Question about Singer Sewing Machines
Singer 758 model and the material is not feeding through the machine. Needle is only going up and down in one spot.
    New Friend:
Feed dog will not pull thread through
Posted on Jun 27, 2017
  • Singer Master
  • 7,365 Answers
Here is a link for a free manual, check to see if the feed dog lever is up in the sewing position, if the feed dog lever is down then try to raise it up. if it will not raise then the machine needs to be check to see what's wrong with the feed dog.
http://www.singerco.com/uploads/download/6dc4cd61b0c61a5fc13e60785f01d29199328059.pdf
Posted on Nov 18, 2013
SOURCE: Feed doesn't feed Singer 560
there should be a control to raise or lower the feed dogs, lower to stipple and high to sew normal. it sounds like you may have lowered them
Posted on May 07, 2008
  • 1788 Answers
SOURCE: Machine will not feed material
Use a fresh needle and install with flat side facing rear of machine. Is your clutch engaged, after you wound the bobbin? Do you have an owners manual? If not, go online to brother-usa.com and download one for free. It is good to have a copy on hand anyway. Good luck
Posted on Sep 12, 2010
  • 1788 Answers
SOURCE: how do you get the feed to stay level instead of
What on earth are you trying to do? Feed dogs move the fabric and are doing what they are supposed to do. Are you trying to darn? Embroider? Normally there is a plastic plate that you put over the feed dogs to do that or there is a lever to lower them. I could not find a manual for your machine so I can't tell if you have either of those.
Posted on Apr 25, 2011
SOURCE: Singer 758 model and the thread is bunching up from the bobbin under the material
try changing the needle--flat side goes to the back of machine
rethread the machine top & bobbin--make sure to use every thread guide
make sure bobbin is wound correctly & inserted correctly in the bobbin case
clean under the needle plate & in the bobbin area for lint or loose threads
if you don't have a manual try singer
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number(example 758)
Click search
Posted on Apr 10, 2012
spydurmann
SOURCE: Hello. I own a Singer
i had this problem about a week ago. the jam even messed up my hook timing. i re-timed my machine, cleaned out everything and it still wouldnt work for me. i changed out the needle, tried different fabrics and threads but nothing seemed to work. i finally changed the stitch to a zigzag stitch, and it seemed to work ok. i went through all the different stitches sewing a line about 3 inches long. my sewing machine now works fine. i think when i switched stitches in the past it messed up the needle alignment. (im not an expert or anything, in fact i recently taught myself to sew. i hope this helps you out)
Posted on Apr 13, 2012
Does singer model 758 have a feed dog?
Yes, the vast majority of sewing machines have feed dogs. That is how the fabric is pulled through the machine to produce the line of stitching.
Singer Touch Sew 758 Instructions Manual
Jun 27, 2017 | Singer Sewing Machines
Model 1 1425n. Why can't I get the material to feed through?
try changing the needle, make sure the top thread has not come off the take up lever, also check to see if the feed dogs are in the up position, so the machine can sew.
May 27, 2015 | Singer Sewing Machines
How do I stop my needle from breaking and how to I see to it that the machine is self feeding the material forward instead of me having to pull it towards me to get the stitches into the material?
The needle may be bent, but surely the material should feed away from you not towards? Is the bobbin in correctly? If you have inadvertently left the feed dogs down the material will not be gripped and stay in the same place instead of moving. Check.
Mar 27, 2015 | Sewing Machines
My sewing machine thread is sticking around the drop feed control
There are several possibilities, but the most likely is you have a burr on the needle plate that is catching the thread. Run your finger over the plate, and if you feel a rough spot, use an Emory board to smooth it. You can also easily replace it. Sewing Parts online has a replacement plate for $12.99, by the way, and I'm going to provide the direct link below.
Another possibility is the bobbin is not correctly wound, the bobbin case is not correctly inserted, the surface of the bobbin case has a rough spot (solve an Emory board the same way), the needle is not all the way up in the clamp, you did not thread with the presser foot UP, or your bobbin is warped. To determine that, roll it down a flat surface. If it wobbles, it's warped. Needle Plate Singer 416472401
Oct 02, 2014 | Singer Sewing Machines
Singer 758 breaking needle
Machine breaks needles
1.make sure you are using the right needle for your type of sewing machine.
. There are cases where the machine will only use ones specified in the owners manual.
2.the presser foot may not be installed properly
3.use the correct needle for the type of fabric you are working with. To fine of needle on heavy fabric or to course a needle on silk or jersey can damage fabric.
4.let the feed dogs guide the fabric & the feed dogs will work with the presser foot .
5.the needle is not all the way in -push all the way up against the stop
6. Check top thread tension
7. machine could be out of time & need to be serviced
May 26, 2012 | Singer Sewing Machines
Click search
Apr 10, 2012 | Singer Sewing Machines
I have a Singer Stylist 513 & I cannot get the feed dogs raised.
The model 513 Singer has two gears which operate the feeding mechanism. If one of these gears is broken, the machine will run except the feed dogs will not move. This is a very common problem with this model.
Aug 03, 2010 | Singer Sewing Machines
The feed dog will not advance the material
Call Singer at 1-800-4singer and they will help you. I think a piece of the needle may be stuck in your feed dog
Oct 11, 2009 | Singer 3116 Simple
Model 6233 Singer material will not feed needle goes up and down
Is the feed dog pushed to the up position? How about selecting a stitch length? I have a feeling watching the dvd and instruction manual will do wonders for you, If you lost your manual, go online to www.singerco.com and download one for free,
Apr 22, 2008 | Singer 3116 Simple
Sewing Machines Logo
311 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
