Question about Vehicle Parts & Accessories
Radio key fails to opetate Driver side door opening other door not opening
  • 26 Answers
You will need to pull the door panel off to check the actuator rod . if the rod is conected then replace the actuator itself.
Posted on Nov 18, 2013
How do i get the radio to go off when key is off and driver door is open on 2006 chev. impala?
Are the keys removed? Have you tried the power button? When I"m getting out of the drivers side the radio always cuts off, if the keys are out of the ignition.
Jul 02, 2014 | 2006 Chevrolet Impala
I got a 2000 Pontiac trans am and every time I turn the car on the driver side window will roll down and it won't roll back up. But the passenger side window works fine. And when the stereo works the...
How about when the radio is on & the key is off or
in your hand,if you open either front door does the radio go off
& do you lose the delayed window feature assuming you have that
If so you problem is a delayed accy relay
Next would be the front door switches
I will give you credit for what you tried
but fail to see why you would switch motor
from door to door,they work powered directly or they don't
I would think your battery would have gone dead by now
if the relay failed to time out or go to sleep
Jul 27, 2013 | Cars & Trucks
My radio will not turn off when I open my door on the driver side
Generally speaking, the radio and some other circuits "keep power" after you turn the key off for up to 10 minutes. When the door is opened and the interior lights come on, the power source is supposed to be turned off.
This "keep alive" relay could be in the body computer or it could be a separate relay.
You may need to have a shop take a look at it, or get the shop manual to have the wiring diagrams and test procedures.
Jan 24, 2013 | 2004 GMC Yukon
1994 toyodriver,s side door cannot open from outside and inside even with key
The mechanism or door rod has been disconnected inside the door. Replace as needed.
Jan 21, 2013 | Cars & Trucks
Radio does not go off when key is out of ignition and door is shut
You are on the right track...the problem appears to be on the driver side rear door actuator switch...locate this spring loaded sensor usually on the inside of the door by the hinges...spray it with PB Blastor, or WD 40...(Blastor works better) and move the switch back and forth...this should loosen up the sticking actuator and return your Buick to normalcy...Hope this helps
Jul 03, 2012 | 1998 Buick Century
04 expedition radio won't turn off after I take
Does it turn off when you open the driver side door? If so, that's normal. My car also keeps the radio on when the key is taken out of the ignition until I open the driver side door. If the driver side door is not opened then the radio will only stay on for 8 or 10 minutes though. If it's not turning off ever, even when you open the door, then I don't know what's wrong with it.
Cheers!
May 02, 2012 | Pioneer Car Audio & Video
The driver side door does not unlock - can only (central locking)
Hi:
It is extremely difficult to remove the door panel with the door closed. You mentioned that you can unlock the door with a key, so does the door still open and close once unlocked? You most likely just need to replace the power door lock solenoid, as when they fail, they usually sieze up, and make manual lock unlocking difficult.
May 04, 2010 | 2000 Honda CR-V
My driver side door wont open how do i get it
sounds like the door lach is sticking
use some wd40 spray the lock and let it sit 4 a while
now since you have the inside skin off reach inside the door with 1 hand and try and open the door from the outside and see if the lock bar moves it usualy pushes down i think on a lach
if it goes up and down with no resistance make sure it is contacting the lach if yes make sure the door is unlocked
somtimes the lock is just stuck
after unlock open the door
push down on lock bar attached to lock then pull up on it if that fails to open door
after that all fails unlock door have friend pull handle and then give the door a good kick from inside just remember not the kick the glass
Jun 25, 2009 | 1998 Mercury Mystique
Door lock 2004 jetta wagen
If remote locks and unlocks driver door but does not unlock passenger doors,then follow the advice above:
Get in the car using the key to unlock the doors. From the passenger side lock and unlock your doors using the button on the passenger door. Get out and the remote should now unlock all the doors with 2 presses.
Worked perfectly for me after several other suggestions (and dealer) failed.
Nov 07, 2008 | 2004 Volkswagen Jetta
Vehicle Parts & Accessories Logo
22 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
