Question about Dacor Preference PGR30 Gas Kitchen Range
My oven won't heat. When you press bake it goes to prebake 135 but does not heat. The fan works and the stove top works. We have model PGR30. We cannot find the reset button to try
ngfam1
  • 639 Answers
SOURCE: Convection Oven not working
I'm Neil and glad to be at your service!
First you always need to wipe out any large spills or hunks of food before self cleaning or you will get smoke and sometimes a little fire inside! The manual will tell you this.You can get a new manual online at the web site for your brad range!
It will not harm anything but may be uncomfortable in your home!
This time you need to call service!
For a good service you might try,
A&E Factory service
1-800-905-9505 7days / 24hours Nation Wide
Please give me a solution rating here at fixya.com
Thank You
Neil
Posted on Aug 24, 2008
SOURCE: dacor rsd305
yes, you need to open the panel (in the center of the front of the oven when you open the door on the top) and press the reset button, there is a site that gives step by step instructions, but i can no longer find it
Posted on Aug 25, 2008
  • 435 Answers
SOURCE: Oven starts, then shuts off; won't stay on
Since, it works only for short time, I believe something is wrong with the circuit.
I would suggest you to call the service guy and fix it.
Posted on Sep 30, 2008
  • 288 Answers
SOURCE: Oven will not heat
Heating elements are protected by a fusable link that is a one time fuse that is meant to protect the stove from overheating. It sounds like the elements need to be replaced
Posted on Jan 19, 2010
rickead1
  • 1998 Answers
SOURCE: Dacor dual fuel range (ERD36SBK):
It could be the oven ignitor which is located under the heat displacement shield if you have a voltage meter or a multimeter do an ampere test should first shut the gas off next locate the oven ignitor or bake ignitor and you will see two wires that go to the ignitor clip around one of the wires should be reading 3-3.3 amps any less then this and the oven will not light even if it read 2.9 it would still be a weak ignitor and need to be replaced because it would not be lighting the gas when it was supposed to check your oven ignitor and message me back with your finds And please remember when our chat is concluded to rank how this opinion has helped in your appliance situation Thanks again and Happy New Year
Rick
Posted on Dec 29, 2010
Oven will not heat at all. Stovetop works fine
Phillip, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oven Wont Heat or Not Working Bake and Broil Element Testing Oven...
Electric Stove Troubleshooting Oven Not Working
Top 6 Reasons Electric Oven Wont Heat Electric Range Troubleshooting
Stove Terminal Block Replacement Frigidaire Electric Range Repair part...
Jun 17, 2016 | Kitchen Ranges
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Oven was heating and we got HEAVY smoke....
Nothing in the elements, thermostat thermocouples are gas filled, sensors have wiring inside, nothing in the liner or insulation. You said this was a stove, and some stoves have a vent that goes up through one of the burners on the top. If you had oil splatter or drip into this it can get into your oven. We do know that some blower fans on convection ovens have a sealed oil bearing, but there would be very little oil coming out of this (drops) and you will notice your fan getting noisier or running slower in the near future. Good Luck, Appliance Specialists
Jan 25, 2010 | Ovens
Stove Top on Oven works fine. The Oven has stopped working. You can press bake and it will work and adjust temperature and it will light up that it is pre heating but no heat inside oven
there is more than likely a problem with the control board.but you can check the continuity of the bake element.this may also be bad
Jan 21, 2010 | Frigidaire Ovens
Oven will not heat; convection fan runs when in convection mode, but elements won't heat for convection bake, pure convection, bake, or broil; it comes on as if it's going to work but the temp gauge never...
Jan 19, 2010 | Dacor Preference RSD30 Gas Kitchen Range
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
My ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Dec 18, 2007 | GE JKP20 Electric Single Oven
Dacor oven
I believe it is supposed to be. Prebake, including the convection fan, will happen until the oven reaches the set temperature.
Dec 11, 2007 | Dacor Preference PGR30 Gas Kitchen Range
Oven wont work at all.
Convection oven and Bake will not heat past 200degrees. Broiler works fine and the range works fine.This is for the Model # MGR5875QDW, Gas Precision Touch Control 800, can you help. Thanks Kasz3
Dec 24, 2006 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Dacor Preference PGR30 Gas Kitchen Range Logo
76 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
240cpa
Jaime Hernandez
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
