players & Recorders
It's brand new, and it won't read disc
Run a cleaner disc thru 'em. If that doesn't fix it-take it back.
Sep 21, 2011 | Stanton C.324- Cdj C 324 C324cdj C324...
When loading a dvd it displays, "NO DISK". Is it
Hello
There are mainly three motors for most of the DVD players. One to spin the disc we insert in, other to load the laser pickup unit to-and-fro inside it to read the disc and an other one to load the tray mechanism 'in-out'. According to your description, the disc spins inside, and you can hear its spin. So motor which spins the disc has no trouble at all I should say. Then comes to the second motor that moves the laser assembly inside it. If it do not work, the laser pickup unit won't move and no reading will take place and 'No Disc' display will be the result. The last chance is with Laser Pickup Unit itself. Just get this unit repaired by any well experienced service technician or by the authorised service center, because, there are special tools to open this unit. As it is a compactable one, more care should be given to it while repairing. Suspect the second motor I described earlier, and the Laser Pickup Unit. OK.
Jun 14, 2011 | RCA DRC628 Portable DVD Player
I have the stanton c324, every time i put the cd in, it want to read it. then it said no disc. i told it apart and clean the len, and it still said no disc. is there a repair shop in southern California or...
If you took it apart you might of voided the warranty. Try buying like a cd cleaner they sell them at bust buy and stuff and give that a try. If that doesn't work. Contact Stanton and Have them take a look at it for you.
May 05, 2011 | Stanton C324 Mp3 Cd Player With Effects...
My stanton c324 i replaced the reader and its still showing no disc and the disc will not spin.
I hope this helps.
Nov 16, 2010 | Stanton Audio Players & Recorders
The disc changer isn't reading the discs, instead it will just keep changing discs.
Take the cover off. Look to see if the unit "clamps" on each disc and tries to read it. If it does you need a new laser. A new unit is usually more cost effective though. If your machine doesn't clamp or spin the disc the problem could be mechanical. 99% of the time the laser is at fault. Good Luck!
barneyluc
Oct 05, 2008 | Pioneer Audio Players & Recorders
C-314 stanton cd player, reads no disc, but disc is in cd player
Jul 28, 2008 | Stanton C304 Single Top Loading CD Player...
Stanton C.402 CD Player Logo
37 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Electro Med Services...
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
