Question about Philips Philishave HQ6707 Electric Shaver
Screwdriver undo philishave screws torx - Philips Philishave HQ6707 Electric Shaver
Nokia 6303 screen faulty following accidental washing machine incident. Unable to remove front cover after unscrewing 2 torx screws. Can you advise. Thanks.
After undoing the two torx screws pull the bottom up (you have to press in the little black tabs holding it, one side at a time) and then slip a small screwdriver between the sliver cover and the black body and leaver it up. Start at one side and work your way around. I am not a phone engineer so don't take this a gospel but I as I couldn't find any information how to do it I just tried various methods and with this it just popped off.
Jan 12, 2010 | Nokia Cell Phones
The top off Hotpoint WMA35 washing machine?
Located at the front end of the top cover, are 2 plastic covers, prise them out with a small screw driver or something similar, and inside are 2 torx screws, get a torx screwdriver, and undo the 2 screws, if tyou don't have the correct screwdriver, you may be able to undo them with a small screwdriver.
Give the top a good hard push towards the rear, and it should come off..
Hope this helps.
Dec 28, 2009 | Hotpoint WMA35 Front Load Washer
Undoing screw to get into ps3
you need a torx bit,not sure of the size though,i open mine with a small flat screwdriver.
Apr 17, 2009 | Sony Playstation 3 (PS3) Console
Changing an element on the main oven - Neff U1721 Double oven
You should not need to remove fan to access the element fixing scew(s).
You may need what is called a torx screwdriver, if the screws are conventional screws, but some times a small screwdriver will undo them if they are not too tight.
let me know if you require any more assistance.
Plz rate my solution.
Thanks.
Jan 10, 2009 | Neff U1721 Double circotherm Electric Oven
Unable to remove the backplate off Neff oven
If there are no screws at the rear of the oven compartment that you can see to remove, then you will have remove the oven from the housing, and remove outer rear panel of oven to access the element.
Check the 4 fixings again, because on some ovens , they are not using coventional screws, they are are using what are called Torx screws, and you need a torx screwdriver or key to undo them.
Thanks.
Jan 07, 2009 | Neff U1721 Double circotherm Electric Oven
Broken screen
boatsy,
replace the lcd..
Apr 07, 2008 | Nokia 6288 Cellular Phone
Security torx screws
Go to a local hardware store, and ask them for a TORX screwdriver set.  The screws come in a large variety of sizes, and buying a set is the best way.  Make sure that at the base of the driver head it has a small hole for the security nib the screws have that prevents most ordinary screwdrivers from oppening them.
Jan 11, 2008 | Microsoft Xbox 360 Console
Cleaning the filter
Is it a recessed star, or a raised star? If it is recessed, the tool is called torx. Most of your better tool suppliers will have them. The raised star.... I cant help you.
Nov 15, 2007 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Philips Philishave HQ6707 Electric Shaver Logo
74 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
