DC Input Broken - Computers & Internet
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 18 Answers
Replace with a new router or switch or hub are the only options. you can pick a new one up cheap on ebay or amazon
Posted on Dec 18, 2013
Cobra 200 has no power and lights do not light up
Could be a number of things power related. Check the input cables to the radio and find a broken cable or jack. Otherwise check the regulator circuit of the radio internally. If the external wires are not providing DC than it is likely the cabling.
Feb 01, 2015 | Cobra Radio Communications
Broken DC/DC converter
It is probably a shunt fed switch mode power supply with a short circuit chopper transistor.
Jun 15, 2014 | Computers & Internet
I have Acer Laptop with a JV50PU motherboard which has a faulty DC input socket connection. The laptop works OK on Charged battery but not on DC input. Is it possible to get a schematic of the motherb
If the DC Power Jack is soldered onto the motherboard then take the time to unsolder it and remove it. Then buy another DC Power Jack which costs less than $8.00 and solder it into it's place. Normally when it is soldered onto the motherboard there is no cable involved. That's all there is to it if it's soldered onto the motherboard.
If it sits on a slot in the motherboard and has a cable harness attached to it then you can purchase that too for less than $15.00. All you do then is follow where the other end of the cable harness plugs into the motherboard and unplug it. Then place the new dc jack in the slot where the old one sat and plug the other end of the cable harness into the motherboard.
Mar 20, 2012 | Computers & Internet
NEED DIRECTIONS ON HOW TO INSTALL DC INPUT FOR TOSHIBA
This is not something you can do yourself. It requires soldering. You first have to remove the old jack then solder the new one to the board.You can,t over heat the board and alot of other stuff. We repair jacks for 110.00$.Look us up on facebook...rippy computers or call 704 820-6433.we would be glad to help you if we can.We do alot of mail order repairs.
Apr 28, 2010 | Toshiba Satellite A105 Notebook
Amilo Pro v2065 shuts down when battery is plugged
you need do check:
1) no charging means adapter input problem, first check your adapter DC output voltage is ok
2) check DC jack socket on the motherboard:
--- DC socket any pin disconnected, you need use iron and flux to fix it
--- DC socket damage(broken),you have to change it
3) if DC socket connection normall, the DC/DC circiute near around DC socket some component damage, you need find a technacian to repair.
hope help you to deal it well
May 14, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
DC input jack broken
Yes it's not usually something that can be repaired at home. Your chances are better if the jack just seems loose and not actually broken, however replacing it is better. I work for a Laptop Repair Shop in NYC and we deal with this issue frequently.
Dec 25, 2008 | Acer Aspire 5500 5570-2609 Laptop
you need to buy a new jack for replacement. then solder the broken one out of the mainboard and clean the place and solder the new one. or some acer have a separet jack then that one is easy only to change.
DC input port broken.
Radio Shack can get it... Call 304 925 3992 and ask for John
Dec 10, 2008 | Amphion Mediaworks AMW M510
I own a four track recorded, but to get it work i have to manually apply pressure to the power input in order for it to turn on. is it possible for me to fix this problem so that i dont have to fuss around...
Hello!
You have a dc jack for power input or an ac line?? I bet dc jack...Take the unit apart and solder the broken connections at the dc jack. I have done it over 1000 times...literally. Good Luck!
barneyluc
Oct 11, 2008 | Audio Players & Recorders
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
