Question about Troy-Bilt Squall 2100 208 cc 21-in Single-Stage Gas Snow Blower 31AS2T
Troy bilt sequall 2100 will not start. has new plug
Has new plug and turns over fine. new gas.???
    Sergeant:
  • 417 Answers
Is the gas making it TO the new plug? Pull it over a dozen or so times on full choke and then pull the uh to see if its wet meaning the engine is getting fuel. Also make sure the safeties and off switches aren't preventing it from starting
Posted on Nov 21, 2013
Where is spark plug located on Squall 2100, 4 cycle,208cc ohv?
You will have to drop the back panel. See picture also add a link to your manual.
Troy Bilt Snow Thrower 31AS2T5F711
Feb 15, 2016 | Troy-Bilt Squall 2100 208 cc 21-in...
Electric start on Troy Bilt 21" single stage snow blower doesn't work. Recoil starter does. Electric start worked last year, but today, nothing. All cords good, power, etc.
The starter could be bad. Remove starter and see if it will turn over when 120v is applied.Check the wires to starter first! Good-Day!
Nov 16, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
My Troy bilt squall 2100 snowblower does not idle steady. It races and slows while idling.
It sounds like the carb needs cleaning and readjusting, or the fuel filter is clogged. Good-Day! Remove and clean out carb, it may be dirty inside.
Nov 13, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
How do I drain the oil from my Troy bilt 2100 squall snow blower so I can change the oil?
You need to remove the lower panel to access the engine. In the engine blow-out, the oil drain plug is numbered 77 (bottom of the crank case).
25256884-5livr0uqynklw3svefpqfefw-2-0.png 25256884-5livr0uqynklw3svefpqfefw-2-2.png
Oct 26, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
Troy-bilt starter seized
Remove starter, and see if it will turn over by applying 120v to starter. If it wont work. Starter is bad. Good-Day!
Mar 13, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
Sequall 2100 will not start
Change the coil at the magneto that generates the high voltage to the spark plug
Nov 18, 2013 | Troy-Bilt Squall 2100 208 cc 21-in...
I have a troy-bilt squall 2100 snowblower that wont start. Primer bulb doesnt seem to do anything. Use of starting fliud in the air intake will get it to start briefly. Removed carb bowl and there seems...
I share your frustration. We just had our first snow fall of the season and my Troy Bilt Squall 2100 would not start or do anything. The snow blower is well maintained and does not have 2 hours use. I use 0-30 synthetic oil and installed fresh gasoline. It is simply maddening to have plunked down close to $500.00 and have a useless snow blower. Trying to get through to Troy Bilt's help line is next to impossible.
Nov 21, 2010 | Honda Garden
Troy-Bilt TB70SS will not start
Hi. Go to any auto parts store and get a can of starter fluid. Have a helper squirt a little into the air cleaner while u start it up. Then continue to squirt the starter fluid to keep it running until the engine sounds good again. J.
Jul 07, 2010 | Troy Bilt Tb70ss Gas Trimmer
Troy-Bilt Chipper Shredder won't start
It takes good gas, good spark, and good air for a gasoline engine to run well. The next thing I would do is put a new air filter in it.
Apr 23, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Troy-Bilt Squall 2100 208 cc 21-in Single-Stage Gas Snow Blower 31AS2T Logo
193 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
