Question about Samsung Televison & Video
How remove back of Samsung 245T? No screws visible.
How do I remove the back of a Samsung 245T monitor? No screws are visible. Thanks.
3 Suggested Answers
SOURCE: I am attempting to repair
on off button doesnt work
Posted on May 02, 2011
To remove the back, use a Phillips screwdriver with a shaft that is slightly smaller than the hole. While gently pulling on the back cover, push the point of the screwdriver into each of the 4 holes as far as it will go and you will feel the back release from the front.
Posted on Nov 23, 2015
Can someone tell me how to open the case of my Samsung 932BW? There are no screws on the back or front. I need to open it up to take a look at the capacitors. Thanks.
1.follow this first
2.Turn the monitor so the front section is facing
upwards. after completely pulling this front cover,
Turn the monitor so the back of it is facing
upwards. Lift up and remove the back cover.
Sep 27, 2010 | Samsung 932BW Monitor
Is there a fuse I can change in my Samsung 245T?The unit does not turn on.
Yes, there is main AC fuse.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Service manual: http://elektrotanya.com/?q=showresult&megnev=samsung%20&megnev2=245&kategoria=monitor&kat2=schematics
Jun 11, 2010 | Computers & Internet
High pitched whistling
Try changing refresh frequency, color depth or resolution (wait for the whistle to appear before testing). Admittedly, you might have to give up some image quality - less colors, or less resolution. There is probably a problem in the TV syncing mechanism - if you can, try getting it replaced. "High pitched whistles" in video and TV hardware are usually harbingers of bad news.
Aug 24, 2009 | Samsung SyncMaster 245T 24 inch LCD...
How to open the back cover of Samsung SyncMaster 794mg CRT .
"Don't kill yourself just to save some bucks"
Here are the instructions:
http://www.josepino.com/?open-samsung-back-cover
Apr 24, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
How do I open cover of Acer AL2021 Monitor ?
This is a bit tricky, but not impossible.
1. Remove the two visible screws near the bottom. 2. Pull the plastic covers off the stand: Pull from the inside (nearest where the stand is attached to the monitor. 3. Undo the screws and remove the bracket. 4. Under the bracket is the final screw. 5. Try pulling the front off the back starting at the bottom. It'll require a little force. 6. Now you should be able to get a knife in to pull the rest of the case off. Leaver by pushing the front outwards and back inwards and the clips should come off ok.
Aug 06, 2008 | Samsung SyncMaster 550S Monitor
Xerox
remove both visible screws on back.  Slide front cover off (pushing the glass off, toward its bottom.
Mar 11, 2008 | Xerox XG-91D 19" LCD Monitor
Sam.SyncMaster750S control buttons not responding
First, be aware that the flyback xformer can carry a 50,000 volt charge that can arc to anything grounded. Unless you are possitive the chasis is not hot, I'd forgo pulling it apart.
That said, if you turn the monitor on its face and remove the stand. You'll see two screws on the bottom corners of the monitor housing. Remove them. Next, turn the monitor upright with the screen facing you. you'll see two VERY small openings along the top edge of the monitor bezel. Insert a small flat-headed screw driver into each opening, and press gently down. You should hear the locking tabs release. DO NOT pry the case as you will damge it. With the screws out and tabs released, the case will easily break apart.
Jan 22, 2008 | Samsung SyncMaster 750S Monitor
Televison & Video Logo
23 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
